problem with adding two sketches together
I am building a automatic watering system for a school project, and while adding two sketches together i ran into the "X does not name a type" error. I have now run into the problem that i have no experience in coding.
The first sketch is the automatic watering code that uses a soil moisture sensor, water level sensor, water pump and a LED.
#include "FastLED.h"
// These constants won't change. They're used to give names to the pins used:
const int ledPin = 2;                                             // Digital output pin that the LED is attached to
const int pumpPin = 12;                                           // Digital output pin that the water pump is attached to
const int waterLevelPin = A3;                                      // Analoge pin water level sensor is connected to
const int moistureSensorPin = 7;                                  // Digital input pin used to check the moisture level of the soil
// How many leds in your strip?
#define NUM_LEDS 6
#define DATA_PIN 5
//#define CLOCK_PIN 13
CRGB leds[NUM_LEDS];
// These are the values to edit - see the instructional video to find out what needs adjusting and why:
double checkInterval = 5;                                      //time to wait before checking the soil moisture level - default it to an hour = 1800000
int waterLevelThreshold = 180;                                    // threshold at which we flash the LED to warn you of a low water level in the pump tank - set this as per the video explains
int emptyReservoirTimer = 15;                                     // how long the LED will flash to tell us the water tank needs topping up - default it to 900 = 30mins
int amountToPump = 300;                                           // how long the pump should pump water for when the plant needs it
// Global temp values
int sensorWaterLevelValue = 0;                                      // somewhere to store the value read from the waterlevel sensor
int moistureSensorValue = 0;                                       //somewhere to store the value read from the soil moisture sensor
FastLED.addLeds<WS2812, DATA_PIN, RGB>(leds, NUM_LEDS);
pinMode(ledPin, OUTPUT);
pinMode(pumpPin, OUTPUT);
pinMode(moistureSensorPin, INPUT);
//flash the LED five times to confirm power on and operation of code:
for (int i = 0; i <= 4; i++) {
digitalWrite(ledPin, HIGH);
delay(300);
digitalWrite(ledPin, LOW);
delay(300);
delay(2000);
digitalWrite(ledPin, HIGH);                                   // turn the LED on
sensorWaterLevelValue = analogRead(waterLevelPin);              //read the value of the water level sensor
Serial.print("Water level sensor value: ");                     //print it to the serial monitor
Serial.println(sensorWaterLevelValue);
if (sensorWaterLevelValue < waterLevelThreshold) {              //check if we need to alert you to a low water level in the tank
  for (int i = 0; i <= emptyReservoirTimer; i++) {
else {
  delay(checkInterval);                                         //wait before checking the soil moisture level
// check soil moisture level
moistureSensorValue = digitalRead(moistureSensorPin);       //read the moisture sensor and save the value
Serial.print("Soil moisture sensor is currently: ");
Serial.print(moistureSensorValue);
Serial.println(" ('1' means soil is too dry and '0' means the soil is moist enough.)");
if (moistureSensorValue == 337) {
  //pulse the pump
  digitalWrite(pumpPin, HIGH);
  Serial.println("pump on");
  delay(amountToPump);                                      //keep pumping water
  digitalWrite(pumpPin, LOW);
  Serial.println("pump off");
  delay(800);                                              //delay to allow the moisture in the soil to spread through to the sensor
and the second sketch is a code to run a RGB LED strip.
#define NUM_LEDS 6
#define DATA_PIN 5
  for(int i=0; i<NUM_LEDS; i++){
      leds[i] = CHSV(160, 255, 128);
      FastLED.show();
      delay(400);
      leds[i] = CHSV(100,255,100);
      FastLED.show();
Sketch 2 is already partially inserted into sketch 1 but the "FastLED.addleds<ws2812, DATA_PIN, RGB>(leds, NUM_LEDS); line is where the compiler runs into the error 'Serial' does not name a type
I hope you can help.
Please Read this before posting a programming question then follow the instructions about using code tags and formatting your code and post your best effort at a combined sketch together with any error messages or a description of what is wrong with it
combining two or more code sources isn’t so easy for a beginner, but there are several references, one I wrote in Introductory Tutorials.
Posting the EXACT error message copied from the IDE instead of a paraphrase is useful.
But your initial problem is because you have a } ending setup() early so the Serial.begin and following code isn't in any function. You have more } (closing braces) than { (opening braces) and that never works out well.
Steve
The auto format tool (Ctrl t or Tools, Auto Format) of the IDE often will help you to see mismatched and misplaced curly brackets.
