I've been having issues with the serial monitor while trying to display values of analog and digital pins. It's not a specific code that is giving me an issue, but anytime I run a digital or analog read command and use Serial.print(variable) at any baud rate, the serial monitor just displays "15" or "16". It does not display the actual value or state of the pin that I am trying to read.
Hardware: generic Uno R3 board, usb connection to computer
Software: Arduino IDE 1.8.13
This is a test code that I used to confirm that the problem was not related to anything specific on other projects:
int temperature = (analogRead, A2);
pinMode(A2, INPUT);
Serial.println(temperature);
The value of the pin is now being read constantly as 0 when I have the variable "temperature" declared before loop and setup. Is this because the program is only reading the value of the A1 pin a single time and reprinting it? If so, what can I do to have the read value of the pin constantly updated and displayed on the serial monitor accordingly?
int temperature = analogRead(A1);
pinMode(A1, INPUT);
I'm not convinced the pin is ever getting read in that configuration, honestly....
Okay, no I was too curious, I went ahead and compiled that and checked the assembly listing... the analogRead() is not happening at all. That line might as well be int temperature = 0.
I am, frankly, stunned that that doesn't even generate a compiler warning... (but it doesn't, even with all warnings enabled!)... you can't call a function like that in the declaration of a global unless it's the constructor for a class. analogRead() isn't. You need to call analogRead() inside setup() or loop() or a function called by those (though, we know it's not being called before main() (which, behind the scenes, calls init() to initialize the on-chip peripherals, and then calls setup() followed by loop() repeatedly, which is what some people above seem to imagine it is doing; if you called analogRead() before init(), it would sit there spinning forever, waiting for the result ready bit to be set in the ADC status register.... whilest the ADC has not yet been turned on)...
But yeah, move the temperature=analogRead(A1) into loop; you can still declare int temperature globally, though depending on where you want to go from here you may not need to.
