krebad
October 26, 2021, 8:00pm
1
My code i as follows:
float radius;
String msg="What is the radius of your circle? ";
float area;
String msg2="Your circle has an area of: ";
float pi=3.14;
Serial.println(msg);
while (Serial.available()==0);
radius=Serial.parseFloat();
area=piradius radius;
Serial.print(msg2);
Serial.println(area);
//the result i get in my serial monitor is as follows:
Your circle has an area of: 12.56
Your circle has an area of: 0.00
// I entered 2 as my variable and get the proper result. then I get the second entry of "Your circle has an area of: 0.00.
have not figured out why.
Change the line ending setting on the serial monitor to "no line ending" or "none" or whatever gives no line-ending character like CR or LF, or both..
Please remember to use code tags when posting code
krebad
October 26, 2021, 8:03pm
3
Coding tags? I am very new to this. Thank you so very much for your assistance.
Yes, that's right.
The things that stop your posted code making no sense.
(Hint: read it back and compare it to your actual code)
krebad
October 26, 2021, 8:19pm
7
can you show me which line you are referring to?
I will go back and look at the posting requirements for code.
Thank you so very much. I started this just a few days ago and am now addicted.
The line in your original post that doesn't look like the same line in your original code.
gcjr
October 27, 2021, 9:04am
9
consider (Arduino sprintf lacks floating pt formating)
String prompt ="What is the radius of your circle? ";
char s0 [80];
char s1 [20];
char s2 [20];
Serial.println(prompt);
if (! Serial.available())
return; // nothing to do
int n = Serial.readBytesUntil ('\n', s0, sizeof(s0));
s0 [n] = 0; // replace '\n' with null
float radius = atof (s0);
float area = PI * radius * radius;
dtostrf (radius, 8, 3, s1);
dtostrf (area, 8, 3, s2);
sprintf (s0, " radius %s, area %s", s1, s2); // reuse s0
Serial.println (s0);
There is no need to re-invent PI, it's already defined for you in the core. Here is the source code:
#define PI 3.1415926535897932384626433832795
330R
October 27, 2021, 11:54am
12
krebad:
Code tags?
There's more than one way to do it, by the way. You can click on the button marked </>
while you are editing, you can use traditional [code]
and [/code]
tags, or (my favourite and the most versatile) you can post your code between 2 instances of 3 consecutive backticks, with the optional indication of the language (usually cpp), like so:
```cpp
// Your code goes here
330R
October 27, 2021, 11:59am
13
At least, OP truncated it to 2 decimal places. Once upon a time, the State of Indiana did much worse .
system
Closed
April 25, 2022, 11:59am
14
