Problem with AC Light Dimmer module loop error even though it has an interrupt.
Hi! everyone. Can you please help with my code?
I'm using NodeMcu ESP8266 and AC Light Dimmer Module, 1 Channel, 3.3V/5V logic, AC 50/60hz, 220V/110V.
#include <RBDdimmer.h>//
//#define USE_SERIAL  SerialUSB //Serial for boards whith USB serial port
#define outputPin  12
#define zerocross  5 // for boards with CHANGEBLE input pins
dimmerLamp dimmer(outputPin, zerocross); //initialase port for dimmer for ESP8266, ESP32, Arduino due boards
//dimmerLamp dimmer(outputPin); //initialase port for dimmer for MEGA, Leonardo, UNO, Arduino M0, Arduino Zero
int outVal = 0;
volatile bool intfired=false;
  USE_SERIAL.begin(9600);
  pinMode(zerocross, INPUT_PULLUP);
  pinMode(outputPin, OUTPUT);
  attachInterrupt(digitalPinToInterrupt(zerocross), handleInterrupt, CHANGE);
  dimmer.begin(NORMAL_MODE, ON); //dimmer initialisation: name.begin(MODE, STATE)
  USE_SERIAL.println("Dimmer Program is starting...");
  USE_SERIAL.println("Set value");
void printSpace(int val)
  if ((val / 100) == 0) USE_SERIAL.print(" ");
  if ((val / 10) == 0) USE_SERIAL.print(" ");
ICACHE_RAM_ATTR void handleInterrupt() {
  intfired=true;
  int preVal = outVal;
  if (USE_SERIAL.available())
    int buf = USE_SERIAL.parseInt();
    if (buf != 0) outVal = buf;
    delay(200);
  dimmer.setPower(outVal); // setPower(0-100%);
  if (preVal != outVal)
    USE_SERIAL.print("lampValue -> ");
    printSpace(dimmer.getPower());
    USE_SERIAL.print(dimmer.getPower());
    USE_SERIAL.println("%");
  delay(50);
And, even though I put an "ICACHE_RAM_ATTR" or interrupt function. I still get these looping error.
load 0x4010f000, len 1392, room 16
tail 0
chksum 0xd0
csum 0xd0
v3d128e5c
~ld
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
I'm still new at this. That's why I'm having trouble with this kind of problem and even in the technical stuff in Arduino. Hope you can help me. Thanks in Advance.
Hi
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
http://forum.arduino.cc/index.php/topic,148850.0.html.
What AC Light Dimmer Module, 1 Channel, 3.3V/5V logic, AC 50/60hz, 220V/110V?
Can you post link to data/specs of the dimmer please?
Thanks.. Tom.. :slight_smile:
i don't see where "intfired" is used in your code other than being set in the interrupt.
i don't see where the "looping error" you posted are coming from in your code
