Problem with Arduino nano clone
After burned the bootloader I try to upload blink schetck but appears this message:
Arduino:1.8.10 (Windows 10), Scheda:"Arduino Nano, ATmega328P"
Lo sketch usa 924 byte (3%) dello spazio disponibile per i programmi. Il massimo è 30720 byte.
Le variabili globali usano 9 byte (0%) di memoria dinamica, lasciando altri 2039 byte liberi per le variabili locali. Il massimo è 2048 byte.
Errore durante il caricamento dello sketch
avrdude: stk500_program_enable(): unknown response=0xfc
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
Questo report potrebbe essere più ricco di informazioni abilitando l'opzione
"Mostra un output dettagliato durante la compilazione"
in "File -> Impostazioni"
I try everything but it doesn't work.
I'm sorry for rewrite but if I retry to upload :
avrdude: loadaddr(): (b) protocol error, expect=0x14, resp=0xfc
avr_read(): error reading address 0x0000
    read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
La porta seriale selezionata avrdude: stk500_recv(): programmer is not responding
 non esiste o la scheda non è connessa
(deleted)
I try and this is the result
Arduino:1.8.10 (Windows 10), Scheda:"Arduino Nano, ATmega328P (Old Bootloader)"
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x8c
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x8c
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x8c
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x8c
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x8c
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x8c
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x8c
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x8c
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x8c
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x8c
Do I need to reburn with old-bootloader?
Which bootloader did you burn to the Nano?
After burning the bootloader, did you load a sketch using the ISP programmer? If so, then you erased the bootloader.
Incidentally, you can burn the Uno bootloader to a Nano, that will give you an additional 1.5K bytes of program memory because it allocates less memory for the bootloader, but you will need to use Tools > Board > Arduino Uno for programming.
I use a nano to burn bootloader and after I use the usb cable to upload the program. My settings for burn to nano is new bootloader and arduino nano.
Yes choose old bootloader .
