Problem with Adafruit 2.13" Tri-Color eInk / ePaper Display with SRAM
Hello,
I have a problem getting a Adafruit 2.13" Tri-Color eInk / ePaper Display with SRAM running.
I have connected the display as shown here:
I have installed the libraries and wanted t run the EPDtest (code shown below, I hope),
but nothing happens. Is there no SPI library and pin declaration needed?
regards
Helmut
EPDTest.ino (2.09 KB)
Here is the code:
#include "Adafruit_EPD.h"
#define EPD_CS 10
#define EPD_DC 9
#define SRAM_CS 8
#define EPD_RESET 5 // can set to -1 and share with microcontroller Reset!
#define EPD_BUSY 3 // can set to -1 to not use a pin (will wait a fixed delay)
Adafruit_IL0373 display(212, 104, EPD_DC, EPD_RESET, EPD_CS, SRAM_CS, EPD_BUSY);
#define FLEXIBLE_213 true
#define COLOR1 EPD_BLACK
#define COLOR2 EPD_RED
//while (!Serial) { delay(10); }
Serial.println("Adafruit EPD test");
display.begin();
#if defined(FLEXIBLE_213) || defined(FLEXIBLE_290)
// The flexible displays have different buffers and invert settings!
display.setBlackBuffer(1, false);
display.setColorBuffer(1, false);
#endif
// large block of text
display.clearBuffer();
testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", COLOR1);
display.display();
delay(5000);
for (int16_t i=0; i<display.width(); i+=4) {
display.drawLine(0, 0, i, display.height()-1, COLOR1);
for (int16_t i=0; i<display.height(); i+=4) {
display.drawLine(display.width()-1, 0, 0, i, COLOR2); // on grayscale this will be mid-gray
display.display();
//don't do anything!
void testdrawtext(char *text, uint16_t color) {
display.setCursor(0, 0);
display.setTextColor(color);
display.setTextWrap(true);
display.print(text);
Make links clickable with URL tags. Provide links to the product in question.
You might also read How to use this forum - please read.
Which is available through the first link in General Guidance and How to use the Forum
Some links for my use:
