Problem with array and function(s)
Hello, I am new to coding on the Arduino.
My project is to have a type of autonomous miniature car, but I am having a problem with my code.
In the Scan() function an array is created called distances[]. The problem is that I want to append a variable called 'range' which is the output of the function find_range(), yet it seems to append mostly zeroes to the array when it should not be. Also, when I print 'length_distances' to the serial monitor it prints a zero. Any help or guidance as to what the problem is would be appreciated. Here is my code:
//Test with Scan
#include <AFMotor.h>
//setting pin numbers
AF_DCMotor motor1(1);
AF_DCMotor motor2(2);
AF_DCMotor motor3(3);
AF_DCMotor motor4(4);
const int trigpin_R = 53;
const int echopin_R = 51;
const int trigpin_L = 22;
const int echopin_L = 24;
//setting up other variables
int range;
long duration_R;
int distance_R;
long duration_L;
int distance_L;
int i;
int largest;
int index_largest;
int n;
//defining threshold distance in cm
const int t_d=20;
  Serial.begin(9600);           // set up Serial library at 9600 bps
  //set up sensor input, output
  pinMode(trigpin_R, OUTPUT);
  pinMode(echopin_R, INPUT);
  pinMode(trigpin_L, OUTPUT);
  pinMode(echopin_L, INPUT);
  Serial.println("Start");
  // turn on motors and set the speed of motors
  motor1.setSpeed(155);
  motor2.setSpeed(155);
  motor3.setSpeed(155);
  motor4.setSpeed(155);
  motor1.run(RELEASE);
  motor2.run(RELEASE);
  motor3.run(RELEASE);
  motor4.run(RELEASE);
//defining the function for getting the range to nearest obstacle in cm
int get_range() {
  digitalWrite(trigpin_R, LOW);
  delayMicroseconds(2);
  digitalWrite(trigpin_R, HIGH);
  delayMicroseconds(5);
  duration_R = pulseIn(echopin_R, HIGH);
  digitalWrite(trigpin_L, LOW);
  digitalWrite(trigpin_L, HIGH);
  duration_L = pulseIn(echopin_L, HIGH);
  distance_R = duration_R*0.034/2;
  //Serial.println(distance_R);
  //Serial.println("distance_R");
  distance_L = duration_L*0.034/2;
  //Serial.println(distance_L);
  //Serial.println("distance_L");
  int distance=distance_L;
  if (distance_R<distance_L){
    distance=distance_R;
  return distance;
int scan() {
  Serial.println("scan");
  int time_turning=0;
  motor1.run(FORWARD);
  motor2.run(FORWARD);
  motor3.run(BACKWARD);
  motor4.run(BACKWARD);
  delay(1500);
  int start_time=millis();
  int distances[]={};
  n=0;
  while (time_turning<3010){
    range=get_range();
    motor1.run(BACKWARD);
    motor2.run(BACKWARD);
    motor3.run(FORWARD);
    motor4.run(FORWARD);
    delayMicroseconds(9986);
    time_turning=millis()-start_time;
    distances[n]=range;
    n++;
    Serial.println(distances[n]);
  largest=distances[0];
  int length_distances = sizeof(distances)/sizeof(distances[0]);
  int largest_interval=0;
  int largest_interval_midpoint=0;
  for (int index=0; index<length_distances; index++){
    if (distances[index]>largest){
      largest=distances[index];
      index_largest=index;
      for (int i=index_largest+1;i<length_distances; i++){
        if ((distances[i]>=distances[i-1]) and (distances[i]>20)){
          continue;
        else{
          largest_interval=i-index_largest-1;
          largest_interval_midpoint=index_largest+(floor(largest_interval/2));
          index+=largest_interval;
  for(int i = 250; i < length_distances; i++)
  Serial.println(distances[i]);
  Serial.println(length_distances);
  Serial.println("index_midpoint");
  Serial.println(largest_interval_midpoint);
  //Serial.println(2000-index_largest*1);
  return (3000-(largest_interval_midpoint*10));
  range=get_range();
  while ((range)>=(t_d)){
    //Serial.print("forward");
    range=get_range();
  Serial.println(range);
  if ((range)<(t_d)){
    //Serial.println("Scan");
    int time_to_turn=scan();
    if (time_to_turn>0){
      delay(time_to_turn);
    range=get_range();
    if (range<t_d);{
      delay(1500);
      range=get_range();
int distances[]={};
because it is doing exactly what you tell it to do; is to create and empty array.
try:
int distances[10]; //create array with 10 elements
keep in mind that in C/C++ the element starts at index 0.
arduino_new:
int distances[]={};
try:
But I do want it to create an empty array and simply append to the array at the nth index starting from n=0.
For example, this code works in a simulator such as tinkercad and it prints "6":
  int distances[]={};
  distances[0]=5;
  distances[1]=6;
  Serial.println(distances[1]);
jonman5:
No can do. Unless you use dynamic memory allocation (an advanced technique), you must declare the array size at compile time.
jonman5:
the size of arrays cannot be changed in C++.
either 1) define the length of the array with the maximum elements you wish to add, or 2) look into some dynamic objects like vector.
** dynamic allocation on a micro controller is problematic, so start with (1).
gfvalvo:
Well, this compiler will allow you to create an array on the stack, e.g.:
void myFunction(size_t arrySize) {
  char myString[arrySize] = "";
BulldogLowell:
And the OP's next post would be about a "Not Declared in Scope" problem as the array would disappear once myFunction exits.
