Problem with a network of 3 xbee !
Hi all , I have a network of 3 xbee , one of them is the coordinator and it's connected with arduino , what I want to do is to command each one of the 2 other xbee module ( digital output ) Individually without adding any other arduino . in other word , when I send a command for xbee 2 from xbee 1 , xbee 3 must ignore this information . I can do that by adding arduino but I am looking for a solution with only one arduino in the coordinator . Thank you
Configure the XBees to communicate in API mode. Each packet will be addressed to, and received by, only on XBee.
Thank you for your response , Do you have any tutorial for that ? thanks
nc56: Thank you for your response , Do you have any tutorial for that ? thanks
Try this.
