problem with big stepper motor speed control
hello people , i am new guy in the arduino world and i have stuck on big stepper control speed with potensiometer , the slow speed is achieved but i can get more the half at the higher , here the code, i dont know if i have missed something , i apologise in advance if my post does not follow the forum requirements....
// Defines pins numbers
const int stepPin = 6;
const int dirPin = 7;
int customDelay,customDelayMapped; // Defines variables
// Sets the two pins as Outputs
pinMode(stepPin,OUTPUT);
pinMode(dirPin,OUTPUT);
digitalWrite(dirPin,HIGH); //Enables the motor to move in a particular direction
customDelayMapped = speedUp(); // Gets custom delay values from the custom speedUp function
// Makes pules with custom delay, depending on the Potentiometer, from which the speed of the motor depends
digitalWrite(stepPin, HIGH);
delayMicroseconds(customDelayMapped);
digitalWrite(stepPin, LOW);
// Function for reading the Potentiometer
int speedUp() {
int customDelay = analogRead(A0); // Reads the potentiometer
int newCustom = map(customDelay, 0, 1023,20,2000); // Convrests the read values of the potentiometer from 0 to 1023 into desireded delay values (300 to 4000)
return newCustom;
but as far i set the delay time manually the motor runs slow and high max speed
//int customDelay,customDelayMapped; // Defines variables
//customDelayMapped = speedUp(); // Gets custom delay values from the custom speedUp function
delayMicroseconds(20);
//int speedUp() {
//int customDelay = analogRead(A0); // Reads the potentiometer
// int newCustom = map(customDelay, 0, 1023,20,2000); // Convrests the read values of the potentiometer from 0 to 1023 into desireded delay values (20 to 2000)
//return newCustom;
Need to see datasheets for motor AND driver.
Can you explain that more precisely - what are you expected to see, v. what you actually see.
Here my nema 24 stepper motor and driver, in my potentiometer test code , the motor can not get the high revs same as when i run the simplest code where i set the delay value manually , but the slow speeds can be achieved,
MarkT:
I test my motor by setting the delay values 2000 for slow and 20 for high speed and runs ok, speeds are achieved , but the code with the potentiometer can't give me the high revs as the manual test, i checked the monitor print values snd the mapping works fine , 2000 to 20 , but the motor doesn't response to the 20 same as manually , i can say the motor achieves half top speed revs
How is your pot wired up?
What values are you getting from the analogRead?
I suspect this line is what is responsible for your results:
[color=#222222]int customDelay = analogRead(A0); // Reads the potentiometer[/color]
I think analogRead is a very slow instruction.
Maybe only read it every 64th time through the loop?
Well you clearly have a servomotor, not a stepper motor!
Anyway the issue is that its using the same step/direction interface as a stepper motor would,
which needs a high rate of pulses for a high speed. You are calling analogRead() which takes a
long time on ATmega microcontrollers - 110µs or so, limiting the pulse rate.
Your management of time is poor too - using delayMicroseconds() instead of micros(), so that
the code execution time eats into your performance.
Perhaps try replacing
by
  static unsigned long last_read= 0 ;
  if (millis() - last_read >= 20)   // only read pot occasionally
    last_read += 20 ;
  static unsigned long last_step = 0 ;
  if (micros() - last_step >= customDelayMapped)
    last_step += customDelayMapped ;  // schedule next pulse without being affected by code execution time
    delayMicroseconds(5);
MarkT:
by
   last_read += 20 ;
Thanks MarkT for youryour suggestion , it works fine , low revs high revs , ....i am mechanical engineer , i must stydy deeply the electronics, thanks for your valuable help, thank all the guys offered their help
http://www.xinhuanet.com/culture/2018-01/08/c_1122227025.htm?from=timelin
Here some youtube videos about my work on robotics animatronics
I
mayyortom:
mayyortom:
wildbill:
The wiring is same as most of cases , GND , U+ 5 to arduino , COM to A0, and when i print monitor i got the mapped values, 20, 2000 and the low revs are achieved fine, same as the manual test
vpanagiotou:
https://youtu.be/m7gl5Y-FEk8
https://youtu.be/DfIHu8HsOTc
https://youtu.be/TzNOG7NmIJU
https://youtu.be/K4Ygm8msBtQ
http://mp.weixin.qq.com/s/TR2lxFo-r6vintqYi1Pklg
Hi, again , i builta code to contor my closed servo motor with potensiometer and limit switch , but my motor runs slow , i dont know how to compile your suggestion to my application, my mechanical world seems far away from electronic world , so i need a help to sort it out
const int driverPUL = 6;    // PUL- pin
const int driverDIR = 7;    // DIR- pin
const int spd = A0;     // Potentiometer
const int limit1 = A1;
const int limit2 = A2;
// Variables
int slv;
int pd = 30;
pinMode (driverPUL, OUTPUT);
pinMode (driverDIR, OUTPUT);
pinMode (limit1,INPUT);
pinMode (limit2,INPUT);
slv=analogRead(spd);
if (slv > 575)
if (!digitalRead(limit1)){}
{ pd = map(slv,575,1023,2000,30);
digitalWrite(driverDIR,HIGH);
digitalWrite(driverPUL,HIGH);
delayMicroseconds(pd);
digitalWrite(driverPUL,LOW);
if (slv < 350)
if (!digitalRead(limit2)){}
{ pd = map(slv,350,0,2000,30);
digitalWrite(driverDIR,LOW);
I need help to compile your time delay suggestion in previous messages
int speedUp();
int customDelayMapped ;
int customDelay ;
void loop ()
static unsigned long last_read = 0;
last_read += 20 ;
static unsigned long last_step = 0;
digitalWrite(stepPin,HIGH);
delayMicroseconds(5) ;
int speedUp()
int newCustom = map(customDelay , 0, 1023, 20 ,2000);
return newCustom ;
Thanks in advance
That compiles without errors for me.
