Problem with avr timer for sequencing
Hello guys,
I tried to create an avr timer, reading maxembedded introduction
but I am not able to make it work.
I recreated a simple program using timers to let you know what I am trying to do.
I believe this is pretty straightforward:
my midi array is composed of 128 bytes,
I want the timer to interrupt everytime I need to send a byte.
If the 128 bytes have been read, I want to go back to the start of the sequence.
Equally, if I push start_button, I want the sequence to start at (flow = 0).
#include <Bounce2.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#define  LED  5
#define  startbutton  2
Bounce   start_button;
byte     start_at_zero = 0;
int      flow = 0;
float    clock_frequency = 0.0000625;
int      tempo = 100;
void  setup()
  Serial.begin(32500);
  pinMode(LED, OUTPUT);
  pinMode(startbutton, INPUT);
  start_button.attach(startbutton);
  start_button.interval(5);
  digitalWrite(LED, LOW);
  //Starts here..
  float   clock_frequency = 0.0000625; //16Mhz on arduino uno
    cli();
    TCCR1A = 0;
    TCCR1B = 0;
    // I set the first timer for comparison
    // (6000/tempo*4/128) = 1 mesure divided by 128 events;
    OCR1A = (6000/tempo*4/128)/clock_frequency - 1;
    // CTC mode on for second timer:
    TCCR1B |= (1 << WGM12);
    // timer compare interrupt:
    TIMSK1 |= (1 << OCIE1A);
    sei();
ISR(TIMER1_COMPA_vect)
  if (new_start == 1)
   flow = new_start = 0;
  if (flow == 0)
    digitalWrite(LED, HIGH);
  else if (flow == 64)
  flow++;
   if (flow >= 128)
       flow = 0;
void  loop()
   if (start_button.update() && start_button.read() == HIGH)
    new_start = 1;
Would you help me to find what is going wrong ?
I am pretty sure the code is "almost" good and the modification to make it work,
not huge.
Thank you !
A local variable with the same name as a global variable is NEVER a good thing.
Do you KNOW, without having to look, the order that the operands will be evaluated in? Does that result in the value that you expect in OCR1A? Use parentheses to force the operands to be evaluated in the order you expect.
Variables used in ISRs and other functions (like new_start and flow) need to be volatile.
So, where are you actually sending a byte somewhere?
Read? You said send in the previous sentence. Which is it? Where are you reading anything?
Well, I made some mistakes in copying the code:
clock_frequency is only a global variable here.
I think I know the order of operands, yes.
Here, I want to calculate the time between every note I play:
I divide a second by my tempo and multiply it by 4, to have the duration of a measure (4 times).
Then, I divide it by 128 to have the duration between every note.
So, this becomes the required delay.
Then, if I understand well, I divide it by by the clock_frequency, to have the timer count.
That way, I obtain 29.999. Is that the good way to do it ?
I am not actually reading or sending any byte in this code, but this is what I want my code to be for.
Flow is the value that would be used to read a byte in a string and send it to the midi output.
I just didn't want it to appear here not to make the code complex.
You can't write to the serial port in an ISR, so the whole timer thing is an academic exercise, isn't it?
Wow I wasn't aware of that...
But, can I still call a function which would write to the serial port ?
Anyway, if it is "only" an academic exercise, I still would like to know how to succeed with this,
as it is driving me a bit crazy right now ! :stuck_out_tongue:
Sure. As long as you don't call it from an ISR.
I don't think you've told us what the problem is.
The problem is that nothing is happening and I don't know how to test it,
as I can't print anything inside the ISR.
So, my guess is the timer is badly set up,
or the comparison between the timers never occurs, as the led never blinks.
Still, I am not able to fully understand how to set up a timer...
