Hi there:
I am reading from a bluetooth connection some numbers, in this way:
252#12#1#212#
this is the code:
char input; // variable to receive data from bluetooth
char inputstring; //the string with the numbers
int dato; //the number in inputstring
if( bluetooth.available() ) // if data is available to read
input = bluetooth.read(); // read it and store it in 'input'
if (input != '#') {inputstring += input;}
else //all the number is readed
{dato = atoi(inputstring);
inputstring = ''; //the string is deleted
bluetooth.println(dato); }
the compiler says that dato = atoi(inputstring) is not correct. "Invalid conversion from 'char' to 'cont char*'.
I have changed the definition of input and stringinput with no success, for example char inputstring[4]
Any help? Thanks in advance
