hi,
I am looking for some advice on this program I am having a problem with.
The simulation is for a food blender. Ie one start switch to switch the system on and off. The switch should allow any of the three different speed selector switches, slow, medium and fast to operate only if the on/off switch is on and not to work if the on/off switch is off.
The on/off switch is input 2. The three speeds are inputs 3,4 and 5
The answer seems obvious, but for some reason it's puzzling me.
Many thanks
Derek
course assignment - household appliance
int MOTOR = 9; // the pin for the MOTOR
pinMode(MOTOR,OUTPUT); // tell Arduino MOTOR is an output
pinMode(2, INPUT);
pinMode(3, INPUT);
pinMode(4, INPUT);
pinMode(5, INPUT);
if (digitalRead (3)== HIGH) // if switch is pressed then jump to next line and switch on motor
analogWrite(MOTOR, 50); // Sets the PWM mark:space ratio speed LOW.
while(!digitalRead(3)== HIGH)
delay(10); // do nothing, just delay a very tiny amount
else if (digitalRead (4)== HIGH) // if switch is pressed then jump to next line and switch on motor
analogWrite(MOTOR, 127); // Sets the PWM mark:space ratio speed MEDIUM.
while(!digitalRead(4)== HIGH)
else if (digitalRead (5)== HIGH) // if switch is pressed then jump to next line and switch on motor
analogWrite(MOTOR, 255); // Sets the PWM mark:space ratio speed HIGH.
while(!digitalRead(5)== HIGH)
digitalWrite(MOTOR, LOW);
