I recently acquired a 3.2" TFT LCD (The SainSmart one) with the SSD1289 driver.
I cannot get it to work in 8-bit mode, and I need the extra pins for the touchscreen and the SD reader. The driver is capable of 8-bit operation and this particular board, link below, is said to have 8-bit support on SainSmart's webpage (in Chinglish, though).
I am using Henning Karlsen's UTFT library, link below.
Also, I am quite sure that I wired it right, since I did it according to the UTFT_Requirements.pdf in the library folder (with DB0 to DB7 tied to GND).
Now, I did some sniffing in the SSD1289 datasheet, link below, and found out that it requires, for 8-bit mode, a certain combination of pins PS3, PS2 and PS1 (eg. if PS3 = 1, PS2 = 0, PS1 = 1, PS0 = 0 than it is in 6080 8-bit mode). However, these pins are not on the breakout of the LCD.
SainSmart webpage for the LCD:
http://www.sainsmart.com/sainsmart-3-2-tft-lcd-display-touch-panel-pcb-adapter-sd-slot-for-arduino-2560.html
Henning Karlsen's UTFT library:
http://henningkarlsen.com/electronics/library.php?id=52
SSD1289 datasheet:
