I cant upload my ATmega32L with Arduino through ISP.
I uploaded ArduinoISP sketch to the Arduino board and I replaced files in arduino-0022\hardware\arduino folder by arduino-extras downloaded here http://www.avr-developers.com/corefiles/index.html
After then I copied ATmegaBOOT_168_diecimila.hex and ATmegaBOOT_168_328P.hex to arduino-0022\hardware\tools\avr\bin folder. In this folder I have started a command promt and wrote avrdude -p m32 -c avrisp -P com3 -b 19200 .
But C:\WinAVR-20100110\bin\arvdude.conf:320 unrecognized character: "a" has appeared.
A little bit progress.....avrdude.conf:332 unrecognized character: "w" has appeared. :~
I copied all giveio+avrdude.exe files from avrdude-5.11-Patch7610-win32 folder to arduino-0022/hardware/tools/avr/bin folder and replaced it.
avrdude.conf I copied to tools/avr/etc folder.
Maybe files from downloaded avrdude-5.10 folder should I copied somewhere?
If you just open a cmd.exe window and type 'avrdude.....', winblows will rightfully use the version of avrdude that is in the global path variable (maybe c:/winavr.../), so you should replace that one as well (or start the arduino one with absolute path information, which is probably more painful).
Would you mind posting exactly what you type? Including the path information... a screenshot would be best (shift + print key and then paste it into ms-paint or something like that).
I copied all files from avrdude-5.11-Patch7610-win32 folder into C:/WinAVR-20100110/bin
When I wrote avrdude -p m32 -c avrisp -P com3 -b 19200 in command promt opened from arduino-0022\hardware\tools\avr\bin a error message C:\WinAVR-20100110\bin\arvdude.conf:320 unrecognized character: "w" was showed.
Print screen here: http://img692.imageshack.us/img692/1001/beznzvuuxl.jpg
# Overall avrdude defaults
default_parallel = "lpt1";
default_serial = "com1";
# default_bitclock = 2.5
<-- this is line 320 - it is empty. There no sign of a "w" here.
# PROGRAMMER DEFINITIONS
You use the wrong .exe and .conf files… there’s no other explanation.
You are right. But I copied the same files from avrdude-5.11 folder into WinAVR main directory as well into arduino/hardware/tools/avr/bin and etc/ directory.
Watch this: http://img571.imageshack.us/img571/8811/beznzvuxd.jpg On a right monitor (the smaller one) is command promt before I replaced all files in arduino directory by WinAVR/bin files.
We have got a new error message here: stk500_getsync(): not in sync: resp=0x00
Serial link is not connected, I just tried it some time ago and a internal osc. should be in use.
I have followed this tutorial: http://arduino.cc/forum/index.php/topic,52223.0.html, but more interesting now...
I used a reset button on the arduino board and thi error has occurred: http://img191.imageshack.us/img191/2817/beznzvuqq.jpg
I reupload ArduinoISP example program (which was there before) back to the board, but still the same error message.
