I have an I2C LCD connected to an Arduino Uno. I have downloaded and use a library which also had a example code.
The first problem is that although the LCD displays the text it is dark. I need to illuminate the LCD with a bright light source in order to see the text. In all other vLCD I have used this was not a problem. Seem to be issue with backlight. The code controlling backlight has no effect on the display
Second problem. There are never any serial available in the loop
/* YourDuino.com Example Software Sketch
20 character 4 line I2C Display
Backpack Interface labelled "YwRobot Arduino LCM1602 IIC V1"
Connect Vcc and Ground, SDA to A4, SCL to A5 on Arduino
terry@yourduino.com */
/*-----( Import needed libraries )-----*/
#include <LiquidCrystal_SR3W.h>
#include <LiquidCrystal_SR2W.h>
#include <LiquidCrystal_SR.h>
#include <LiquidCrystal.h>
#include <LCD.h>
#include <I2CIO.h>
#include <FastIO.h>
#include <Wire.h> // Comes with Arduino IDE
// Get the LCD I2C Library here:
// https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
// Move any other LCD libraries to another folder or delete them
// See Library "Docs" folder for possible commands etc.
/*-----( Declare Constants )-----*/
/*-----( Declare objects )-----*/
// set the LCD address to 0x27 for a 20 chars 4 line display
// Set the pins on the I2C chip used for LCD connections:
// addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
/*-----( Declare Variables )-----*/
void setup() /*----( SETUP: RUNS ONCE )----*/
Serial.begin(9600); // Used to type in characters
lcd.begin(20, 4); // initialize the lcd for 20 chars 4 lines, turn on backlight
// ------- Quick 3 blinks of backlight -------------
for (int i = 0; i< 3; i++)
lcd.backlight();
delay(250);
lcd.noBacklight();
delay(250);
lcd.backlight(); // finish with backlight on
//-------- Write characters on the display ------------------
// NOTE: Cursor Position: Lines and Characters start at 0
lcd.setCursor(3, 0); //Start at character 4 on line 0
lcd.print("Hello, world!");
lcd.setCursor(2, 1);
lcd.print("From YourDuino");
lcd.setCursor(0, 2);
lcd.print("20 by 4 Line Display");
lcd.setCursor(0, 3);
delay(2000);
lcd.print("http://YourDuino.com");
delay(8000);
// Wait and then tell user they can start the Serial Monitor and type in characters to
// Display. (Set Serial Monitor option to "No Line Ending")
lcd.setCursor(0, 0); //Start at character 0 on line 0
lcd.print("Start Serial Monitor");
lcd.setCursor(0, 1);
lcd.print("Type chars 2 display");
Serial.println("LOOP");
}/*--(end setup )---*/
void loop() /*----( LOOP: RUNS CONSTANTLY )----*/
// when characters arrive over the serial port...
lcd.backlight();
if (Serial.available())
// wait a bit for the entire message to arrive
delay(100);
// clear the screen
lcd.clear();
// read all the available characters
while (Serial.available() > 0)
// display each character to the LCD
lcd.write(Serial.read());
}/* --(end main loop )-- */
/* ( THE END ) */
