Problem with Arduino MKR1000 on my Macbook Pro
hi guys:
I have a problem on using Arduino 1.6.10 IDE with Arduino MKR1000. I can find the Arduino MKR1000 on the board and the port. When I am trying to upload the blink example to it. It shows me this message.
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware "/Applications/Arduino.app/Contents/Java/hardware" -hardware "/Users/MikeLo/Library/Arduino15/packages" -tools "/Applications/Arduino.app/Contents/Java/tools-builder" -tools "/Applications/Arduino.app/Contents/Java/hardware/tools/avr" -tools "/Users/MikeLo/Library/Arduino15/packages" -built-in-libraries "/Applications/Arduino.app/Contents/Java/libraries" -libraries "/Users/MikeLo/Documents/Arduino/libraries" -fqbn=arduino:samd:mkr1000 -vid-pid=0X2341_0X804E -ide-version=10610 -build-path "/var/folders/_n/0t1_bg117lj9krbtsfxy010m0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "/var/folders/_n/0t1_bg117lj9krbtsfxy010m0000gn/T/arduino_modified_sketch_531354/Blink.ino"
Board mkr1000 (platform samd, package arduino) is unknown
Error compiling for board Arduino/Genuino MKR1000.
Does anyone know the solution for this problem?
Did you follow the instructions in the MKR forum section for installing the boards JSON and do the updates ?
Did you do the boards UPDATE via board manager
Should be :-
Arduino SAMD Boards (32 bits ARM Cortex-M0) 1.6.6
hackster.io - MKR1000 1.6.4-mkr02
Libs update for WiFi101 via sketches, include libraries :-
WiFi101 0.9.1
There may be newer ones but these are stable.
no worry. I have already figure out the solution this evening. Thank you so much.
