Problem with Aref
I am trying to get the Aref pin to work so I can scale down analog input references for better resolution. I cannot figure out what I am doing wrong here.
I am using the 3.3V supply from the Uno board through a voltage divider of 1.5M and 1K resistors. This provides around 2.19mV. I connect that to the Aref, and the GND below the Aref to the bottom of the divider. No matter what I do, I cannot read anything but 1023. I am understand the floating pin, but it doesn't go to 0 when grounded. I have tried just connecting it to the 3.3V supply directly (to AREF), and that works. I have tried INTERNAL and DEFAULT analog references, and they seem to work fine. It is only when I try and scale it down that it won't read. Also, I have tried multiple analog pins in case one was bad or something.
Divider:
Below is the code, however, I suspect there is something else going on as it work fine on a direct connection to board voltages...
Any help would be appreciated
float test;
float coeff[] = {0 , 1.978425E+2 , -2.001204E-7 , 1.036969E-11 , -2.549687E-16 ,
    3.585153E-21 , -5.344285E-26 , 5.099890E-31};    //Type J coefficients
float temp;
float temp_comp;
long time_ref;        //time to act as start time reference (milliseconds)
long time_current;
int analogpin = A1;  //analog pin to use
int analoginput = 0;  //integer value 0-1023 input from pin
void setup(){
  analogReference(EXTERNAL);  //use AREF as voltage reference
  Serial.println("Anolog input testing");
void loop(){
  delay(2000);
  time_current = millis();  //timestamp
 // analoginput = 0;
  analoginput = analogRead(analogpin); // reads analong input pin and stores to variable
  test = 0;
  temp = 0;
  temp_comp = 0;
  test = map(analoginput, 0 , 1023 , 0 , 2150); // maps 0-1023 to 0-2150 microvolts
  test = test/1000; // converts microvolts to millivolts
  temp = tc_calc(test);
  temp_comp = temp + 21.222;
  Serial.print(time_current);
  Serial.print("\t");
  Serial.print(analoginput);
  Serial.print("\t");
  Serial.print(test);
  Serial.print("\t");
  Serial.print(temp);
  Serial.print("\t");
  Serial.print(temp_comp);
  Serial.println("");
// Thermocouple Calculations
float tc_calc(float tc_mv){
  int i = 0;
     while(i <=7) {
       temp = temp + coeff[i]*pow(tc_mv,i);
       i++;
  return temp;
The voltage you applied to aref becomes the new reference... it's normal that you cannot read anything but 1023.
Take a look here : analogReference() - Arduino Reference
I am sorry, that doesn't make any sense. I am applying ~2.19mV at AREF, and grounding the analog input pin, I should get zero. When I apply 3.3V at AREF and ground the analog input pin, I get 0. Similarly, when I repeat this for 5V, I get 0. It is only when I apply the 2.2mV that I get 1023.
I forgot to mention in my first post, I tested all of this with a DVM, and I am infact getting the voltages as they should be at each pin and reference.
wdenny:
That is because you failed to study/read the datasheet about the electrical specification of the Aref pin and what's it's minimum voltage can be, approx +1.0 vdc.
Lefty
the minimum which Arduino can pick up is ~4.88mV (5/1023). If less it gets 0.
And you're saying the opposite of you first post :astonished: please be logical.
If you want to understand how ridiculous are your tests, draw a schema, it would help you :slight_smile:
I guess that is my mistake. I was relying on the Arduino reference guides and documentation. I guess maybe they should consider changes there documentation from:
As indicated:
EXTERNAL: the voltage applied to the AREF pin (0 to 5V only) is used as the reference.
to something more like (1-5V)
Indeed that tutorial is faulty.
The 1V limit for AREF is not a hard limit though - below that voltage they no longer guarantee the accuracy of the ADC.
I suspect you can try setting AREF to 0.5V and get less accurate results.
BTW the AREF input must be driven from a low impedance source, a voltage divider is not good enough.
