Problem with a blinking LED
Hello
I am an Arduno beginner.
I am trying to get 2 LEDs working with different blinking times through for loop
The program is working fine with no problem.
However, when I add the Serial.begin(baud rate) One of the LEDs (yellow) is constantly turned on and not blinking.
When this Serial.begin command is disabled, the LED is blinking as it should
Any reason for that?
Is related to the OS : Windows 10. I also work with the latest Arduino version
I appreciate any help
Thanks
Here is the code:
int redLED = 3;
int yellowLED = 1;
int waitTimeonRed= 100;
int waitTimeoffRed= 1000;
int waitTimeonYellow= 100;
int waitTimeoffYellow= 1000;
int numRedBlink= 3;
int numYellowBlink= 2;
pinMode(redLED,OUTPUT);
pinMode(yellowLED,OUTPUT);
void loop () {
Serial.println(" The Red LED is Blinking");
for (int j = 1; j<=numRedBlink; j=j+1) {
Serial.print(" You are in Blink No.: ");
Serial.println(j);
digitalWrite(redLED,HIGH);
delay(waitTimeonRed);
digitalWrite(redLED,LOW);
delay(waitTimeoffRed);
Serial.println(" ");
Serial.println(" The yellow LED is Blinking");
for (int j = 1; j<=numYellowBlink; j=j+1) {
Serial.println(j);
digitalWrite(yellowLED,HIGH);
delay(waitTimeonYellow);
digitalWrite(yellowLED,LOW);
delay(waitTimeoffYellow);
That is because Serial use pin 0 and 1. The pin 1 in your code is used for both Serial and LED.
To solve it, change LED pin to other Arduino pin.
You can also use the library to blink multiple LED without delay
On many Arduinos, pins 0 and 1 are used for serial i/o. Sharing can happen but takes special effort. It would be best if you chose a different pin for your yellow LED. You must change BOTH the code and the wiring.
