hi ,
i have a problem with arduino mega 2560 that it resets it self automatically during the execution of the
program it's the first time it does that .
note , i'm using the reset button on the board to much to test my code
may be that caused this problem ?! and how can i solve it
thanks ,
Sounds like a bug in your sketch which I suggest you post here.
system
October 29, 2014, 9:21am
#3
Using it how? In conjunction with what code? And what other hardware?
You have either a software problem, a hardware problem, or a PEBKAC problem.
… or a PEBKAC problem.
They can be quite expensive to fix, I hear.
system
October 30, 2014, 12:13am
#5
My experience has been that they are not expensive to fix, but that they are the hardest to fix.
First, you have to admit you have a problem... 8)
i can find a little bit sarcasm behind ur replies
however,
i admit i had a problem , may be "PEBKAC" as google told me it means that the problem is not in the device,
the problem in the user
the problem was inadequate power of arduino , when i powered it with the required , problem disappeared .
Thanks for ur replies
system
November 2, 2014, 12:25pm
#7
If you could only find a little, I'll have to try harder. 8)
