problem with adding limit switch function in this code
Hello, I am making automatic toy car have
HC-SR04 distance sensor (to sense my hand)
2 limit switch (one to reverse the motor, one to stop the motor)
so what I am tying to do is
  1. sense my hand
  2. Car moves back
  3. back limit switch hit the wall
  4. Car moves forward
  5. front limit switch hit the wall
  6. Car stops
Please use bottom link to see the picture
https://drive.google.com/file/d/0B2d99J14zOkrVDZneW92bUc5WlU/
#define trigPin 9
#define echoPin 8
#define led 11
#define led2 10
#define limswitch 12
#define limswitch2 13
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(led, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(2, OUTPUT); // this runs the motor front
pinMode(4, OUTPUT); // this runs the motor back
pinMode(12, OUTPUT);
long duration, distance;
digitalWrite(trigPin, LOW); // Added this line
delayMicroseconds(2); // Added this line
digitalWrite(trigPin, HIGH); // delayMicroseconds(1000); - Removed this line
delayMicroseconds(10); // Added this line
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) /29.1;
if (distance < 30) // This is where the LED On/Off happens
digitalWrite(led,HIGH); // When the Red condition is met, the Green LED should turn off
digitalWrite(led2,LOW);
digitalWrite(4,HIGH);
digitalWrite(2,LOW);
delay(2000);
digitalWrite(2,HIGH);
digitalWrite(4,LOW);
delay(2000);
digitalWrite(led,LOW);
digitalWrite(led2,HIGH);
if (distance >= 500 || distance <= 0)
Serial.println(“Out of range”);
Serial.print(distance);
Serial.println(" cm");
This code is letting me to run the motor back 2sec and forward 2sec when it sense the hand front of distance sensor.
How can I add limit switch function to this?
Change the [ quote ] tags to [ code ] and then maybe the gurus will read it. Without code tags, the forum software eats certain significant parts of your code which will prevent it from working.
While you're at it, define some names for your pins, so that it's obvious which digitalWrite() moves which motor.
One method would be to remove the delay(2000)s and replace them with a while loop that waits until the appropriate switch becomes pressed.
Really?
