Hello!
I writed a simple code for string to array conversion.
The raw command send perfectly, but the esp board restarts, without http response.
What is the problem with my code?
I worked a lot of hours with this.
I write in php language.
In php, this function is very simple... but in this program language is very difficult.
My unworked code:
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <IRsend.h>
#include <IRremoteESP8266.h>
#define IR_SEND_PIN D2
IRsend irsend(IR_SEND_PIN);
const char* ssid = "ssid";
const char* password = "pass";
IPAddress ip(192, 168, 0, 168);
IPAddress gateway(192, 168, 0, 1);
IPAddress subnet(255, 255, 255, 0);
ESP8266WebServer server(80);
uint16_t rawcommand[]={};
void hexsend() {}
void rawsend()
int kovetkezoindex;
int nextindex;
long szamok;
String message;
String command1=server.argName(0);
String value1=server.arg(0);
String command2=server.argName(1);
String value2=server.arg(1);
int elsoindex = value2.indexOf(',');
String cmd = value2.substring(0, elsoindex);
szamok = cmd.toInt();
rawcommand[0] = szamok;
message += rawcommand[0];
message += "\n";
int rawszama = value1.toInt();
for (int i=1; i < rawszama; i++)
if (i==1)
kovetkezoindex = value2.indexOf(',', elsoindex+1);
int utolsoindex = kovetkezoindex-elsoindex;
String cmd = value2.substring(utolsoindex, kovetkezoindex);
nextindex = kovetkezoindex+1;
rawcommand[i] = szamok;
message += rawcommand[i];
message += "\n";
else if(i==rawszama-1)
kovetkezoindex = value2.lastIndexOf(',');
String cmd = value2.substring(kovetkezoindex+1);
message += "\n";
kovetkezoindex = value2.indexOf(',', nextindex);
String cmd = value2.substring(nextindex, kovetkezoindex);
message += "\n";
irsend.sendRaw(rawcommand, rawszama, 38);
server.send(200, "text/plain", message); //Response to the HTTP request
irsend.begin();
// Initialize serial port
while (!Serial) continue;
WiFi.config(ip, gateway, subnet);
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
if (MDNS.begin("esp8266")) {
Serial.println("MDNS Responder Started");
server.begin();
Serial.println("HTTP Server Started");
server.on("/rawsend", rawsend);
server.on("/hexsend", hexsend);
server.handleClient();
The probe request:
http://192.168.0.168/rawsend?rawszama=19&value=1304,1188,494,1210,2100,1206,1306,1188,2144,1188,2144,1188,472,1206,464,2028,472,2020,492
