Problem with "APDS-9960 RGB and Gesture Sensor" interface
Hi, I am working on gesture recognition sensor interface. I get communication error, and the error code is 2.
here is my code (Sample code in Arduino IDE).
#include <Wire.h>
#include “paj7620.h”
Notice: When you want to recognize the Forward/Backward gestures, your gestures’ reaction time must less than GES_ENTRY_TIME(0.8s).
You also can adjust the reaction time according to the actual circumstance.
#define GES_REACTION_TIME 500 // You can adjust the reaction time according to the actual circumstance.
#define GES_ENTRY_TIME 800 // When you want to recognize the Forward/Backward gestures, your gestures’ reaction time must less than GES_ENTRY_TIME(0.8s).
#define GES_QUIT_TIME 1000
uint8_t error = 0;
Serial.println("\nPAJ7620U2 TEST DEMO: Recognize 9 gestures.");
error = paj7620Init(); // initialize Paj7620 registers
if (error)
Serial.print(“INIT ERROR,CODE:”);
Serial.println(error);
Serial.println(“INIT OK”);
Serial.println(“Please input your gestures:\n”);
uint8_t data = 0, data1 = 0, error;
error = paj7620ReadReg(0x43, 1, &data); // Read Bank_0_Reg_0x43/0x44 for gesture result.
if (!error)
switch (data) // When different gestures be detected, the variable ‘data’ will be set to different values by paj7620ReadReg(0x43, 1, &data).
case GES_RIGHT_FLAG:
delay(GES_ENTRY_TIME);
if(data == GES_FORWARD_FLAG)
Serial.println(“Forward”);
delay(GES_QUIT_TIME);
else if(data == GES_BACKWARD_FLAG)
Serial.println(“Backward”);
Serial.println(“Right”);
case GES_LEFT_FLAG:
Serial.println(“Left”);
case GES_UP_FLAG:
Serial.println(“Up”);
case GES_DOWN_FLAG:
Serial.println(“Down”);
case GES_FORWARD_FLAG:
case GES_BACKWARD_FLAG:
case GES_CLOCKWISE_FLAG:
Serial.println(“Clockwise”);
case GES_COUNT_CLOCKWISE_FLAG:
Serial.println(“anti-clockwise”);
default:
paj7620ReadReg(0x44, 1, &data1);
if (data1 == GES_WAVE_FLAG)
Serial.println(“wave”);
delay(100);
What can be wrong ? The module failure or I2c needs external pullup or any other communication problem ? Please suggest.
Hello there!
I’ve had a good deal of experience with this sensor. And I have gotten similar errors. Can you make sure that all of the power and ground pins to the sensor are correctly wired and that the ground for the sensor and whatever Arduino you are using?
While you’re at it. Can you post a picture of your schematic with all wiring as it can help solve problems.
Thanks
Hello there,
https://www.dx.com/p/produino-gy-apds9900-llc-apds-9900-rgb-and-gesture-sensor-module-i2c-breakout-for-arduino-2022955#.XCxBD2t95hF
This is the module, I am using.
Connected 4 pins to arduino Uno board.
Sensor side Arduino side
Vin - 3.3 V Gnd - Gnd SDA - SDA SCL - SCL
pull up resistors are not connected.
Sorry for the delay.
I see from the pictures in the link you posted that there is a 10k resistor array, and the SDA and SCL pins appear to be going to that and to the supply, which means those are the pull up resistors. It also means that unless you have pull-ups on the Uno, the interface itself should be working.
Is the code you posted the entire segment. There appears to be a function called paj7620Init() that is called at the beginning. This is most likely where the error shows up. Can you post the code of that function?
Thank you for your response.
As far as I know, paj7620Init() is an API that is used for register initialization, same as Serial.begin(9600) to initiate serial communication. It has to get handled internally.
And, You are correct, that is the function returns the transmission error.
britto: As far as I know, paj7620Init() is an API that is used for register initialization, same as Serial.begin(9600) to initiate serial communication. It has to get handled internally.
So by this do you mean that the code for this function cannot be seen? When you include the library, you are using quotation marks instead of carrots, which indicate that the code is in the same work directory as the .ino file. Can you post that code?
  • paj7620.cpp
  • A library for Grove-Guesture 1.0
  • Copyright (c) 2015 seeed technology inc.
  • Website : www.seeed.cc
  • Author : Wuruibin & Xiangnan
  • Modified Time: June 2015
  • The MIT License (MIT)
  • Permission is hereby granted, free of charge, to any person obtaining a copy
  • of this software and associated documentation files (the “Software”), to deal
  • in the Software without restriction, including without limitation the rights
  • to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
  • copies of the Software, and to permit persons to whom the Software is
  • furnished to do so, subject to the following conditions:
  • The above copyright notice and this permission notice shall be included in
  • all copies or substantial portions of the Software.
  • THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
  • IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
  • FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
  • AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
  • LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
  • OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
  • THE SOFTWARE.
#include <Wire.h>
#include <Arduino.h>
// PAJ7620U2_20140305.asc
/* Registers’ initialization data */
unsigned char initRegisterArray[2] = { // Initial Gesture
{0xEF,0x00},
{0x32,0x29},
{0x33,0x01},
{0x34,0x00},
{0x35,0x01},
{0x36,0x00},
{0x37,0x07},
{0x38,0x17},
{0x39,0x06},
{0x3A,0x12},
{0x3F,0x00},
{0x40,0x02},
{0x41,0xFF},
{0x42,0x01},
{0x46,0x2D},
{0x47,0x0F},
{0x48,0x3C},
{0x49,0x00},
{0x4A,0x1E},
{0x4B,0x00},
{0x4C,0x20},
{0x4D,0x00},
{0x4E,0x1A},
{0x4F,0x14},
{0x50,0x00},
{0x51,0x10},
{0x52,0x00},
{0x5C,0x02},
{0x5D,0x00},
{0x5E,0x10},
{0x5F,0x3F},
{0x60,0x27},
{0x61,0x28},
{0x62,0x00},
{0x63,0x03},
{0x64,0xF7},
{0x65,0x03},
{0x66,0xD9},
{0x67,0x03},
{0x68,0x01},
{0x69,0xC8},
{0x6A,0x40},
{0x6D,0x04},
{0x6E,0x00},
{0x6F,0x00},
{0x70,0x80},
{0x71,0x00},
{0x72,0x00},
{0x73,0x00},
{0x74,0xF0},
{0x75,0x00},
{0x80,0x42},
{0x81,0x44},
{0x82,0x04},
{0x83,0x20},
{0x84,0x20},
{0x85,0x00},
{0x86,0x10},
{0x87,0x00},
{0x88,0x05},
{0x89,0x18},
{0x8A,0x10},
{0x8B,0x01},
{0x8C,0x37},
{0x8D,0x00},
{0x8E,0xF0},
{0x8F,0x81},
{0x90,0x06},
{0x91,0x06},
{0x92,0x1E},
{0x93,0x0D},
{0x94,0x0A},
{0x95,0x0A},
{0x96,0x0C},
{0x97,0x05},
{0x98,0x0A},
{0x99,0x41},
{0x9A,0x14},
{0x9B,0x0A},
{0x9C,0x3F},
{0x9D,0x33},
{0x9E,0xAE},
{0x9F,0xF9},
{0xA0,0x48},
{0xA1,0x13},
{0xA2,0x10},
{0xA3,0x08},
{0xA4,0x30},
{0xA5,0x19},
{0xA6,0x10},
{0xA7,0x08},
{0xA8,0x24},
{0xA9,0x04},
{0xAA,0x1E},
{0xAB,0x1E},
{0xCC,0x19},
{0xCD,0x0B},
{0xCE,0x13},
{0xCF,0x64},
{0xD0,0x21},
{0xD1,0x0F},
{0xD2,0x88},
{0xE0,0x01},
{0xE1,0x04},
{0xE2,0x41},
{0xE3,0xD6},
{0xE4,0x00},
{0xE5,0x0C},
{0xE6,0x0A},
{0xE7,0x00},
{0xE8,0x00},
{0xE9,0x00},
{0xEE,0x07},
{0xEF,0x01},
{0x00,0x1E},
{0x01,0x1E},
{0x02,0x0F},
{0x03,0x10},
{0x04,0x02},
{0x05,0x00},
{0x06,0xB0},
{0x07,0x04},
{0x08,0x0D},
{0x09,0x0E},
{0x0A,0x9C},
{0x0B,0x04},
{0x0C,0x05},
{0x0D,0x0F},
{0x0E,0x02},
{0x0F,0x12},
{0x10,0x02},
{0x11,0x02},
{0x12,0x00},
{0x13,0x01},
{0x14,0x05},
{0x15,0x07},
{0x16,0x05},
{0x17,0x07},
{0x18,0x01},
{0x19,0x04},
{0x1A,0x05},
{0x1B,0x0C},
{0x1C,0x2A},
{0x1D,0x01},
{0x1E,0x00},
{0x21,0x00},
{0x22,0x00},
{0x23,0x00},
{0x25,0x01},
{0x26,0x00},
{0x27,0x39},
{0x28,0x7F},
{0x29,0x08},
{0x30,0x03},
{0x31,0x00},
{0x32,0x1A},
{0x33,0x1A},
{0x34,0x07},
{0x35,0x07},
{0x36,0x01},
{0x37,0xFF},
{0x38,0x36},
{0x39,0x07},
{0x3A,0x00},
{0x3E,0xFF},
{0x3F,0x00},
{0x40,0x77},
{0x41,0x40},
{0x42,0x00},
{0x43,0x30},
{0x44,0xA0},
{0x45,0x5C},
{0x46,0x00},
{0x47,0x00},
{0x48,0x58},
{0x4A,0x1E},
{0x4B,0x1E},
{0x4C,0x00},
{0x4D,0x00},
{0x4E,0xA0},
{0x4F,0x80},
{0x50,0x00},
{0x51,0x00},
{0x52,0x00},
{0x53,0x00},
