Hello,
I wrote this sketch ( autocorelation code comes from an instructable) because I need to calculate audio input signals frequencies "non-stop". So I use the ISR(ADC_vect) (known as conversion complete interrupt) to fill-up th array "rawData". When it's full, the arduino launchs the autocorelation to calculate the signal period and then I it determines its frequency and during that time I disable all interrupts. Next, I re-enable interrupts and the array is re-filled with news incoming datas (the array is refreshed).
BUT it doesn't work ! The arduino calculate the frequency once and it never refresh the array or I don't known why but if I change the signal's frequency nothing happens. My LCD is freezed...
I tested my sketch on Proteus only...do you believe that the "error" comes from me or from Proteus ?
If I comment the lines where I disabled and then re-enable interrupts it works but it gives unwanted interrupts which...interrupts the program every 26µs (the sample rate period)...
//Algo d'autocorrelation tiré d'un instructable : http://www.instructables.com/id/Reliable-Frequency-Detection-Using-DSP-Techniques/
#include <LiquidCrystal.h>;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
/************Variables*****************/
////Variables relatives à la copie du signal
const int nbData = 800; // nombres d'échantillons du signal
char rawData[nbData] = {}; //tableau de stockage de la copie du signal
volatile unsigned int index = 0;
float frequency = 0;//variable pour stockage de la frequence mesurée
/*******Pour l'autocorrelation *************/
float sample_freq = 38461.54;//fréquence d'échantillonnage en Hz, 1 conversion toutes les 52µs
lcd.begin(16,2);
cli();
ADCSRA = 0;//initialisation des registres ADCSRA et ADCSRB pour le CAN
ADCSRB = 0;
//mettre le voltage de référence
//Alignement à gauche des bits -> resultat de la conversion dans registre ADCH
ADMUX |= 0x60;
//parametrage des prédiviseurs d'horloge pour le CAN à un prediviseur de 64 - 16mHz/64=250kHz = f_horlogeCAN
//active le déclenchement automatique en gros dès que la CAN précédente est finie, on en recommnce direct une autre
//active l'interruption quand toutes les mesures sont faites
//autorise la conversion
ADCSRA |= (1<<ADEN) | (1<<ADATE) | (1<<ADIE) | (1<<ADPS0) | (1<<ADPS2);
ADCSRA |= (1<<ADSC);//démarre la conversion (starts the ADC measurment)
sei();
ISR(ADC_vect){//éxecute le code à chaque fin de conversion A/N
if(index < nbData){//Si on a pas encore rempli un taleau de 800 échantillons
rawData[index] = ADCH;//mettre la tension mesurée dans le tableau
++ index;
void loop(){
if(index == nbData){// si j'ai mes 400 valeurs
//uint8_t saveSREG = SREG; //copie du registre pour pouvoir le restaurer après avoir traité l'admf
cli(); //désactiver toute interruption
frequency = runAutocorrelation();
lcd.setCursor(0,0);
lcd.print(frequency);
index = 0;
sei();
//SREG = saveSREG; //restaurer le SREG et re autoriser les interruptions
////////////////////////////////////// Autocorrelation /////////////////////////////////////////////////
float runAutocorrelation(){
int i,k;//compteurs
long sum, sum_old;//résultats de correlation
float thresh = 0;
int period = 0;
byte pd_state = 0;
float freq_per = 0;
sum = 0;
pd_state = 0;
// Autocorrelation
for(i=0; i < nbData; i++)
sum_old = sum;
sum = 0;
for(k=0; k < nbData-i; k++) sum += (rawData[k])*(rawData[k+i])/256;
// Peak Detect State Machine
if (pd_state == 2 && (sum-sum_old) <=0)
period = i-1;//à l'origine c'etait juste period = i mais c'est plus precis comme ça...
pd_state = 3;
if (pd_state == 1 && (sum > thresh) && (sum-sum_old) > 0) pd_state = 2;
if (!i) {
thresh = sum * 0.5;
pd_state = 1;
// Frequence mesurée en Hz
freq_per = sample_freq/period;
return freq_per;
I'm sorry for my bad english...I'm a french student
Hugo
