Problem with Adafruit_ST7735
Hi to all
I hawe a problem compile one scatch
the problem is all time when I want to compile getting this error
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp: In member function 'void Adafruit_ST7735::commonInit(const uint8_t*)':
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:324: error: 'SPI' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:326: error: 'SPI_CLOCK_DIV4' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Adafruit_ST7735\Adafruit_ST7735.cpp:334: error: 'SPI_MODE0' was not declared in this scope
Where? We can't guess what your "scatch" looks like.
here is the code
//RTC CONNECTIONS
//Connect the RTC VCC to the Arduino +5 v
// RTC GND to the Arduino GND
// RTC SDA to the Arduino Analog Pin 4
// RTC SCL to the Arduino Analog Pin 5
// LCD DISPLAY CONNECTION
#define sclk 4 //connected to digital PIN 4
#define mosi 5 //connected to digital PIN 5
#define cs 6 //connected to digital PIN 6
#define dc 7 //connected to digital PIN 7
#define rst 8 //connected to digital PIN 8
// RELAY CONNECTION
// GND connected to Arduino GND
int Pin1 = 9; // IN1 connected to digital 9
int Pin2 = 10; // IN2 connected to digital 10
int Pin3 = 11; // IN3 connected to digital 11
int Pin4 = 12; // IN4 connected to digital 12
// VCC connected to Arduino +5v
//#include // Core graphics library
//#include // Hardware-specific library
//#include // library needed for RTC
#include <Adafruit_GFX.h>
#include <Wire.h>
#include <Adafruit_ST7735.h>
#include "RTClib.h" //RTC Library
RTC_DS1307 RTC;
Adafruit_ST7735 tft = Adafruit_ST7735(cs, dc, mosi, sclk, rst);
void setup(void) {
// DEFINING PINS FOR RELAY CONTROL
pinMode(Pin1, OUTPUT);
pinMode(Pin2, OUTPUT);
pinMode(Pin3, OUTPUT);
pinMode(Pin4, OUTPUT);
Wire.begin();
RTC.begin();
tft.initR(INITR_BLACKTAB); // initialize a ST7735S chip, black tab
tft.fillScreen(ST7735_BLACK); // Clear screen
digitalWrite(Pin1, 1 );
digitalWrite(Pin2, 1 );
digitalWrite(Pin3, 1 );
digitalWrite(Pin4, 1 );
tft.setCursor(0,50);
tft.println(" Waiting 10 seconds ");
tft.println(" for RTC to Sync ");
delay(10000);//wait for RTC to Respond, if not set time
if (! RTC.isrunning()) {
tft.println(" RTC was NOT running!");
tft.println(" Resetting RTC ");
// following line sets the RTC to the date & time this sketch was compiled
RTC.adjust(DateTime(DATE, TIME));
tft.setCursor(10,10);
tft.setTextColor(ST7735_WHITE);
tft.setTextSize(1);
tft.println("TIMER CONTROL");
tft.setTextColor(ST7735_YELLOW,ST7735_BLACK);//set text color & size for DATE coming from TinyRTC
tft.setTextSize(2);
tft.setCursor(5,30);
DateTime now = RTC.now(); //GRAB DATE AND TIME FROM RTC
tft.print(now.year(), DEC);
tft.print('/');
tft.print(now.month(), DEC);
tft.print('/');
tft.print(now.day(), DEC);
tft.println(' ');
tft.setCursor(15,70);
tft.setTextColor(ST7735_GREEN,ST7735_BLACK); //set color for TIME
tft.setTextSize(2);//set text size for TIME coming from TinyRTC
tft.print(now.hour(), DEC);
tft.print(':');
if(now.minute() < 10) { //PRINT A 0 IN FRONT OF THE MINUTE IF LESS THAN 10
tft.print('0');
tft.print(now.minute(), DEC);
else {
tft.print(':');
if(now.second() < 10) {//PRINT A 0 IN FRONT OF THE SECONDS IF LESS THAN 10
tft.print('0');
tft.print(now.second(), DEC);
else {
tft.println(" ");
// THIS IS THE DECISION MAKING PORTION OF THE SKETCH, THIS EXAMPLE IS A ONE MINUTE CYCLE
// FOR DEMO PURPOSES: IT TURNS ON RELAY 1 AT 10 SECONDS, THEN OFF AT 20
// IT THEN TURNS RELAY 2 AND 4 ON AT 40 SECONDS AND OFF AT 50,
// AT 50 SECONDS IT TURNS ON RELAY 1 AND 3 THEN OFF AT 0
if(now.second() == 10) {
tft.setCursor(0,100);
tft.setTextColor(ST7735_GREEN,ST7735_BLACK); //set color for TIME ON
tft.setTextSize(1);//set text size
tft.print("Relay 1 is on ");
digitalWrite(Pin1, 0);
if(now.second()== 20) {
tft.setTextColor(ST7735_RED,ST7735_BLACK); //set color for TIME ON
tft.print("Relay 1 is off ");
digitalWrite(Pin1, 1);
if(now.second()== 40){
digitalWrite(Pin1, LOW);
digitalWrite(Pin2, HIGH);
digitalWrite(Pin3, LOW);
digitalWrite(Pin4, HIGH);
tft.println("Relay 1 is on ");
tft.println("Relay 2 is off ");
tft.println("Relay 3 is on ");
tft.println("Relay 4 is off ");
if(now.second()== 50){
digitalWrite(Pin1, HIGH);
digitalWrite(Pin2, LOW);
digitalWrite(Pin3, HIGH);
digitalWrite(Pin4, LOW);
tft.println("Relay 1 is off ");
tft.println("Relay 2 is on ");
tft.println("Relay 3 is off ");
tft.println("Relay 4 is on ");
if(now.second()== 00){
You forgot to include the SPI library and setup the SPI functions.
Thanks
That is the only problem