{0x54,0x00},
{0x57,0x80},
{0x59,0x10},
{0x5A,0x08},
{0x5B,0x94},
{0x5C,0xE8},
{0x5D,0x08},
{0x5E,0x3D},
{0x5F,0x99},
{0x60,0x45},
{0x61,0x40},
{0x63,0x2D},
{0x64,0x02},
{0x65,0x96},
{0x66,0x00},
{0x67,0x97},
{0x68,0x01},
{0x69,0xCD},
{0x6A,0x01},
{0x6B,0xB0},
{0x6C,0x04},
{0x6D,0x2C},
{0x6E,0x01},
{0x6F,0x32},
{0x71,0x00},
{0x72,0x01},
{0x73,0x35},
{0x74,0x00},
{0x75,0x33},
{0x76,0x31},
{0x77,0x01},
{0x7C,0x84},
{0x7D,0x03},
{0x7E,0x01},
  • Function Name: paj7620WriteReg
  • Description: PAJ7620 Write reg cmd
  • Parameters: addr:reg address; cmd:function data
  • Return: error code; success: return 0
    uint8_t paj7620WriteReg(uint8_t addr, uint8_t cmd)
    char i = 1;
    Wire.beginTransmission(PAJ7620_ID); // start transmission to device
    //write cmd
    Wire.write(addr); // send register address
    Wire.write(cmd); // send value to write
    i = Wire.endTransmission(); // end transmission
    if(0 != i)
    Serial.print(“Transmission error!!!\n”);
    return i;
  • Function Name: paj7620ReadReg
  • Description: PAJ7620 read reg data
  • qty:number of data to read, addr continuously increase;
  • data:storage memory start address
    uint8_t paj7620ReadReg(uint8_t addr, uint8_t qty, uint8_t data)
    uint8_t error;
    Wire.write(addr);
    error = Wire.endTransmission();
if(0 != error)
return error; //return error code
Wire.requestFrom((int)PAJ7620_ID, (int)qty);
while (Wire.available())
*data = Wire.read();
#ifdef debug //debug
Serial.print(“addr:”);
Serial.print(addr++, HEX);
Serial.print(" data:");
Serial.println(*data, HEX);
#endif
data++;
return 0;
  • Function Name: paj7620SelectBank
  • Description: PAJ7620 select register bank
  • Parameters: BANK0, BANK1
  • Return: none
    void paj7620SelectBank(bank_e bank)
    switch(bank){
    case BANK0:
    paj7620WriteReg(PAJ7620_REGITER_BANK_SEL, PAJ7620_BANK0);
    case BANK1:
    paj7620WriteReg(PAJ7620_REGITER_BANK_SEL, PAJ7620_BANK1);
    default:
  • Function Name: paj7620Init
  • Description: PAJ7620 REG INIT
  • Parameters: none
    uint8_t paj7620Init(void)
    //Near_normal_mode_V5_6.15mm_121017 for 940nm
    int i = 0;
    uint8_t error;
    uint8_t data0 = 0, data1 = 0;
    //wakeup the sensor
    delayMicroseconds(700); //Wait 700us for PAJ7620U2 to stabilize
Wire.begin(5,4);
Serial.println(“INIT SENSOR…”);
paj7620SelectBank(BANK0);
error = paj7620ReadReg(0, 1, &data0);
if (error)
return error;
error = paj7620ReadReg(1, 1, &data1);
if (error)
return error;
Serial.print(“Addr0 =”);
Serial.print(data0 , HEX);
Serial.print(", Addr1 =");
Serial.println(data1 , HEX);
if ( (data0 != 0x20 ) || (data1 != 0x76) )
return 0xff;
if ( data0 == 0x20 )
Serial.println(“wake-up finish.”);
for (i = 0; i < INIT_REG_ARRAY_SIZE; i++)
paj7620WriteReg(initRegisterArray_[0], initRegisterArray*[1]);_
_
}*_
* paj7620SelectBank(BANK0); //gesture flage reg in Bank0*
* Serial.println(“Paj7620 initialize register finished.”);*
* return 0;*
