After instalation i cant started Arduino IDE
log from cmd:
Microsoft Windows [Version 10.0.19045.4046]
(c) Microsoft Corporation. Wszelkie prawa zastrzeżone.
C:\Users\piotr>cd C:\Program Files\Arduino IDE
C:\Program Files\Arduino IDE>"Arduino IDE.exe"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 79484
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/piotr/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-03-24T13:55:35.926Z root INFO Backend Object.initialize: 9.4 ms [Finished 1.049 s after backend start]
2024-03-24T13:55:35.927Z root INFO Backend Object.configure: 7.6 ms [Finished 1.049 s after backend start]
2024-03-24T13:55:35.927Z root INFO Backend s.onStart: 4.0 ms [Finished 1.049 s after backend start]
2024-03-24T13:55:35.929Z root INFO Backend s.configure: 0.7 ms [Finished 1.099 s after backend start]
2024-03-24T13:55:35.931Z root INFO Backend d.onStart: 0.4 ms [Finished 1.099 s after backend start]
2024-03-24T13:55:35.933Z root INFO Backend d.configure: 0.2 ms [Finished 1.099 s after backend start]
2024-03-24T13:55:35.935Z root INFO Backend d.initialize: 49.8 ms [Finished 1.100 s after backend start]
2024-03-24T13:55:35.935Z root INFO Backend c.onStart: 0.5 ms [Finished 1.100 s after backend start]
2024-03-24T13:55:35.937Z root INFO Backend a.configure: 2.3 ms [Finished 1.102 s after backend start]
2024-03-24T13:55:35.941Z config INFO >>> Initializing CLI configuration...
2024-03-24T13:55:35.941Z root INFO Backend c.initialize: 1.2 ms [Finished 1.103 s after backend start]
2024-03-24T13:55:35.942Z root INFO Backend R.onStart: 2.0 ms [Finished 1.104 s after backend start]
2024-03-24T13:55:35.944Z config INFO Loading CLI configuration from c:\Users\piotr\.arduinoIDE\arduino-cli.yaml...
2024-03-24T13:55:35.945Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:35.945Z root INFO Backend a.initialize: 1.3 ms [Finished 1.107 s after backend start]
2024-03-24T13:55:35.945Z root INFO Backend w.onStart: 3.4 ms [Finished 1.109 s after backend start]
2024-03-24T13:55:35.945Z root INFO Backend r.configure: 5.3 ms [Finished 1.110 s after backend start]
2024-03-24T13:55:35.945Z discovery-log INFO start
2024-03-24T13:55:35.945Z discovery-log INFO start new deferred
2024-03-24T13:55:35.945Z root INFO Backend d.initialize: 1.4 ms [Finished 1.111 s after backend start]
2024-03-24T13:55:35.945Z root INFO Backend y.onStart: 5.4 ms [Finished 1.115 s after backend start]
2024-03-24T13:55:35.945Z root INFO Backend r.configure: 4.3 ms [Finished 1.116 s after backend start]
2024-03-24T13:55:35.946Z root INFO Backend a.onStart: 1.2 ms [Finished 1.119 s after backend start]
2024-03-24T13:55:35.946Z root INFO Backend h.configure: 1.0 ms [Finished 1.119 s after backend start]
2024-03-24T13:55:35.946Z root INFO Backend s.configure: 0.3 ms [Finished 1.120 s after backend start]
2024-03-24T13:55:35.946Z root INFO Backend l.configure: 0.2 ms [Finished 1.120 s after backend start]
2024-03-24T13:55:35.953Z root INFO Theia app listening on http://127.0.0.1:56439.
2024-03-24T13:55:35.953Z root INFO Finished starting backend application: 7.8 ms [Finished 1.127 s after backend start]
2024-03-24T13:55:35.968Z root WARN The local plugin referenced by local-dir:/c%3A/Users/piotr/.arduinoIDE/plugins does not exist.
2024-03-24T13:55:35.968Z root WARN The local plugin referenced by local-dir:/c%3A/Users/piotr/.arduinoIDE/extensions does not exist.
2024-03-24T13:55:35.969Z root WARN The local plugin referenced by local-dir:C:\Users\piotr\.arduinoIDE\plugins does not exist.
2024-03-24T13:55:35.989Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\piotr\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\piotr\\AppData\\Local\\Arduino15\\staging","user":"."},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-03-24T13:55:35.989Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-03-24T13:55:35.989Z config INFO Loaded the CLI configuration.
2024-03-24T13:55:36.002Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/piotr/AppData/Local/Arduino15","sketchDirUri":"file:///.","additionalUrls":[],"network":"none","locale":"en"}
2024-03-24T13:55:36.002Z config INFO Validating the CLI configuration...
2024-03-24T13:55:36.004Z config INFO The CLI config is valid.
2024-03-24T13:55:36.004Z config INFO <<< Initialized the CLI configuration.
