Problem with arduino after update
Among other things, I made them a weather station and save the code for each good operation and make a folder which library I use. Now I have bought a new display (S3) and want to use the working code, but again after an update I get the most strange messages while this code that is present on the same display just works. So the code is good. How is this possible?
I'm using the ESP32-8048S070
Get a status 1 message.
And get error messages from the original library that came with the display and has always worked.
#include <Arduino_GFX_Library.h>
#define GFX_BL DF_GFX_BL // default backlight pin, you may replace DF_GFX_BL to actual backlight pin
#define TFT_BL 2
/* More dev device declaration: https://github.com/moononournation/Arduino_GFX/wiki/Dev-Device-Declaration */
#if defined(DISPLAY_DEV_KIT)
Arduino_GFX *gfx = create_default_Arduino_GFX();
#else /* !defined(DISPLAY_DEV_KIT) */
/* More data bus class: https://github.com/moononournation/Arduino_GFX/wiki/Data-Bus-Class */
//Arduino_DataBus *bus = create_default_Arduino_DataBus();
/* More display class: https://github.com/moononournation/Arduino_GFX/wiki/Display-Class */
//Arduino_GFX *gfx = new Arduino_ILI9341(bus, DF_GFX_RST, 0 /* rotation */, false /* IPS */);
Arduino_ESP32RGBPanel *bus = new Arduino_ESP32RGBPanel(
    GFX_NOT_DEFINED /* CS */, GFX_NOT_DEFINED /* SCK */, GFX_NOT_DEFINED /* SDA */,
    41 /* DE */, 40 /* VSYNC */, 39 /* HSYNC */, 42 /* PCLK */,
    14 /* R0 */, 21 /* R1 */, 47 /* R2 */, 48 /* R3 */, 45 /* R4 */,
    9 /* G0 */, 46 /* G1 */, 3 /* G2 */, 8 /* G3 */, 16 /* G4 */, 1 /* G5 */,
    15 /* B0 */, 7 /* B1 */, 6 /* B2 */, 5 /* B3 */, 4 /* B4 */
// option 1:
// 7寸 50PIN 800*480
Arduino_RPi_DPI_RGBPanel *gfx = new Arduino_RPi_DPI_RGBPanel(
  bus,
//  800 /* width */, 0 /* hsync_polarity */, 8/* hsync_front_porch */, 2 /* hsync_pulse_width */, 43/* hsync_back_porch */,
//  480 /* height */, 0 /* vsync_polarity */, 8 /* vsync_front_porch */, 2/* vsync_pulse_width */, 12 /* vsync_back_porch */,
//  1 /* pclk_active_neg */, 16000000 /* prefer_speed */, true /* auto_flush */);
    800 /* width */, 0 /* hsync_polarity */, 210 /* hsync_front_porch */, 30 /* hsync_pulse_width */, 16 /* hsync_back_porch */,
    480 /* height */, 0 /* vsync_polarity */, 22 /* vsync_front_porch */, 13 /* vsync_pulse_width */, 10 /* vsync_back_porch */,
#endif /* !defined(DISPLAY_DEV_KIT) */
 * End of Arduino_GFX setting
  #include <WiFi.h>
  #include <HTTPClient.h>
  #include <WiFiClient.h>
  #include <Arduino_JSON.h>
//fonts declare
//#include "FreeMono8pt7b.h"
/* more fonts at: https://github.com/moononournation/ArduinoFreeFontFile.git */
//https://oleddisplay.squix.ch/
//Kies lib version
//#include "Orbitron_Medium_12.h"
#include "fonts/Luckiest_Guy_Regular_18.h"
#include "fonts/Luckiest_Guy_Regular_24.h"
#include "fonts/Luckiest_Guy_Regular_26.h"
#include "fonts/Luckiest_Guy_Regular_28.h"
//#include "Montez_Regular_32.h"
#include "fonts/Dialog_plain_7.h"
#include "fonts/Dialog_plain_9.h"
#include "fonts/Dialog_plain_18.h"
#include "fonts/Dialog_plain_24.h"
#include "fonts/Dialog_bold_24.h"
#include "fonts/DialogInput_plain_32.h"
#include "fonts/Dialog_bold_32.h"
#include "fonts/Dialog_bold_40.h"
//#include "FreeSansBold10pt7b.h"
//#include "FreeSerifBoldItalic12pt7b.h"
  #define SCALE0      0xC655        // accent color for unused rainbow scale segments
  #define SCALE1      0x5DEE        // accent color for unused rainbow scale segments
  #define SCALE2      0x10CE        // blue used as fill in baro panel
//   #define RED2RED     0        // rainbow scale ring meter color scheme
//   #define GREEN2GREEN 1
//  #define BLUE2BLUE   2
//   #define BLUE2RED    3
  #define GREEN2RED   4
//   #define RED2GREEN   5
  #define DEG2RAD 0.0174532925
  const char* ssid = "xxx";        // your wifi SSID here
  const char* password = "xxxx";
  // const char* ssid = "xxxxx";        // your wifi SSID here
  // const char* password = "xxx";                                                   // your wifi password here
   String openWeatherMapApiKey = "xxxx";                                    // your OpenWeatherMap APIkey here
   String city = "Eindhoven";        // replace with your city's name
   String countryCode = "NL";        // replace with your country identification
   String jsonBuffer;
   String jsonDocument (1024);
// THE DEFAULT TIMER IS SET TO 10 SECONDS FOR TESTING PURPOSES
// for a final application, check the API call limits per hour/minute to avoid getting blocked/banned
   unsigned long lastTime = 0;
// timer set to 10 minutes (600000)
   unsigned long timerDelay = 600000;                                                           // currently one initial call and then every ten minutes
// set timer to 30 seconds (30000)                                                              // handy during the testing phase of your project
// unsigned long timerDelay = 30000;
//https://javl.github.io/image2cpp/
// 'OIP', 144x150px
const unsigned char epd_bitmap_OIP [] PROGMEM = {
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3c,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x3b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x3d, 0x80, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3c, 0xc0, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3e, 0x60, 0x00, 0x07, 0xe0, 0xf8, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0x30, 0x00, 0x1f, 0x00,
	0x1e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0x18, 0x00,
	0x3c, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f,
	0x8c, 0x00, 0x70, 0x1c, 0x01, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x3f, 0xc7, 0x00, 0xc0, 0x06, 0x08, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x3f, 0xe1, 0x83, 0x80, 0x03, 0x04, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf0, 0xe3, 0x00, 0x01, 0x06, 0x18, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x37, 0xf8, 0x7e, 0x00, 0x01, 0x82, 0x0c, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x17, 0xfe, 0x1e, 0x00, 0x00, 0x62, 0x06,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1b, 0xff, 0x0f, 0xe0, 0x00,
	0x33, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1b, 0xff, 0x83,
	0x9c, 0x00, 0x10, 0xc3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x09,
	0xff, 0xc1, 0xc7, 0x00, 0x10, 0x61, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x0d, 0xff, 0xe0, 0xe1, 0x80, 0x00, 0x30, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x0c, 0xff, 0xf0, 0x60, 0x40, 0x00, 0x10, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0xff, 0xf8, 0x30, 0xe0, 0x00, 0x08, 0xe0, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x46, 0x7f, 0xfc, 0x13, 0x00, 0x18, 0x08, 0xa0, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x73, 0x3f, 0xfe, 0x1e, 0x00, 0x07, 0x08,
	0xa0, 0x03, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x4f, 0x9f, 0xff, 0x0c, 0x00,
	0x01, 0xcc, 0x1f, 0xff, 0xc0, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x21, 0x8f, 0xff,
	0x08, 0x1f, 0x00, 0x66, 0x00, 0x00, 0x1f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x30,
	0xcf, 0xff, 0x00, 0x27, 0xe0, 0x22, 0x00, 0x00, 0xff, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x03, 0x98, 0xc3, 0xff, 0x80, 0x0f, 0xf8, 0x32, 0x0e, 0x03, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x02, 0xfe, 0x61, 0xff, 0x80, 0x0d, 0xfe, 0x12, 0x01, 0x1f, 0xfe, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x30, 0xff, 0x80, 0x0f, 0xff, 0x92, 0xc0, 0xff, 0xfc, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x18, 0x3f, 0x80, 0xff, 0x8f, 0xc2, 0x80, 0x7f,
	0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x1c, 0x0f, 0x81, 0xde, 0x0f, 0xbb,
	0x00, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xbf, 0xe7, 0x03, 0x80, 0x1f,
	0x87, 0xf7, 0xff, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x83, 0x05, 0x80,
	0x00, 0x0f, 0xff, 0xf1, 0xff, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0,
	0x18, 0xc0, 0x00, 0x0f, 0xff, 0xf1, 0xff, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x30, 0x5f, 0xe1, 0xb0, 0x00, 0x07, 0xff, 0xff, 0xc1, 0xdf, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x3f, 0xe0, 0x01, 0x00, 0x00, 0x03, 0xef, 0xc0, 0xf1, 0xfc, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x20, 0xf8, 0x02, 0x00, 0x00, 0x01, 0xff, 0xa8, 0x1f, 0xf0, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x1f, 0x04, 0x00, 0x00, 0x00, 0x7d, 0x1c, 0x5f, 0xe0,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x03, 0xd8, 0x00, 0x00, 0x00, 0x02, 0x03,
	0xbf, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x70, 0x00, 0x00, 0x00,
	0x06, 0x00, 0x0f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x1c, 0x00,
	0x00, 0x00, 0x0c, 0x48, 0x0f, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x3f, 0xfc,
	0x06, 0x00, 0x00, 0x00, 0x18, 0x48, 0x08, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
	0xe0, 0x07, 0x81, 0x80, 0x00, 0x00, 0x7b, 0xf8, 0x08, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x0f, 0x00, 0x00, 0xc0, 0xc0, 0x00, 0x00, 0xe0, 0x3d, 0x08, 0x18, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x7f, 0xf0, 0x00, 0x00, 0x30, 0x60, 0x00, 0x03, 0x80, 0x07, 0x18, 0x18, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x01, 0xfe, 0x0c, 0x30, 0x00, 0x0f, 0x00, 0x0b, 0xf8, 0x30,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x0f, 0x03, 0x86, 0x10, 0x00, 0x3c, 0x00, 0x10,
	0x30, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x38, 0x00, 0x63, 0x08, 0x00, 0xf0,
	0x00, 0x00, 0x61, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x60, 0x00, 0x18, 0x8c,
	0x07, 0x80, 0x00, 0x01, 0xc7, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x00, 0xc0, 0x00,
	0x0c, 0xc4, 0x10, 0x00, 0x00, 0x03, 0x3c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x01,
	0x80, 0x00, 0x02, 0x46, 0x00, 0x00, 0x00, 0x0c, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x04, 0x03, 0x00, 0x00, 0x01, 0x23, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x04, 0x06, 0x00, 0x00, 0x00, 0x93, 0xc1, 0x80, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x06, 0x04, 0x00, 0x00, 0x00, 0xd3, 0xec, 0x06, 0x18, 0x18, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0c, 0x00, 0x00, 0x00, 0x69, 0xf8, 0x38, 0x0f, 0xf8,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x18, 0x00, 0x00, 0x00, 0x29, 0xf9, 0xe0,
	0x1d, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x18, 0x00, 0x00, 0x00, 0x15,
	0xfe, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x30, 0x00, 0x00,
	0x00, 0x0d, 0xfe, 0x03, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x30,
	0x00, 0x00, 0x00, 0x04, 0xff, 0x1f, 0x08, 0x00, 0x01, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x03, 0x60, 0x00, 0x00, 0x00, 0x06, 0xff, 0xfe, 0x0c, 0x00, 0x06, 0x40, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x03, 0x60, 0x00, 0x00, 0x00, 0x02, 0xff, 0xfe, 0x04, 0x00, 0xcc, 0x20, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x03, 0x60, 0x00, 0x00, 0x00, 0x01, 0xff, 0xfe, 0x04, 0x01, 0xf0, 0x10,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xc0, 0x00, 0x00, 0x00, 0x00, 0xff, 0xfe, 0x08, 0x06,
	0x60, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfe,
	0x18, 0x0c, 0x40, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xc0, 0x00, 0x00, 0x00, 0x00,
	0x3f, 0xfe, 0x1c, 0x70, 0x40, 0x13, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00,
	0x00, 0x00, 0x1f, 0xfe, 0x26, 0x40, 0x40, 0x60, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80,
	0x00, 0x80, 0x00, 0x00, 0x0f, 0xfe, 0x21, 0xc0, 0xe5, 0xc0, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x03, 0x80, 0x00, 0x80, 0x00, 0x00, 0x07, 0xfe, 0x40, 0x4f, 0x6f, 0x80, 0x40, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x03, 0x00, 0x00, 0x80, 0x00, 0x00, 0x03, 0x07, 0xff, 0xe8, 0x39, 0x80, 0x40, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x80, 0x00, 0x00, 0x03, 0x00, 0x7f, 0xf8, 0x39, 0x80,
	0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x80, 0x00, 0x00, 0x06, 0x00, 0x00, 0x98,
	0x11, 0x80, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x80, 0x00, 0x00, 0x06, 0x00,
	0x01, 0x80, 0x01, 0xb1, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x80, 0x00, 0x00,
	0x0c, 0x00, 0x01, 0x00, 0x03, 0xbf, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x80,
	0x00, 0x00, 0x18, 0x00, 0x02, 0x00, 0x07, 0xf7, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0e, 0x00,
	0x00, 0xc0, 0x20, 0x00, 0x30, 0x00, 0x06, 0x00, 0x07, 0xf9, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x0e, 0x00, 0x00, 0xc0, 0x20, 0x00, 0x60, 0x00, 0x04, 0x00, 0x0f, 0xff, 0x20, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x0c, 0x00, 0x00, 0xc0, 0x40, 0x00, 0xc0, 0x00, 0x0e, 0x00, 0x1f, 0xfe, 0x20, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x40, 0x20, 0x03, 0x00, 0x00, 0x0f, 0x80, 0x3f, 0xff,
	0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x40, 0x30, 0x1c, 0x00, 0x00, 0x19, 0xf1,
	0xff, 0xff, 0xb0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x00, 0x40, 0x07, 0xe0, 0x00, 0x00,
	0x10, 0x3f, 0xff, 0xff, 0xb0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x60, 0x00, 0x00,
	0x00, 0x00, 0x30, 0x3f, 0xff, 0xff, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x60,
	0x00, 0x00, 0x00, 0x00, 0x30, 0x3f, 0xff, 0xff, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00,
	0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x20, 0x7f, 0xff, 0xff, 0xb0, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x38, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x60, 0xff, 0xff, 0xff, 0xa0, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x30, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x60, 0xff, 0xf0, 0xff, 0x20, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x41, 0xff, 0x90, 0xfe,
	0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0xc3, 0xff,
	0x90, 0xfe, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00,
	0xc7, 0xf9, 0x31, 0xfc, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x18, 0x00, 0x00,
	0x00, 0x00, 0x8f, 0xf1, 0x33, 0xfc, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x1c,
	0x00, 0x00, 0x00, 0x01, 0x8f, 0xf3, 0x37, 0xf8, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00,
	0x00, 0x0c, 0x00, 0x00, 0x00, 0x01, 0x9f, 0xf2, 0x37, 0xf8, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x60, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x01, 0x8f, 0xf2, 0x33, 0xf8, 0x40, 0x00, 0x00, 0x00,
	0x00, 0x00, 0xe0, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x01, 0x8f, 0xf2, 0x31, 0xf8, 0xc0, 0x00,
	0x00, 0x00, 0x00, 0x00, 0xe0, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x01, 0x0f, 0xfa, 0x30, 0xf0,
	0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x01, 0x07, 0xfe,
	0x30, 0x70, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x03,
	0x07, 0xfe, 0x30, 0x31, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x01, 0xc0, 0x00,
	0x00, 0x03, 0x07, 0xfc, 0x10, 0x11, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00,
	0xe0, 0x00, 0x00, 0x03, 0x07, 0xfc, 0x10, 0x13, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00,
	0x00, 0x00, 0xf0, 0x00, 0x00, 0x03, 0x07, 0xfe, 0x10, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
	0x80, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x03, 0x07, 0xfe, 0x10, 0x03, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x03, 0x0d, 0xfe, 0x18, 0x06, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x02, 0x0d, 0xfe, 0x18, 0x06,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x02, 0x0c, 0xfe,
	0x18, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x02,
	0x1c, 0xfe, 0x08, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x03, 0xc0,
	0x00, 0x02, 0x1c, 0x7f, 0x08, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
	0x01, 0xf0, 0x00, 0x02, 0x14, 0x7f, 0x8c, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00,
	0x00, 0x00, 0x00, 0xf8, 0x00, 0x02, 0x32, 0x7f, 0xc4, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x02, 0x22, 0x3f, 0xe4, 0x60, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x00, 0x02, 0x22, 0x3f, 0xbe, 0xc0, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x07, 0xc0, 0x02, 0x62, 0x3f, 0xcf, 0x80,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x30, 0x00, 0x03, 0xf0, 0x02, 0x62, 0x3f,
	0xc7, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x01, 0xc0, 0x00, 0x00, 0xfe, 0x02,
	0xe2, 0x3f, 0xc2, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00,
	0x7f, 0x83, 0xe3, 0x7f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x78, 0x00,
	0x00, 0x00, 0x6f, 0xe3, 0xe1, 0x7f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xc6, 0x00, 0x1f,
	0xc0, 0x00, 0x00, 0x00, 0xc1, 0xff, 0x61, 0x7f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xff,
	0xff, 0xfe, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x3e, 0x61, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x06, 0x07, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x04, 0x61, 0xff, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x61, 0xfe, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x61, 0xfe,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00,
	0x41, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06,
	0x00, 0x00, 0x41, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x08, 0x00,
	0x00, 0x0c, 0x00, 0x00, 0x43, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00,
	0xe0, 0x00, 0x00, 0x18, 0x00, 0x00, 0x43, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00,
	0x00, 0x07, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x47, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x08, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x30, 0x02, 0x00, 0x47, 0xf0, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x07, 0xc8, 0x00, 0x3f, 0x00, 0x00, 0x00, 0x00, 0x60, 0x02, 0x00, 0x4f, 0xf0, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x05, 0xff, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x60, 0x02, 0x00, 0x4f, 0xf0,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x02, 0x00,
	0x4f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80,
	0x02, 0x00, 0x4f, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x03, 0x00, 0x02, 0x00, 0x4f, 0xe8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x06, 0x00, 0x02, 0x00, 0x5f, 0xe8, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x02, 0x00, 0x5f, 0xe4, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x02, 0x00, 0x5f, 0xc6, 0x00, 0x00, 0x00, 0x00,
	0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x02, 0x00, 0x5f, 0xc2, 0x00, 0x00,
	0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x02, 0x00, 0x5f, 0xc3,
	0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x02, 0x00,
	0x1f, 0xc1, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00,
	0x03, 0xff, 0xff, 0xc0, 0x80, 0x00, 0x00, 0x00, 0x3f, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f,
	0x00, 0x00, 0x02, 0x00, 0x1f, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0xff, 0xfe, 0x00, 0x00, 0x00,
	0x00, 0x3f, 0xff, 0x00, 0x1e, 0x00, 0x1f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xfe,
	0x00, 0x00, 0x03, 0xe0, 0x1f, 0xff, 0x80, 0x00, 0x1f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x7f, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x80, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x3f, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x80, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x80,
	0x1f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x1f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x1f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x80, 0x00, 0x00, 0x00, 0x00
  int delayTime = 500;
// joint variables
   float temp_01=10;
   float hum_01;
   int   hum_02;
   int   press_02 = 960;        // necessary for initial dynamic baro panel
   float w_speed_01;
   float w_speed_02;
   float press_01;
   float weather_01;
// rainbow scale ring meter variables
   uint32_t runTime = -99999;        // time for next update
   int reading = 10;        // value to be displayed in circular scale
   int tesmod = 0;
   int r_gauge_pos_x = 420 ;              // these two variables govern the position  ====> Nieuwe pos tbv 7"
   int r_gauge_pos_y = 10;              // of the square + gauge on the display
//org   int r_gauge_pos_x;        // these two variables govern the position
//org   int r_gauge_pos_y;        // of the square + gauge on the display
   int ringmeter_radius = 150;        // governs diameter of rainbow gauge
//org   int ringmeter_radius = 65;
  char* ringlabel[] = {"","*C","%","mBar"};
                                             // some custom labels
   float temp_rainbowgauge;
   int t;
        // x-position of numeric in rainbow scale center        // governs position of numerical output rainbow scale
// small needle humidity meter
   int   j;
   float center_x1;        // center x of edge markers humidity gauge
   float center_y1;        // center y of edge markers humidity gauge
   int   radius_s = 135;        // for scale markers
   int   needle_length = 120;        // gauge needle length
   int   edgemarkerLength = 5;        // edge marker length
   float edge_x1, edge_y1, edge_x1_out, edge_y1_out;
   float angle_needle = 0;
   float needle_x, needle_y;
   float needle_x_old, needle_y_old;
   float angle_circle = 0;
   int   pivot_x;        // pivot coordinates needle of small gauge hum panel
   int   pivot_y;
   int   static_num_panel_x;
   int   static_num_panel_y;
   int   baro_panel_x;
   int   baro_panel_y;
   float barval;
   int   p1_x, p1_y, p1_x_old, p1_y_old;                                                        // barometer panel polygon points
   int   p2_x, p2_y, p2_x_old, p2_y_old;
   int   p3_x, p3_y, p3_x_old, p3_y_old;
   int   p4_x, p4_y, p4_x_old, p4_y_old;
   float compassPivot_x;        // wind compass direction pointer
   float compassPivot_y;
   float c_x1, c_x2,c_x3, c_x4;
   float c_y1, c_y2,c_y3, c_y4;
   float c_x1_old,c_x2_old,c_x3_old, c_x4_old;
   float c_y1_old,c_y2_old,c_y3_old, c_y4_old;
   float wind_dir_01;
   int   wind_dir_02;
   float compass_angle;
   int   compass_r = 22;
   char* sector [] = {"Noord", "Noord-Oost", "Oost", "Zuid-Oost", "Zuid", "Zuid-West", "West", "Noord-West"};                              // wind sector labels
   int   h;
   float max_temp_today;        // mini max temp panel
   float min_temp_today;
   int   minmax_panel_x;
   int   minmax_panel_y;
   int   t_meter_increase;
   int   t_meter_increase_old;
// TBV BEGIN POS KADERS
   int   kader_x;
   int   kader_y;
void setup(void)
   WiFi.begin (ssid, password);
   Serial.println ("Connecting");
     delay(5000);
     Serial.print(".");
   Serial.println("");
   Serial.print("Connected to WiFi network with IP Address: ");
   Serial.println("Timer set to 10 seconds (timerDelay variable), it will take 10 seconds before publishing the first reading.");
    gfx->begin();
    gfx->fillScreen(BLACK);
#ifdef TFT_BL
    pinMode(TFT_BL, OUTPUT);
    digitalWrite(TFT_BL, HIGH);
#endif
draw_all_panel_frames ();
title_panel_text();
static_data_in_numeric_window ();
rainbowScaleMeter ();
static_data_in_rainbow_panel ();
humidity_static ();
build_dynamic_baropanel ();        // to start dynamic baropanel
static_minmax_panel ();
compassGauge ();
   Serial.println ("First run to get data. Next update according to timerDelay");
   Serial.println ();
   Serial.println ();
   run_the_weatherstation (); // we do this here once to get the station up and running. next update: see timerDelay
   if ((millis() - lastTime) > timerDelay)                                                      // check WiFi connection status
       if(WiFi.status()== WL_CONNECTED)
          Serial.println("WiFi Disconnected");
         lastTime = millis();
   delay(10000);
 gfx->drawBitmap(635, 325, epd_bitmap_OIP, 144, 150, CYAN); //x,y, naam, grote
// #  functions section        #
// #  static - draw all panel frames                                                    #
void draw_all_panel_frames (){
 //  baro_panel_x = 162;
//   baro_panel_y = 156;
   baro_panel_x = 476;  //extra tbv positie
   baro_panel_y = 322;
   minmax_panel_x = 242;
   minmax_panel_y  = 478;
   kader_x = 3;
   kader_y = 3 ;
gfx->drawRoundRect(kader_x,   kader_y, 412,  38, 4, GREEN);                                      // title panel frame m TEXT KOP
gfx->drawRoundRect (  kader_x,  kader_y+40 , 412, 277, 4, GREEN);                                   // left upper big panel frame / VERZAMEL KADER
gfx->drawRoundRect (  kader_x+444,  kader_y, 335, 317, 4, GREEN);                                   // right upper big panel frame  // TEMP KADER VERZAMELRAINBOW => y= + 330
gfx->drawRoundRect (  3, 322,  154,  156, 4, GREEN);                           // extreme left lowerpanel frame    => kader WIND  y+????
gfx->drawRoundRect ( 161, 322,  154,  156, 4, GREEN);                         // left-of-middle lower panel frame       => HUM
gfx->drawRoundRect (minmax_panel_x+77, 322, 154,  156, 4, GREEN);                      // extreme right lower window e
gfx->drawRoundRect (476, 322, 154,  156, 4, GREEN);                      // barpmeter
// # static data in the title panel                                                     #
//https://github.com/moononournation/Arduino_GFX/blob/master/examples/HelloWorldGfxfont/HelloWorldGfxfont.ino
void title_panel_text(){
   gfx->setTextColor (CYAN,BLACK);
   gfx->setFont(&Luckiest_Guy_Regular_26);
   gfx->setCursor (kader_x+40,kader_y+28);
   gfx->print ("WEERONLINE EINDHOVEN");
// # static data in the numeric panel                                                   #
void static_data_in_numeric_window (){
   static_num_panel_x = 20;  //x org = 3  y org =3  (KADERS)    // all coordinates in this panel relative to these two
   static_num_panel_y = 35;  // org=+5
   gfx->setTextColor (YELLOW,BLACK);
   gfx->setFont(&Dialog_bold_32);
   gfx->setCursor (static_num_panel_x,static_num_panel_y+45);   // basis postie laten staan
   gfx->print ("temp");
   gfx->setCursor (static_num_panel_x,static_num_panel_y+100);   //alles Y+10 ivm grote
   gfx->print ("druk");
   gfx->setCursor (static_num_panel_x,static_num_panel_y+155);
   gfx->print ("vocht");
   gfx->setCursor (static_num_panel_x,static_num_panel_y+210);
   gfx->print ("wind");
   gfx->setCursor (static_num_panel_x,static_num_panel_y+265);
   gfx->print ("richting");
   //gfx->setTextColor (YELLOW,BLACK);
   //gfx->setFreeFont(&FreeSans9pt7b);
   gfx->setCursor (static_num_panel_x+310,static_num_panel_y+45); //Y+5  alles X+50 tbv opschuiven naar rechts
   gfx->print ("C");
   gfx->drawCircle(static_num_panel_x+300,static_num_panel_y+25,4,YELLOW);   // degree character
   gfx->drawCircle(static_num_panel_x+300,static_num_panel_y+25,5,YELLOW);   // char degree character -> werkt alleen bij GFX   // degree character
   gfx->setCursor (static_num_panel_x+300,static_num_panel_y+100);
   gfx->print ("mB");
   gfx->setCursor (static_num_panel_x+300,static_num_panel_y+155);
   gfx->print ("%");
   gfx->setCursor (static_num_panel_x+300,static_num_panel_y+210);
   gfx->print ("m/s");
  gfx->setFont(0);
// # static data in the rainbow scale panel                                             #
 void static_data_in_rainbow_panel (){
   gfx->setFont(&Dialog_plain_18);
   gfx->setCursor (r_gauge_pos_x+45,r_gauge_pos_y+15);
   gfx->setTextColor (YELLOW);
   gfx->drawCircle(r_gauge_pos_x+310,r_gauge_pos_y+5,3,YELLOW);                    // degree character
   gfx->drawCircle(r_gauge_pos_x+310,r_gauge_pos_y+5,4,YELLOW);
   gfx->setCursor (r_gauge_pos_x+320,r_gauge_pos_y+20);
   gfx->print ("C");
   gfx->setCursor (r_gauge_pos_x+145,r_gauge_pos_y+290);
   gfx->setFont(&Dialog_plain_24);
   gfx->print ("0");
   gfx->setCursor (r_gauge_pos_x+230,r_gauge_pos_y+290);          // 50 is top rainbow scale temperature
   gfx->print ("50");
   gfx->setFont(0);
// #  wind compass - static part                                                        #
void compassGauge (){
   compassPivot_x = 1;       // these coordinates determine the position of wind compass and everything in it  /positie aanpassin bij 7"
   compassPivot_y = 301;
   gfx->drawCircle ((compassPivot_x+80), (compassPivot_y+98), (compass_r+25), BLUE);             // outer circle compass   ===> centrum posistie van ringen
   gfx->drawCircle ((compassPivot_x+80), (compassPivot_y+98), (compass_r+15), CYAN);              // inner circle compass - pointer fits in here
   gfx->setTextColor (WHITE, BLACK);
   gfx->setCursor ((compassPivot_x+73), (compassPivot_y+42));
   gfx->print ("N");
   gfx->setCursor ((compassPivot_x+75), (compassPivot_y+165));
   gfx->print ("Z");
   gfx->setCursor ((compassPivot_x+133), (compassPivot_y+105));
   gfx->print ("O");
   gfx->setCursor ((compassPivot_x+10), (compassPivot_y+105));
   gfx->print ("W");
   gfx->setFont(&Dialog_plain_9);
   gfx->setCursor ((compassPivot_x+40), (compassPivot_y+60));
   gfx->print ("NW");
   gfx->setCursor ((compassPivot_x+110), (compassPivot_y+60));
   gfx->print ("NO");
   gfx->setCursor ((compassPivot_x+40), (compassPivot_y+140));
   gfx->print ("ZW");
   gfx->setCursor ((compassPivot_x+110), (compassPivot_y+140));
   gfx->print ("ZO");
   gfx->setCursor ((compassPivot_x+10), (compassPivot_y+40));
   gfx->setTextColor (YELLOW, BLACK);
   gfx->setFont(0);
// #  wind compass - dynamic wind compass pointer                                       #
void compassPointer (){
  compassPivot_x = 40;       // these coordinates determine the position of wind compass and everything in it  /positie aanpassin bij 7"
  compassPivot_y = 360;
   gfx->fillTriangle (c_x1_old,c_y1_old,c_x2_old,c_y2_old,c_x4_old,c_y4_old,BLACK);          // remove old compass pointer by overwritig in white
   gfx->fillTriangle (c_x1_old,c_y1_old,c_x3_old,c_y3_old,c_x4_old,c_y4_old,BLACK);          // remove old compass pointer by overwritig in white
   compass_angle = ((wind_dir_02-90)*DEG2RAD);
   c_x1 = ((compassPivot_x+40) + (compass_r * cos (compass_angle)));                         // calculate coordinates compass pointer tip
   c_y1 = ((compassPivot_y+40) + (compass_r * sin (compass_angle)));
   c_x2 = ((compassPivot_x+40) + (compass_r * cos (compass_angle + 163*DEG2RAD)));           // calculate coordinates compass pointer base point
   c_y2 = ((compassPivot_y+40) + (compass_r * sin (compass_angle + 163*DEG2RAD)));
   c_x3 = ((compassPivot_x+40) + (compass_r * cos (compass_angle - 163*DEG2RAD)));           // calculate coordinates compass pointer base point
   c_y3 = ((compassPivot_y+40) + (compass_r * sin (compass_angle - 163*DEG2RAD)));
   c_x4 = ((compassPivot_x+40) + ((compass_r-4) * cos (compass_angle - 180*DEG2RAD)));       // calculate coordinates compass pointer base point
   c_y4 = ((compassPivot_y+40) + ((compass_r-4) * sin (compass_angle - 180*DEG2RAD)));
   c_x1_old = c_x1; c_x2_old = c_x2; c_x3_old = c_x3;   c_x4_old = c_x4;
   c_y1_old = c_y1; c_y2_old = c_y2; c_y3_old = c_y3;   c_y4_old = c_y4;
   gfx->fillTriangle (c_x1, c_y1,c_x3, c_y3, c_x4, c_y4, 0x3A72);                            // print the new pointer to display
   gfx->fillTriangle (c_x1, c_y1,c_x2, c_y2, c_x4, c_y4, CYAN);                              // print the new pointer to display
tft.fillTriangle (c_x2, c_y2 ,c_x3, c_y3-20, c_x4, c_y4, CYAN);
2=rechterhoek, 3=top  4 = linkerhoek
Parameters:
x0:x coordinate of the apex
y0:y coordinate of the apex
x1:x coordinate of the bottom left point
y1:y coordinate of the bottom left point
x2:x coordinate of the bottom right point
y2:y coordinate of the bottom right point
color:the color of the triangle
        1
  * *   4  * *
3               2
// #  wind sector calculator                                                            #
void windSectorReporter (){
   h = 0;
   if (wind_dir_02 <22.5) h = 0;
   if (wind_dir_02> 22.5) h = 1;
   if (wind_dir_02> 67.5) h = 2;
   if (wind_dir_02>112.5) h = 3;
   if (wind_dir_02>157.5) h = 4;
   if (wind_dir_02>202.5) h = 5;
   if (wind_dir_02>247.5) h = 6;
   if (wind_dir_02>292.5) h = 7;
   if (wind_dir_02>337.5) h = 8;
// #  humidity needle meter panel - static part                                         #       // in right-of-middle lower window
void humidity_static (){
// these four coordinates determine everything in the humidity meter panel
   pivot_x   = 167;             // pivot coordinates needle of humidity meter -// pivot coordinates needle of small gauge  -> punt begin lijn
   pivot_y   = 468;       //165
   center_x1 = 164;        // center x of edge markers humidity gauge - different from pivot needle!
   center_y1 = 470;
   needle_x_old = pivot_x;        // remember
   needle_y_old = pivot_y;        // remember
  gfx->setCursor ((pivot_x+65), (pivot_y-128));                                                  // display percent sign in  small gauge scale
  gfx->print ("% vocht");
  gfx->fillCircle (pivot_x+2, pivot_y, 4, MAGENTA);           // pivot needle middle small gauge        // arbitrary seeding temp - avoids drawing black line from position 0.0
 // gfx->setFont(&Dialog_plain_9);
  gfx->setCursor ((pivot_x),(pivot_y-110));
  gfx->print ("100");
  gfx->setCursor ((pivot_x+100),(pivot_y-10));
  gfx->print ("40");        // scale starts with 40% and ends with 100%
  j = 270;        // start point of cirle segment
    do {
       angle_circle = (j* DEG2RAD);                                                             // angle expressed in radians - 1 degree = 0,01745331 radians
       edge_x1 = (center_x1+4 + (radius_s*cos (angle_circle)));                                 // scale - note the 4 pixels offset in x
       edge_y1 = (center_y1 + (radius_s*sin (angle_circle)));                                   // scale
       edge_x1_out = (center_x1+4 + ((radius_s+edgemarkerLength)*cos (angle_circle)));          // scale - note the 4 pixels offset in x
       edge_y1_out = (center_y1 + ((radius_s+edgemarkerLength)*sin (angle_circle)));            // scale
       gfx->drawLine (edge_x1, edge_y1, edge_x1_out, edge_y1_out,MAGENTA);
       j = j+6;
   while (j<356);
//extra ivm extra weergave
    do {
       edge_x1_out = (center_x1+5 + ((radius_s+edgemarkerLength)*cos (angle_circle)));          // scale - note the 4 pixels offset in x
       edge_y1_out = (center_y1+1 + ((radius_s+edgemarkerLength)*sin (angle_circle)));            // scale
       gfx->drawLine (edge_x1+1, edge_y1, edge_x1_out, edge_y1_out,CYAN); //MAGENTA
       j = j+6;
   while (j<356);
  gfx->setFont(0);
        // end of circle segment
// #   humidity needle meter - dynamic part = needle movement control                   #
void needle_meter (){
   gfx->drawLine (pivot_x, pivot_y, needle_x_old, needle_y_old, 0);                              // remove old needle by overwritig in BLACK
   angle_needle = (420*DEG2RAD - 1.5*hum_02*DEG2RAD);                                           // contains a 1.5 stretch factor to expand 60 percentage points over 90 degrees of scale
   if (angle_needle > 6.28) angle_needle = 6.28;                                                // prevents the needle from ducking below horizontal
   needle_x = (pivot_x + ((needle_length)*cos (angle_needle)));                                 // calculate x coordinate needle point
   needle_y = (pivot_y + ((needle_length)*sin (angle_needle)));                                 // calculate y coordinate needle point
   needle_x_old = needle_x;        // remember previous needle position
   needle_y_old = needle_y;
 //  gfx->drawLine (pivot_x, pivot_y, needle_x, needle_y,MAGENTA);
   gfx->drawLine (pivot_x, pivot_y, needle_x, needle_y,CYAN); //RED
  // gfx->drawLine (pivot_x+3, pivot_y+1, needle_x+1, needle_y+1,CYAN); //RED
   gfx->fillCircle (pivot_x, pivot_y, 2, MAGENTA);                                               // restore needle pivot
// # static data in the min-max temp panel                                              #
   void static_minmax_panel (){
//kader afmeting gfx->drawRoundRect  (minmax_panel_x+75, minmax_panel_y-154, 154,  156, 4, GREEN);
   gfx->drawRoundRect (minmax_panel_x+90, minmax_panel_y-148, 14, 120, 4, WHITE);                     // 'thermometer'
   gfx->fillCircle (minmax_panel_x+96, minmax_panel_y-20, 13, RED);
   gfx->drawCircle (minmax_panel_x+96, minmax_panel_y-20, 14, WHITE);
   gfx->setCursor (minmax_panel_x+120,minmax_panel_y-138); //110
   gfx->print ("Max temp");
   gfx->drawCircle (minmax_panel_x+195, minmax_panel_y-120, 3, WHITE);
   gfx->drawCircle (minmax_panel_x+195, minmax_panel_y-120, 4, WHITE); // meer min => omhoog
   gfx->setCursor (minmax_panel_x+197,minmax_panel_y-95);
   gfx->setTextColor (WHITE,BLACK);
   gfx->print ("C");
   gfx->setCursor (minmax_panel_x+120,minmax_panel_y-60);
   gfx->print ("Min temp");
   gfx->drawCircle (minmax_panel_x+195, minmax_panel_y-40, 3, WHITE);
   gfx->drawCircle (minmax_panel_x+195, minmax_panel_y-40, 4, WHITE);
   gfx->setCursor (minmax_panel_x+197,minmax_panel_y-15);
   gfx->print ("C");
   t_meter_increase = 92;         //was 46                  // absolute vertical pixel range of 'mercury' in thermometer simulation
    gfx->setFont(0);
//https://stackoverflow.com/questions/75858382/openweathermap-weather-returns-null
// # run the weather station - get json string and parse                                #
void run_the_weatherstation (){
// for(;;){
          String serverPath = "http://api.openweathermap.org/data/2.5/weather?q=" + city + "," + countryCode + "&APPID=" + openWeatherMapApiKey;
          jsonBuffer = httpGETRequest(serverPath.c_str());
          Serial.println(jsonBuffer);
          Serial.println("na jsonbuffer");
          JSONVar myObject = JSON.parse(jsonBuffer);
               double weather_01  = (myObject ["weather"]["id"]);
               double temp_01     = (myObject ["main"]["temp"]);
               double hum_01      = (myObject ["main"]["humidity"]);
               double press_01    = (myObject ["main"]["pressure"]);
               double w_speed_01  = (myObject ["wind"]["speed"]);
               double wind_dir_01 = (myObject ["wind"]["deg"]);
         JSONVar minmax_temp = JSON.parse(jsonBuffer);
               double min_temp = (minmax_temp ["main"]["temp_min"]);
               double max_temp = (minmax_temp ["main"]["temp_max"]);
          if (JSON.typeof(myObject) == "undefined")                                             // JSON.typeof(jsonVar) can be used to get the type of the var
             Serial.println("Parsing input failed!");
             return;
          Serial.println ("*******************************************");
          Serial.print ("JSON object = ");
          Serial.println (myObject);
          Serial.println ("extracted from JSON object:");
          Serial.print (myObject["weather"]["id"]);
          Serial.println (" =ID2");
          Serial.print ("temperature:    ");
          Serial.print (myObject["main"]["temp"]);
          Serial.println (" *K");
          Serial.print ("pressure:       ");
          Serial.print (myObject["main"]["pressure"]);
          Serial.println (" mB");
          Serial.print ("humidity:       ");
          Serial.print(myObject["main"]["humidity"]);
          Serial.println (" %");
          Serial.print ("wind speed:     ");
          Serial.print (myObject["wind"]["speed"]);
          Serial.println (" m/s");
          Serial.print("wind direction: ");
          Serial.print (myObject["wind"]["deg"]);
          Serial.println (" degrees");
          temp_rainbowgauge = temp_01-273;                                                      // convert temp from Kelvin to Celsius
          hum_02 = hum_01;        // place humidity value in a transferable variable
          press_02 = press_01;        // place air pressure value in a transferable variable
          w_speed_02 = w_speed_01;                                                              // place wind speed value in a transferable variable
          max_temp_today = max_temp-273;
          min_temp_today = min_temp-273;
          Serial.print("min temp today: ");
          Serial.print (min_temp_today,1);
          Serial.println (" *C");
          Serial.print("max temp today: ");
          Serial.print (max_temp_today,1);
          wind_dir_02 = wind_dir_01;
          windSectorReporter ();
   gfx->setCursor ((compassPivot_x+10), (compassPivot_y+170));
   gfx->print (myObject["wind"]["deg"]);
   gfx->setFont(0);
    print_dynamic_data_to_display ();
    compassPointer ();
    refresh_dynamic_baropanel();
    needle_meter ();
    dynamic_minmax_panel ();
//}//einde for
}//einde run
// # dynamic data in the min-max temp panel                                             #
//nog aanpassen
   void dynamic_minmax_panel (){
   gfx->fillRect (minmax_panel_x+115,minmax_panel_y-115, 72,30,BLACK); //BLACK   tbv wegvegen oude waarde  /meer min => omhoog
   gfx->setFont(&Dialog_bold_24);
   if (max_temp_today >=  0.0) gfx->setCursor (minmax_panel_x+140,minmax_panel_y-95);
   if (max_temp_today >= 10.0) gfx->setCursor (minmax_panel_x+124,minmax_panel_y-95);
   if (max_temp_today <  -0.0) gfx->setCursor (minmax_panel_x+124,minmax_panel_y-95);
   if (max_temp_today <  -9.9) gfx->setCursor (minmax_panel_x+128,minmax_panel_y-95);
   gfx->print (max_temp_today,1);
   gfx->fillRect (minmax_panel_x+115,minmax_panel_y-35, 72,30,BLACK);   //BLACK
   if (min_temp_today >=  0.0) gfx->setCursor (minmax_panel_x+140,minmax_panel_y-15);
   if (min_temp_today >= 10.0) gfx->setCursor (minmax_panel_x+124,minmax_panel_y-15); //minder min => omlaag
   if (min_temp_today <  -0.0) gfx->setCursor (minmax_panel_x+124,minmax_panel_y-15);
   if (min_temp_today <  -9.9) gfx->setCursor (minmax_panel_x+128,minmax_panel_y-15);
   gfx->print (min_temp_today,1);
   t_meter_increase_old = t_meter_increase;
   t_meter_increase = ((max_temp_today/33)*92);                                                 // empirically determined dynamic range of 'mercury' in the graphical thermometer
   //t_meter_increase = ((max_temp_today/33)*46);                                                 // empirically determined dynamic range of 'mercury' in the graphical thermometer
   if (t_meter_increase <1)  t_meter_increase = 1;
   if (t_meter_increase >45) t_meter_increase = 45;                                             // barrier against overflowing of graphical thermometer
   //if (t_meter_increase <1)  t_meter_increase = 1;
   //if (t_meter_increase >45) t_meter_increase = 45;
  //org gfx->fillRect (minmax_panel_x+9,minmax_panel_y+57, 5, -t_meter_increase_old, YELLOW); //black
//org gfx->fillRect (minmax_panel_x+9,minmax_panel_y+57, 5, -t_meter_increase, RED);
 gfx->fillRect (minmax_panel_x+91,minmax_panel_y-26 -t_meter_increase_old, 12, t_meter_increase_old,BLACK);
 gfx->fillRect (minmax_panel_x+91,minmax_panel_y-26 -t_meter_increase, 12, t_meter_increase,RED);
gfx->setFont(0);
// # http GET request module                                                            #
String httpGETRequest(const char* serverName) {
   WiFiClient client;
   HTTPClient http;
   http.begin(client, serverName);                                                              // your IP address with path or Domain name with URL path
   int httpResponseCode = http.GET();                                                           // send HTTP POST request
   String payload = "{}";
   if (httpResponseCode>0) {
    Serial.print("HTTP Response code: ");
    Serial.println(httpResponseCode);
    payload = http.getString();
   else {
     Serial.print("Error code: ");
   http.end();        // free resources
   return payload;
// #  dynamic temperature rainbow scale meter                                           #
void  rainbowScaleMeter (){
   if (millis () - runTime >= 100)                                                              // originally 500 = delay
      runTime = millis ();
      if( tesmod==0)
         reading =  99;
      if( tesmod==1)
         reading = temp_rainbowgauge*2;                                                         // important: here ring is seeded with value
//       r_gauge_pos_x = 161;        // these two variables govern the position
//       r_gauge_pos_y = 5;        // of the square + gauge on the display = upper left corner
     ringMeter (reading,0,100, (r_gauge_pos_x+45),(r_gauge_pos_y+17),ringmeter_radius,ringlabel[0],GREEN2RED);
     tesmod = 1;
// #  rainbow scale: draw the rainbox ring meter, returns x coord of righthand side     #
int ringMeter(int value,int vmin,int vmax,int x,int y,int r, char *units, byte scheme){
  // Minimum value of r is about 52 before value text intrudes on ring
  // drawing the text first is an option
   x += r; y += r;        // calculate coordinates of center of ring
   int w = r / 3;        // width of outer ring is 1/4 of radius
   int angle = 150;        // half the sweep angle of the meter (300 degrees)
   int v = map (value, vmin, vmax, -angle, angle);                                              // map the value to an angle v
   byte seg = 3;        // segments are 3 degrees wide = 100 segments for 300 degrees
   byte inc = 6;        // draw segments every 3 degrees, increase to 6 for segmented ring
   int colour = BLUE;        // variable to save "value" text color from scheme and set default
   for (int i = -angle+inc/2; i < angle-inc/2; i += inc)                                        // draw color blocks every increment degrees
      float sx = cos((i - 90) * DEG2RAD);                                                       // calculate pair of coordinates for segment start
      float sy = sin((i - 90) * DEG2RAD);
      uint16_t x0 = sx * (r - w) + x;
      uint16_t y0 = sy * (r - w) + y;
      uint16_t x1 = sx * r + x;
      uint16_t y1 = sy * r + y;
      float sx2 = cos((i + seg - 90) * DEG2RAD);                                                // calculate pair of coordinates for segment end
      float sy2 = sin((i + seg - 90) * DEG2RAD);
      int x2 = sx2 * (r - w) + x;
      int y2 = sy2 * (r - w) + y;
      int x3 = sx2 * r + x;
      int y3 = sy2 * r + y;
      if (i < v)
         {        // fill in coloured segments with 2 triangles
          switch (scheme)
              case 0: colour = RED; break;                                                      // fixed color
              case 1: colour = GREEN; break;                                                    // fixed color
              case 2: colour = BLUE; break;                                                     // fixed colour
              case 3: colour = RED; break;                   // full spectrum blue to red
              case 4: colour = GREEN; break;                   // green to red (high temperature etc)
              case 5: colour = BLUE; break;                  // red to green (low battery etc)
            // case 3: colour = rainbow(map(i, -angle, angle, 0, 127)); break;                   // full spectrum blue to red
            //  case 4: colour = rainbow(map(i, -angle, angle, 70, 127)); break;                  // green to red (high temperature etc)
            //  case 5: colour = rainbow(map(i, -angle, angle, 127, 63)); break;                  // red to green (low battery etc)
              default: colour = BLUE; break;                                                    // fixed color
              gfx->fillTriangle(x0, y0, x1, y1, x2, y2, colour);
              gfx->fillTriangle(x1, y1, x2, y2, x3, y3, colour);
      else        // fill in blank segments
              gfx->fillTriangle(x0, y0, x1, y1, x2, y2, SCALE1);                                 // color of the unoccupied ring scale
              gfx->fillTriangle(x1, y1, x2, y2, x3, y3, SCALE0);                                 // color of the unoccupied ring scale
t=530;                                  //t=197 aanpassen tbv 7
   if (temp_rainbowgauge<-9.9) t = 525;   //positie na actuele temp
   if (temp_rainbowgauge>-9.9) t = 530;
   if (temp_rainbowgauge > 0 ) t = 532;
   if (temp_rainbowgauge >9.9) t = 524;
   gfx->fillRect (t+14,y-22,140,40,BLACK);   //BLACK   tbv wegvallen nadat temp is gelezen  BLACK
   gfx->setFont(&Dialog_bold_40);
   //gfx->setTextSize(4);
   gfx->setCursor (t+45,y+10);     //positie temp => temp 0.0 heeft basis t,y positie
   gfx->setTextColor (WHITE); //yellow
   gfx->print (temp_rainbowgauge,1);    // tft.print (temp_rainbowgauge,1);  = basic temp 0.0.
   return (temp_rainbowgauge);
  gfx->setFont(0);
// #  rainbow scale: 16-bit rainbow color mixer                                         #
unsigned int rainbow (byte value) {                                                             // value is expected to be in range 0-127
        // value is converted to a spectrum color from 0 = BLUE through to 127 = RED
   byte RED = 0;        // RED is the top 5 bits of a 16 bit colour value
   byte GREEN = 0;        // GREEN is the middle 6 bits
   byte BLUE = 0;        // BLUE is the bottom 5 bits
   byte quadrant = value / 32;
   if (quadrant == 0)
      BLUE = 31;
      GREEN = 2 * (value % 32);
      RED = 0;
   if (quadrant == 1)
      BLUE = 31 - (value % 32);
      GREEN = 63;
      RED = 0;
   if (quadrant == 2)
      BLUE = 0;
      GREEN = 63;
      RED = value % 32;
   if (quadrant == 3)
      BLUE = 0;
      GREEN = 63 - 2 * (value % 32);
      RED = 31;
   return (RED << 11) + (GREEN << 5) + BLUE;
// # dynamic data in the numeric panel                                                  #
void print_dynamic_data_to_display (){
//waarden presenteren
   static_num_panel_x = 120;                 // all coordinates in this panel relative to these two
   static_num_panel_y = 35;               // all coordinates in this panel relative to these two
   gfx->fillRect (static_num_panel_x+10,static_num_panel_y+20,150,40,BLACK);  //tbv wegvallen temp bij verandering ->org =BLACK
   gfx->setCursor (static_num_panel_x+65,static_num_panel_y+46);
   gfx->print (temp_rainbowgauge,1);  //tbv temp in rainbow en totaal overzicht
   gfx->fillRect (static_num_panel_x+45,static_num_panel_y+72,132,40,BLACK);
   gfx->setCursor (static_num_panel_x+55,static_num_panel_y+98);
   if (press_02 <1000) gfx->setCursor (static_num_panel_x+60,static_num_panel_y+98);
   gfx->print (press_02,0);
   gfx->fillRect (static_num_panel_x+45,static_num_panel_y+129,120,40,BLACK);
   gfx->setCursor (static_num_panel_x+75,static_num_panel_y+155);
   gfx->print (hum_02,0);
   gfx->fillRect (static_num_panel_x+40,static_num_panel_y+184,130,40,BLACK);
   gfx->setCursor (static_num_panel_x+70,static_num_panel_y+210);
   gfx->print (w_speed_02,1);
   gfx->fillRect (static_num_panel_x+45,static_num_panel_y+238,245,36,BLACK);
   gfx->setCursor (static_num_panel_x+65,static_num_panel_y+265);
   gfx->print (sector[h]);
   gfx->setFont(0);
// #  dynamic barometer panel                                                           #
void build_dynamic_baropanel (){        // fills two triangles to create 4-point polygon
   barval = 1050-press_02;
//   baro_panel_x = 162;  //extra tbv positie
//   baro_panel_y = 156;        // based on baro pressure
//   baro_panel_x = 476;  //extra tbv positie
//   baro_panel_y = 322;
//vierkant linker bovenhoek = 476,322
   p1_x = ((baro_panel_x+6)+ ((100-barval)/100*144));                                            // p1-p2-p3 corner points for first triangle
   p1_y = ((baro_panel_y+150)- ((100-barval)/100*146));                                           // p1-p4-p3 corner points for second triangle
   p2_x = baro_panel_x+2;
   p2_y = baro_panel_y+154; //was 148
   p3_x = baro_panel_x+152; //was 150
   p3_y = baro_panel_y+154; //was 148
   p4_x = baro_panel_x+152;
   p4_y = p1_y;
   p1_x_old = p1_x;        // remember previous positions of points
   p1_y_old = p1_y;
   p2_x_old = p2_x;
   p2_y_old = p2_y;
   p3_x_old = p3_x;
   p3_y_old = p3_y;
   p4_x_old = p4_x;
   p4_y_old = p4_y;
  gfx->fillTriangle (p1_x, p1_y, p2_x, p2_y, p3_x, p3_y, SCALE2);   //SCALE2                            // make new first triangle
  gfx->fillTriangle (p1_x, p1_y, p4_x, p4_y, p3_x, p3_y, SCALE2);   //SCALE2                            // make new second triangle
  gfx->drawLine (p1_x, p1_y,  p4_x, p4_y, CYAN);                                                // draw horizontal level line
   gfx->drawLine (baro_panel_x+8, baro_panel_y+150, baro_panel_x+148, baro_panel_y+150, SCALE2);    // correct triangles base    SCALE2
   gfx->drawLine (baro_panel_x+8, baro_panel_y+152, baro_panel_x+144, baro_panel_y+152, SCALE2);    // correct triangles-base    SCALE2
   gfx->drawRoundRect (baro_panel_x, baro_panel_y,  154,  156, 4, GREEN);                          // correct right-of-middle lower panel frame
   gfx->drawLine (baro_panel_x+4, baro_panel_y+150, (baro_panel_x+150), (baro_panel_y+4), CYAN);   // redraw line
   gfx->fillCircle (p1_x, p1_y,3,RED);
   gfx->setCursor (baro_panel_x+10, baro_panel_y+20);
   gfx->print ("baro ");
   gfx->setCursor (baro_panel_x+64, baro_panel_y+20);
       if (press_02>999) gfx->print ("high"); else gfx->print ("low ");
   gfx->setFont(0);
// # refresh the dynamic barometer panel                                                #
void refresh_dynamic_baropanel (){
  gfx->fillCircle   (p1_x_old, p1_y_old, 3, BLACK);                                              // erase previous position of red circle
  gfx->fillTriangle (p1_x_old, p1_y_old, p2_x_old, p2_y_old, p3_x_old, p3_y_old, BLACK);         // remove previous first triangle
  gfx->fillTriangle (p1_x_old, p1_y_old, p4_x_old, p4_y_old, p3_x_old, p3_y_old, BLACK);         // remove previous second triangle
  gfx->drawLine (p1_x_old, p1_y_old,  p4_x_old, p4_y_old, BLACK);                                // remove previous horizontal level line
  gfx->drawLine (baro_panel_x+4, baro_panel_y+150, (baro_panel_x+150), (baro_panel_y+4), CYAN);    // draw new diagonal line
//  gfx->drawRoundRect  (minmax_panel_x, minmax_panel_y, 144,  156, 4, GREEN);                       // extreme right lower window
Please post the full error message, using code tags when you do
Which update are you talking about? Library update? Board package update? IDE update?
It would be very useful to post the full error message. If "exit status 1" is the only output, please enable verbose output during compilation, compile your code and post the result here (please do not forget to use code tags for that).
The update of IDE.
I use an existing working code and always use the library as it worked before. But also an update of the library and possibly board gives the same result.
The display now contains the code I last used, but when I compile it now I get this error. I can show an image how it works with the added code.
Still waiting to see an error message.
Sorry, but I suddenly had to fill in at work. Here is a full error message. Again, the libraries I use are the original ones that come with the display. If my other test codes give the same error messages
The error code was too long, so a file
Code-fout.txt (267,2 KB)
There are quite a few different compile errors there so I wonder if the board version being at 3.0.2 is the issue. I would drop that back to the last 2.x version and try again.
https://docs.espressif.com/projects/arduino-esp32/en/latest/migration_guides/2.x_to_3.0.html
Have now figured out what the problem is. It is not the version of the IDE but the version (update) of the boards. I have a laptop with the same IDE version, but the latest updates of the boards have not been run there. So all programs work perfectly on this. So the problem is in the updates of the boards
I have compared the settings of my laptop (code working) and my computer (status 1 error) and apparently all settings are the same. So are all the updates.
Then I deleted the version on my pc and renamed the "Arduino15" in the appdata. Then I installed the last Arduino again. (all settings were immediately in Arduino). Then the code of the ESP32S3 re-uploaded. Again status 1 error.
Very strange that everything works on the laptop with the same settings and not on the PC.
The libraries are also the same in both.
I tried the esp32 code and perfect. Problem is only with ESP32S3
In file included from e:\Arduino\libraries\Arduino_GFX-master\src/Arduino_GFX_Library.h:4,
                 from E:\Arduino\MAP WERKEND\ESP32S3_GFX_TFT_HelloWorld\HelloWorld\HelloWorld.ino:3:
e:\Arduino\libraries\Arduino_GFX-master\src/Arduino_DataBus.h:160:13: error: 'i80_device_list' has not been declared
  160 |   LIST_HEAD(i80_device_list, lcd_panel_io_i80_t)
e:\Arduino\libraries\Arduino_GFX-master\src/Arduino_DataBus.h:160:3: error: ISO C++ forbids declaration of 'LIST_HEAD' with no type [-fpermissive]
e:\Arduino\libraries\Arduino_GFX-master\src/Arduino_DataBus.h:160:48: error: expected ';' at end of member declaration
e:\Arduino\libraries\Arduino_GFX-master\src/Arduino_DataBus.h:161:3: error: 'device_list' does not name a type
  161 |   device_list; // Head of i80 device list
e:\Arduino\libraries\Arduino_GFX-master\src/Arduino_DataBus.h:195:3: error: ISO C++ forbids declaration of 'LIST_ENTRY' with no type [-fpermissive]
  195 |   LIST_ENTRY(lcd_panel_io_i80_t)
e:\Arduino\libraries\Arduino_GFX-master\src/Arduino_DataBus.h:195:32: error: expected ';' at end of member declaration
e:\Arduino\libraries\Arduino_GFX-master\src/Arduino_DataBus.h:196:3: error: 'device_list_entry' does not name a type
  196 |   device_list_entry; // Entry of i80 device list
In file included from e:\Arduino\libraries\Arduino_GFX-master\src/Arduino_GFX_Library.h:14:
e:\Arduino\libraries\Arduino_GFX-master\src/databus/Arduino_ESP32RGBPanel.h:43:3: error: 'esp_lcd_rgb_panel_frame_trans_done_cb_t' does not name a type; did you mean 'esp_lcd_panel_io_color_trans_done_cb_t'?
   43 |   esp_lcd_rgb_panel_frame_trans_done_cb_t on_frame_trans_done; // Callback, invoked after frame trans done
Very likely an issue with the new R3. Either back level your esp32 boards or wait. Here is the official doc'n Migration
I have a new 7 inch display inside the one whose code is lcd. This one does work. The problem lies in the update of the board in combination with a gfx code display
Hi @digiton1.
I'm going to ask you to provide the full verbose output you get from compiling the sketch on the laptop and on the PC.
:red_exclamation_mark: This procedure is not intended to solve the problem. The purpose is to gather more information.
Provide Output From Laptop
Please do this:
  1. Open the sketch on your laptop.
  2. Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
    The "Preferences" dialog will open.
  3. Check the box next to "Show verbose output during: ☐ compile" in the "Preferences" dialog.
  4. Click the "OK" button.
    The "Preferences" dialog will close.
  5. Select Sketch > Verify/Compile from the Arduino IDE menus.
  6. Wait for the compilation to finish.
  7. Right click on the black "Output" panel at the bottom of the Arduino IDE window.
    A context menu will open.
  8. Select Copy All from the menu.
  9. Open a forum reply here by clicking the "Reply" button.
  10. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  11. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the compilation output into the code block.
  12. Move the cursor outside of the code block markup before you add any additional text to your reply.
  13. Click the "Reply" button to post the output.
Provide Output From PC
Please do this:
  1. Open the sketch on your PC.
  6. Wait for the compilation to fail.
  7. You will see a "Compilation error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
  8. Open a forum reply here by clicking the "Reply" button.
  9. Click the <CODE/> icon on the post composer toolbar.
  10. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
  11. Move the cursor outside of the code block markup before you add any additional text to your reply.
  12. Click the "Reply" button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here.
Click here for attachment instructions
  1. Open any text editor program.
  2. Paste the copied output into the text editor.
  3. Save the file in .txt format.
  4. Open a forum reply here by clicking the "Reply" button.
  5. Click the "Upload" icon (Upload icon) on the post composer toolbar:
    The "Open" dialog will open.
  6. Select the .txt file you saved from the "Open" dialog.
  7. Click the "Open" button.
    The dialog will close.
  8. Click the "Reply" button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
Code is to long.
By this the files.
compile code pc:
fout-pc-gfx.txt (269,5 KB)
compile code laptop:
compile_laptop_gfx.txt (306,1 KB)
lib (both the same):
lib_gfx
First line on the laptop version tells you something.
Did you notice the different board package versions in the first few lines?
One solution is to roll back the version on the PC.
The other solution is to check if there is a newer version of the Arduino_GFX library that is compatible with the 3.x board package and if not, fix it yourself (possibly not for the faint hearted).
I did ask which update you were talking about. Your answer was "The update of IDE."; I doubt that that was the case, I'm sure that "update of the ESP32 board package" was the more appropriate answer :slight_smile:
I know you deleted your post.
You roll back the version of the ESP32 boards package using the board manager in the IDE. Don't run both with the newest version because the newest version is the one where you're currently experiencing the issue.
You were absolutely right. The problem is in the esp32 version 3. I'm now trying several versions where everything should work again.
I was convinced that the boards had the latest version, indeed it wasn't.
With the latest version i get also the status 1 error now.
You can study the migration guide posted by @sonofcy in post #10 to try to solve the issues. After all, you probably can't forever stick to version 2.x :wink:
Problem found. After (lib) esp32 version 2.015 the ESP32S3 (gfx) give a error.
With version 2.015 everything works.
