problem with ATmega328p
Hi, I am Using Arduino IDE-0016, When i select the board Duemilanove, i get the following error,
unknown MCU 'atmega328p' specified Known MCU names: avr2 at90s2313 at90s2323 at90s2333 at90s2343 attiny22 attiny26 at90s4414 at90s4433 at90s4434 at90s8515 at90c8534 at90s8535 attiny13 attiny2313 attiny24 attiny44 attiny84 attiny25 attiny45 attiny85 attiny261 attiny461 attiny861 at86rf401 avr3 atmega103 atmega603 at43usb320 at43usb355 at76c711 avr4 atmega8 atmega48 atmega88 atmega8515 atmega8535 at90pwm2 at90pwm3 avr5 atmega16 atmega161 atmega162 atmega163 atmega164p atmega165 atmega165p atmega168 atmega169 atmega169p atmega32 atmega323 atmega324p atmega325 atmega3250 atmega329 atmega3290 atmega406 atmega64 atmega640 atmega644 atmega644p atmega645 atmega6450 atmega649 atmega6490 atmega128 atmega1280 atmega1281 at90can32 at90can64 at90can128 at90usb646 at90usb647 at90usb1286 at90usb1287 at94k avr6 atmega2560 atmega2561 avr1 at90s1200 attiny11 attiny12 attiny15 attiny28 utility/socket.c:1: error: MCU 'atmega328p' supported for assembler only In file included from /opt/cross/lib/gcc/avr/4.1.3/../../../../avr/include/avr/pgmspace.h:81, from utility/types.h:19, from utility/socket.c:9: /opt/cross/lib/gcc/avr/4.1.3/../../../../avr/include/avr/io.h:301:6: warning: #warning "device type not defined"
i continued to compile me code, i get the error message,
avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -I/home/tenet/arduino/arduino-0016/hardware/cores/arduino /home/tenet/arduino/arduino-0016/hardware/cores/arduino/wiring_shift.c -o/tmp/build12600.tmp/wiring_shift.c.o
unknown MCU 'atmega328p' specified Known MCU names: avr2 at90s2313 at90s2323 at90s2333 at90s2343 attiny22 attiny26 at90s4414 at90s4433 at90s4434 at90s8515 at90c8534 at90s8535 attiny13 attiny2313 attiny24 attiny44 attiny84 attiny25 attiny45 attiny85 attiny261 attiny461 attiny861 at86rf401 avr3 atmega103 atmega603 at43usb320 at43usb355 at76c711 avr4 atmega8 atmega48 atmega88 atmega8515 atmega8535 at90pwm2 at90pwm3 avr5 atmega16 atmega161 atmega162 atmega163 atmega164p atmega165 atmega165p atmega168 atmega169 atmega169p atmega32 atmega323 atmega324p atmega325 atmega3250 atmega329 atmega3290 atmega406 atmega64 atmega640 atmega644 atmega644p atmega645 atmega6450 atmega649 atmega6490 atmega128 atmega1280 atmega1281 at90can32 at90can64 at90can128 at90usb646 at90usb647 at90usb1286 at90usb1287 at94k avr6 atmega2560 atmega2561 avr1 at90s1200 attiny11 attiny12 attiny15 attiny28 /home/tenet/arduino/arduino-0016/hardware/cores/arduino/wiring_shift.c:1: error: MCU 'atmega328p' supported for assembler only
Couldn't determine program size: avr-size: '/tmp/build12600.tmp/acce_test.hex': No such file
This problem is appearing only from past 3 days, earlier it was fine.The following are my observations, -problem is only with Duemilanove w/ ATmega328, others dont have any problem -I can burn bootloader for Atmega328, and it works fine, compiling and hence uploading is the problem
I use OpenSuse 11.0 and arduino IDE-16, i have installed all the required repositories. some one plz suggest me the solution.
Jai Hind
I got this error before… but I can’t recall what happened :confused:
0016? Have you tried updating to 0017? Also, have you tried more than one sketch? Rather than just more than one board?
hi captain, I have tried with multiple sketches also, i have tried with arduino 17 also
Hi, the atmega328p is newer than the OpenSuse 11.0 release so it isn't supported by the avr-gcc compiler of 11.0.
You should consider to update to OpenSuse 11.2 or you have to manually update the packages "avr-gcc" and (maybe) "avr-libc" to the most recent versions (if that is possible with OpenSuse)
The easiest (time-consuming) solution is to upgrade the distribution to 11.2.
Eberhard
You can get updated AVR rpms for openSUSE here:
http://www.arduino.cc/playground/Linux/OpenSUSE
If you should consider updating to 11.2, please DON'T use the 'update' option on the DVD! Do a fresh install, it will save you time and a big headache. I think it is worth it, as KDE4 seems to be usable for the first time. Boot-up time has been improved as well.
hi wayoda and madworm, I understand this, but i was using 328p earlier with my system, i lost that duemilanove and now i have bought a new one. i have not changed any thing in my system, but tried to patch avrdude with a new version. so do u think even in this case, your solution works.
jai hind
Well, all I can say is that I've been using the AVR repository for ages and it usually works for me. There are some issues with the 'NewSoftSerial' library, but everything else seems to work.
ok i have decided to go for suse11.2,that wil take one more day for downloading and installing. i hope that will work, so i will post the results after 24 hours.
