I've just bought the Arduino Ethernet. I uploaded the Ethernet WebServer sketch and plugged it into my network.
Both leds under the ethernet jack (green and orange) light up. The LED L9 behaves strange and flickers if I touch grounded parts such as the groundshield of the jack. Sometimes the RX Led goes on and the orange Led goes off simultaneosly. Also the Wiznet IC gets "hot", about 50°C. Is that normal?
However, I tried to enter the IP in my browser, but the browser was not able to connect to it.
I would be happy if somebody knows the solution, I really don't know what could be wrong, maybe a bad board?
The IP should be in my range. I have a Netgear router, my PC and TV have IPs like 192.168.0.3, so I gave my EthernetBoard 192.168.0.15. I also took the recommended MAC (written at the bottom of the board).
The MAC and IP didn't even show of on the "attached devices" site of my router.
I also tried to use the new DHCP function in Arduino version 1.0, but the same problem as before.
The board seems not to respond the routers data (RX LED blinks, but no reaction on the TX LED).
In my previous post I mentioned the strange flicker on LED 9. is that normal, could it have to do with the problem?
Some client test code you can tweek for your setup and try.
//zoomkat 12-08-11
//simple client test
//for use with IDE 1.0
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan assigned to arduino
//byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
//byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
byte myserver[] = { 208, 104, 2, 86 }; // zoomkat web page server IP address
EthernetClient client;
void setup(){
Ethernet.begin(mac, ip);
//Ethernet.begin(mac, ip, subnet, gateway);
Serial.println("Better client test 12/01/11"); // so I can keep track of what is loaded
Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
// check for serial input
if (Serial.available() > 0) //if something in serial buffer
byte inChar; // sets inChar as a byte
inChar = Serial.read(); //gets byte from buffer
if(inChar == 'e') // checks to see byte is an e
sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
if (client.connect(myserver, 80)) { //starts client connection, checks for connection
Serial.println("connected");
client.println("GET /~shb/arduino.txt HTTP/1.0"); //download text
client.println(); //end of get request
else {
Serial.println("connection failed"); //error message if no client connect
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
char c = client.read(); //gets byte from ethernet buffer
Serial.print(c); //prints byte to serial monitor
Serial.println("disconnecting.");
Serial.println("==================");
client.stop(); //stop client
Sorry, but I can't use the arduino 1.0 ide with my ethernetboard (Thats an other problem I have, but the older version works fine for me now, so I will search the problem later)
Unless I'm mistaken, your sketch needs an internet connection to connect to your server. Sorry but I'm not ready yet to give the microcontroller access to the web. I would be glad if I get it running in my own network .
Problem solved
I don't know exactely why, but after trying it again the next day it worked.
I think the problem was the IDE. It showed "done uploading", but it wasn't uploaded. Then after reinstalling the IDE it has worked.
