I'm trying to use Universal-Arduino-Telegram-Bot.
So I choose the library and it's included in my project without errors. But when I try to compile I get a lot of errors - Method 'as' could not be resolved
Here for example
Pictures of code are almost always a waste of time, as in this case. Please copy the code and post it here in code tags (the </> icon above the message editor)
The project works well. I upload it on the board and all works good. The problem only with this library.
This is the example but I didn't get to it - the errors pop up at the library compile time BulkMessages.ino (7.3 KB)
However, if doing what you suggest does what it implies then I can't see how the code could compile. It certainly doesn't compile if you comment out the #include for the library