2024-03-24T13:55:36.039Z root INFO Resolve plugins list: 95.8 ms [Finished 1.212 s after backend start]
2024-03-24T13:55:36.072Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:36.072Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
at Socket.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:43051)
at Socket.emit (node:events:514:28)
at addChunk (node:internal/streams/readable:324:12)
at readableAddChunk (node:internal/streams/readable:297:9)
at Socket.push (node:internal/streams/readable:234:10)
at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
2024-03-24T13:55:36.072Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:36.091Z daemon INFO time="2024-03-24T14:55:36+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
2024-03-24T13:55:36.243Z daemon INFO time="2024-03-24T14:55:36+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-24T14:55:36+01:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-03-24T14:55:36+01:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:56440
{"IP":"127.0.0.1","Port":"56440"}
2024-03-24T13:55:36.243Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:36.244Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:36.244Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:36.365Z daemon INFO time="2024-03-24T14:55:36+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:56441
{"IP":"127.0.0.1","Port":"56441"}
2024-03-24T13:55:36.366Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:36.366Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:36.366Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:36.381Z daemon INFO time="2024-03-24T14:55:36+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:56442
{"IP":"127.0.0.1","Port":"56442"}
2024-03-24T13:55:36.480Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:36.481Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:36.481Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:36.600Z daemon INFO time="2024-03-24T14:55:36+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:56443
{"IP":"127.0.0.1","Port":"56443"}
2024-03-24T13:55:36.601Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:36.601Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:36.601Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:36.639Z daemon INFO time="2024-03-24T14:55:36+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:56444
{"IP":"127.0.0.1","Port":"56444"}
2024-03-24T13:55:36.706Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:36.706Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:36.706Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:36.771Z daemon INFO time="2024-03-24T14:55:36+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:56445
{"IP":"127.0.0.1","Port":"56445"}
2024-03-24T13:55:36.792Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:36.792Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:36.792Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:36.860Z daemon INFO time="2024-03-24T14:55:36+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
2024-03-24T13:55:36.860Z daemon INFO time="2024-03-24T14:55:36+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:56446
{"IP":"127.0.0.1","Port":"56446"}
2024-03-24T13:55:36.959Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:36.959Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:36.960Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:36.972Z daemon INFO time="2024-03-24T14:55:36+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:56447
{"IP":"127.0.0.1","Port":"56447"}
2024-03-24T13:55:37.049Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
time="2024-03-24T14:55:37+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
2024-03-24T13:55:37.049Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.049Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:37.073Z daemon INFO time="2024-03-24T14:55:37+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-24T14:55:37+01:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-03-24T14:55:37+01:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:56448
{"IP":"127.0.0.1","Port":"56448"}
2024-03-24T13:55:37.165Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.165Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.165Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:37.171Z daemon INFO time="2024-03-24T14:55:37+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:56450
{"IP":"127.0.0.1","Port":"56450"}
2024-03-24T13:55:37.248Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.248Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.248Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:37.296Z daemon INFO time="2024-03-24T14:55:37+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:56451
{"IP":"127.0.0.1","Port":"56451"}
2024-03-24T13:55:37.362Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.362Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.362Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:37.362Z daemon INFO time="2024-03-24T14:55:37+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:56452
{"IP":"127.0.0.1","Port":"56452"}
2024-03-24T13:55:37.455Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.455Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.455Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:37.499Z daemon INFO time="2024-03-24T14:55:37+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:56455
{"IP":"127.0.0.1","Port":"56455"}
2024-03-24T13:55:37.587Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.587Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.587Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:37.587Z daemon INFO time="2024-03-24T14:55:37+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:56456
{"IP":"127.0.0.1","Port":"56456"}
2024-03-24T13:55:37.680Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.680Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.680Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:37.709Z daemon INFO time="2024-03-24T14:55:37+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
2024-03-24T13:55:37.711Z daemon INFO Daemon is now listening on 127.0.0.1:56458
{"IP":"127.0.0.1","Port":"56458"}
2024-03-24T13:55:37.726Z root INFO Deploy plugins list: 95.8 ms [Finished 2.900 s after backend start]
2024-03-24T13:55:37.763Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.763Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.763Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:37.779Z daemon INFO time="2024-03-24T14:55:37+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
2024-03-24T13:55:37.815Z daemon INFO time="2024-03-24T14:55:37+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
2024-03-24T13:55:37.816Z daemon INFO Daemon is now listening on 127.0.0.1:56459
{"IP":"127.0.0.1","Port":"56459"}
2024-03-24T13:55:37.830Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.830Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.830Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:37.848Z daemon INFO time="2024-03-24T14:55:37+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
2024-03-24T13:55:37.886Z daemon INFO time="2024-03-24T14:55:37+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
2024-03-24T13:55:37.887Z daemon INFO time="2024-03-24T14:55:37+01:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-24T13:55:37.888Z daemon INFO Daemon is now listening on 127.0.0.1:56460
{"IP":"127.0.0.1","Port":"56460"}
2024-03-24T13:55:37.901Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.901Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.901Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:37.916Z daemon INFO time="2024-03-24T14:55:37+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
2024-03-24T13:55:37.945Z daemon INFO time="2024-03-24T14:55:37+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
2024-03-24T13:55:37.947Z daemon INFO Daemon is now listening on 127.0.0.1:56461
{"IP":"127.0.0.1","Port":"56461"}
2024-03-24T13:55:37.971Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.971Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:37.971Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:37.986Z daemon INFO time="2024-03-24T14:55:37+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
2024-03-24T13:55:38.016Z daemon INFO time="2024-03-24T14:55:38+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
2024-03-24T13:55:38.017Z daemon INFO time="2024-03-24T14:55:38+01:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-24T13:55:38.017Z daemon INFO time="2024-03-24T14:55:38+01:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-24T13:55:38.018Z daemon INFO Daemon is now listening on 127.0.0.1:56462
{"IP":"127.0.0.1","Port":"56462"}
2024-03-24T13:55:38.041Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.041Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.041Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:38.057Z daemon INFO time="2024-03-24T14:55:38+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
2024-03-24T13:55:38.089Z daemon INFO time="2024-03-24T14:55:38+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
2024-03-24T13:55:38.089Z daemon INFO time="2024-03-24T14:55:38+01:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-24T13:55:38.090Z daemon INFO Daemon is now listening on 127.0.0.1:56463
{"IP":"127.0.0.1","Port":"56463"}
2024-03-24T13:55:38.117Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.117Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.117Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:38.134Z daemon INFO time="2024-03-24T14:55:38+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
2024-03-24T13:55:38.165Z daemon INFO time="2024-03-24T14:55:38+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
2024-03-24T13:55:38.165Z daemon INFO time="2024-03-24T14:55:38+01:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-24T13:55:38.166Z daemon INFO Daemon is now listening on 127.0.0.1:56464
{"IP":"127.0.0.1","Port":"56464"}
2024-03-24T13:55:38.184Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.184Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.184Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:38.200Z daemon INFO time="2024-03-24T14:55:38+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
2024-03-24T13:55:38.234Z daemon INFO time="2024-03-24T14:55:38+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
2024-03-24T13:55:38.234Z daemon INFO time="2024-03-24T14:55:38+01:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-24T13:55:38.236Z daemon INFO Daemon is now listening on 127.0.0.1:56465
{"IP":"127.0.0.1","Port":"56465"}
2024-03-24T13:55:38.256Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.256Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.256Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:38.271Z daemon INFO time="2024-03-24T14:55:38+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
2024-03-24T13:55:38.306Z daemon INFO time="2024-03-24T14:55:38+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
2024-03-24T13:55:38.307Z daemon INFO Daemon is now listening on 127.0.0.1:56466
{"IP":"127.0.0.1","Port":"56466"}
2024-03-24T13:55:38.323Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.323Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.323Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:38.338Z daemon INFO time="2024-03-24T14:55:38+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
2024-03-24T13:55:38.370Z daemon INFO time="2024-03-24T14:55:38+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
2024-03-24T13:55:38.371Z daemon INFO Daemon is now listening on 127.0.0.1:56467
{"IP":"127.0.0.1","Port":"56467"}
2024-03-24T13:55:38.391Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.392Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.392Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:38.405Z daemon INFO time="2024-03-24T14:55:38+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
2024-03-24T13:55:38.434Z daemon INFO time="2024-03-24T14:55:38+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
2024-03-24T13:55:38.435Z daemon INFO Daemon is now listening on 127.0.0.1:56468
{"IP":"127.0.0.1","Port":"56468"}
2024-03-24T13:55:38.478Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.478Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.478Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:38.495Z daemon INFO time="2024-03-24T14:55:38+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
2024-03-24T13:55:38.530Z daemon INFO time="2024-03-24T14:55:38+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
2024-03-24T13:55:38.532Z daemon INFO Daemon is now listening on 127.0.0.1:56469
{"IP":"127.0.0.1","Port":"56469"}
2024-03-24T13:55:38.552Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.552Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.552Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:38.567Z daemon INFO time="2024-03-24T14:55:38+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
2024-03-24T13:55:38.600Z daemon INFO time="2024-03-24T14:55:38+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
2024-03-24T13:55:38.601Z daemon INFO Daemon is now listening on 127.0.0.1:56470
{"IP":"127.0.0.1","Port":"56470"}
2024-03-24T13:55:38.624Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.624Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.624Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:38.644Z daemon INFO time="2024-03-24T14:55:38+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
Opening channel for service path '/services/electron-window'.
2024-03-24T13:55:38.683Z daemon INFO time="2024-03-24T14:55:38+01:00" level=info msg="Using config file: c:\\Users\\piotr\\.arduinoIDE\\arduino-cli.yaml"
2024-03-24T13:55:38.684Z daemon INFO Daemon is now listening on 127.0.0.1:56471
{"IP":"127.0.0.1","Port":"56471"}
2024-03-24T13:55:38.700Z daemon INFO Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.700Z daemon ERROR Error: Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku.
2024-03-24T13:55:38.700Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T13:55:38.721Z daemon INFO time="2024-03-24T14:55:38+01:00" level=warning msg="Unable to get Documents Folder: Nie mo┼╝na odnale┼║─ç okre┼Ťlonego pliku."
2
