Problem with adding ultrasonic sensor code with two direction of dc motor
Hello,
i am trying to add the third position (ultrasonic sensor ) to the two position of dc motor directions (Forward & Reverse), but it does not work .Since the position 1&2 worked together and ultrasonic code worked alone.
here is my code for (forward direction & Ultrasonic sensor) only:
// defines pins numbers
const int trigPin = 6;
const int echoPin = 5;
// defines variables
long duration ;
int distance;
int SPEED; // speed of motor
int switchPos3 = 4; // pin for position 3
int switchPos1 = 2; // pin for position 1
int ENA = 8; // enable pin for L298n H bridge motor driver
int In1 = 9; // input pin for L298n H bridge motor driver
int In2 = 7; // input pin for L298n H bridge motor driver
int potval =A0;// analog pin for potentiometer
// variable will change
int switchState1 = 0;
int switchState3=0;
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
Serial.begin(9600); // Starts the serial communication
pinMode (switchPos3, INPUT);
pinMode (switchPos1, INPUT);
pinMode(In1, OUTPUT);
pinMode (In2, OUTPUT);
pinMode(ENA, OUTPUT);
void posOne()
switchState1 = digitalRead (switchPos1); // read the switch pin
if ( switchState1 == HIGH )
SPEED = analogRead(A0); // Read potentiometer value
SPEED = SPEED * 0.249;
Serial.println(SPEED);
digitalWrite (In1, HIGH); // forward direction set pin states HIGH
digitalWrite (In2, LOW); // forward direction set pin states LOW
digitalWrite (ENA, HIGH); // forward direction set pin states HIGH
Serial.println("Position 1 = on "); // print to serial monitor
// Serial.print("Position1: "); // print to serial monitor
else {
//Serial.println("off");
digitalWrite (In2, LOW); // off
digitalWrite (In1, LOW); // off
digitalWrite (ENA, LOW); // off
void posThree(){
switchState3 = digitalRead (switchPos3); // read the switch pin
if ( switchState3 == HIGH )
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance= duration*0.034/2;
//Prints the distance on the Serial Monitor
Serial.print("Distance: ");
Serial.println(distance);
if (distance >=5 && distance <=30)
analogWrite(ENA,SPEED); // Send PWM signal to L298N Enable pin
digitalWrite (In1,LOW ); // forward direction set pin states HIGH
digitalWrite (In2, HIGH); // forward direction set pin states LOW
else {
digitalWrite (ENA,LOW); // off
posThree();
posOne();
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :slight_smile:
mgbanah:
Not a very helpful description of the problem. Does the program do anything? What exactly? What did you expect it to do that's different? What do all your Serial.prints show you is happening?
Steve
Actually, I am using a 4 position selector switch to control dc motor in three modes:
Position 1 (forward direction), position 2 (reverse direction) ,and position 3 backup assist (ultrasonic sensor). When I upload code for position 1&2 together the dc motor will work for two position.Then , I ran the code for position 3 (ultrasonic sensor) by itself. The problem is when I add position 3 to 1&2 , it just work for position 1 &2 and there is no action for position 3. Here are my circuit & code.
 for position 1&2
    int switchPos2 = 4; // pin for position 2
    int led1 =12; // input for headlight
    int led2 =13; // input for taillight
    int SPEED ;  // speed of motor
    // variable will chaange
      int switchState2 = 0;
   Serial.begin (9600); // Arduino to begin serial communication
    //set inputs
  pinMode (switchPos2, INPUT);
 // set outputs
  pinMode (led1,OUTPUT);
void posOne()
          digitalWrite (led1,HIGH);   // headlight HIGH
 else {
     digitalWrite (led1,LOW);   // off
    // digitalWrite (ENA, LOW);    // off
      void posTwo(){
       switchState2 = digitalRead (switchPos2);
     if ( switchState2 == HIGH)
        analogWrite(ENA, SPEED); // Send PWM signal to L298N Enable pin
      digitalWrite (led2,HIGH);    //taillight HIGH
      digitalWrite (In1, LOW);     // reverse  direction set pin states  LOW
      digitalWrite (In2, HIGH);   // reverse  direction  set pin states  HIGH
      digitalWrite (ENA, HIGH); // reverse  direction  set pin states  HIGH
      Serial.println("Position 2 = on");        // print  to serial monitor
      //Serial.print("Position2: ");  // print  to serial monitor
     Serial.println("off");    // print  to serial monitor
      digitalWrite (led2,LOW);   // off
      digitalWrite (In2, LOW);  //off
       //digitalWrite (ENA, LOW);  // off
          posOne();
        posTwo();
 for position3
long duration ;
int distance;
 int switchPos3 = 4; // pin for position 1
   int switchState3=0;
if (distance >=5 )//&& distance <=30)
  else {
int switchPos3 = 10; // pin for position 3
You've just posted the bits of code that work. How is that going to help us tell what is wrong with your combined code that doesn't work?
POST THE COMPLETE CODE WITH ALL 3 FUNCTIONS IN ONE PROGRAM!
Also according to your Fritzy thing you have pull-up resistors on the switch...so all 3 outputs are going to be permanently HIGH. I don't think you mean that.
Steve
Thanks, I figured it out
mgbanah:
What was the solution?
Tom.... :slight_smile:
