Problem with arduino and Ws2812
I loaded this script: Welcome m.uploadedit.com - Hostmonster.com
The problem is the effect "strobe/flashing" of the strip. This doesn't have to be there... (i tested too with fire mode and the strobe was present).
I use both fastled and neopixel library the problem is present in both library.
The video that explain the problem: https://streamable.com/r6vot
Why do that? Problem of Arduino or strip? or what?
Thanks for help and sorry for my bad english.
SimoneBrambilla:
When posting code please use the proper code tags.
When posting links please use the proper URL tags.
The video that you posted explains nothing.
There is nothing to compare it to.
There is no video of the "correct" operation.
Which Arduino Board are you using?
What is the type of the LED strip?
Which version of Arduino IDE are you using?
Which operating system are you using?
Linux, MacOSX, MS Windows, other?
Is the LED Strip being powered by the Arduino Board?
If the LED Strip is being powered by a separate external Power Supply are
the grounds of the LED Strip external Power Supply and the Arduino Board Power Supply tied together?
Do you have a diagram of the circuit that you have wired?
Sorry for that.. the problem is GND. I didn't connect the gnd of strip to gnd of arduino.
SimoneBrambilla:
I assume that the issue is now solved.
