Problem with Alarm with RTC
Hi Guys ,
I'm developing a program (with helping in Forum) to alarm two led with RTC from (min:second) to (min:second) with Serial Monitor but I succeeded only to do that for one led.
when I write the code for twice, the first led turns off and the other receive the command ...
briefly ... Two led don't set together
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
int start_minute;
int start_second;
int end_minute;
int end_second;
int type;
  Wire.begin();
  RTC.begin();
  if (! RTC.isrunning())
    Serial.println("RTC is NOT running!");
  //Any pin. I have used Pin 4
  pinMode(12, OUTPUT);
  DateTime now = RTC.now();
  Serial.print(now.year(), DEC);
  Serial.print('/');
  Serial.print(now.month(), DEC);
  Serial.print('/');
  Serial.print(now.day(), DEC);
  Serial.print(" (");
  Serial.print(now.hour(), DEC);
  Serial.print(':');
  Serial.print(now.minute(), DEC);
  Serial.print(':');
  Serial.print(now.second(), DEC);
  int second_of_the_hour = now.minute() * 60 + now.second();
  //The time is set as 24 hours
  //Pin 4 get high at 6pm and low at 6am
  if (Serial.available() > 0)
    type = Serial.parseInt
    start_minute = Serial.parseInt();
    start_second = Serial.parseInt();
    end_minute = Serial.parseInt();
    end_second = Serial.parseInt();
  int start_time = start_minute * 60 + start_second;
  int end_time =  end_minute * 60 + end_second;
  if (type =5 && second_of_the_hour >= start_time &&  second_of_the_hour < end_time)
    if (!digitalRead(12))
      digitalWrite(12, HIGH);
      Serial.println("ON");
  else if (digitalRead(12))
    digitalWrite(12, LOW);
    Serial.println("OFF");
    if (type =6 && second_of_the_hour >= start_time &&  second_of_the_hour < end_time)
    if (!digitalRead(8))
      digitalWrite(8, HIGH);
  else if (digitalRead(8))
    digitalWrite(8, LOW);
Thanks
4 != 12.
If you expect to have 2 LEDs connected, you need 2 output pins.
  if (type =5
Why are you assigning 5 to type in an if statement?
PaulS:
4 != 12.
sorry that is small mistake .. I write it well in code.
if (type =5
I typed it to set led 12 ON
example : 5,43,12,45,6 .. turn on led 12 from (43:12) to (45:6)
and 6 for led 8 ..
The man said "assigning", not "testing"... :slight_smile:
You need to read up on the various operators. The = operator and the == operator do very different things, and are used in very different ways.
Thanks for Replaying ...
I did that but the Result is the same ...
Led 12 set perfectly .. If I set led 8 from Serial Monitor ..led 12 turns off and led 8 set ...
It's time to post your updated code with all the changes.
my last code :frowning:
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
int start_minute;
int start_second;
int end_minute;
int end_second;
int type;
  Wire.begin();
  RTC.begin();
  pinMode (8, OUTPUT);
  Serial.print('/');
  Serial.print('/');
  Serial.print(" (");
  Serial.print(':');
  Serial.print(':');
    type = Serial.parseInt();
  if (type == 5 && second_of_the_hour >= start_time &&  second_of_the_hour < end_time)
  if (type == 6 && second_of_the_hour >= start_time &&  second_of_the_hour < end_time)
What are you calculating for start_time and end_time? Are the values reasonable?
What IS in type?
Without all the time handling stuff, can you turn the LEDs off and on properly?
Still with the stupid comment, I see. Why? What value does the comment add?
PaulS:
start_time and end_time the time which the led turn on and off in seconds .
What IS in type?
type is the led type (12 or 8 pin)
I can with one led only .. not twice together ..
it's a copy from other code .. sorry ..don't give attention to it ..
Thanks for your helping and patience .
That what I mean ...
It works only for led 12 when I type "5"
and works only for led 8 when I type "6"
I can't make them work together (every led) with its time ..
You have not added any more Serial.print() statements, to show that type, start_minute, start_second, end_minute, and end_second contain valid values. Why not?
You haven't proven that start_time and end_time contain valid values. Why not?
I want just ... two if statements work together
No. You just want to whine.
Put the required Serial.print() statements in your code, or do NOT reply again.
