I want to upload a sketch on a breadboard like this:
Everytime i want to upload iget this Error :. :
Binäre Sketchgröße: 2.648 Bytes (von einem Maximum von 30.720 Bytes)
avrdude: stk500_getsync(): not in sync: resp=0x00
I searched forums for help but install the driver and look for TX/RX bringing no help =(
Sorry for my bad English
What chip are you using to handle the serial communications to the bread board? Ex: Ft232R...
Can you see the USB connection (or the appropriate connection) under 'tools' and then 'serial' port? You should see something like "dev/tty/cu-usbmodem" etc...
If not, confirm that you can see the serial communications chip. On a Mac, go under system profiler and look at the USB connections (Command+R refreshes the list). Otherwise, on a PC there should be a device manager that you can look at.
If you can see the device there but not in the Arduino IDE, then you may need to install the correct driver.
