Problem with blank screen after some minutes
Hi at all,
i'm trying to create a weather station with arduino mega, MCU 2,8 TFT and DHT11.
I used GRD, 53, 51 digital for - + signal of DHT11.
Everyting works, but after some minutes the screen become white.
Can you tell me where i'm wrong?
Thanks in advance
AC
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
#define TS_MINX 158
#define TS_MINY 148
#define TS_MAXX 922
#define TS_MAXY 958
#define YP A1 // Chip Select goes to Analog 3
#define XM A2 // Command/Data goes to Analog 2
#define YM 7 // LCD Write goes to Analog 1
#define XP 6 // LCD Read goes to Analog 0
#include <SPI.h>          // f.k. for Arduino-1.5.2
#include "Adafruit_GFX.h"// Hardware-specific library
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
//#include <Adafruit_TFTLCD.h>
#include <TouchScreen.h>
//Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
// Assign human-readable names to some common 16-bit color values:
#define  BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
int a = 0;
boolean buttonEnabled = true;
#include <DHT.h>
#include <Wire.h>
#include "i2c.h"
#include "i2c_BMP280.h"
BMP280 bmp280;
DHT dht(51, DHT11);
  Serial.println("Inizio scansione temperatura ed umidità:");
//  Serial.print("Probe BMP280: ");
//  if (bmp280.initialize()) Serial.println("Sensor found");
//  else {
//    Serial.println("Sensor missing");
//    while (1) {}
  pinMode(53, OUTPUT);        //pin 53 USCITA
  digitalWrite(53, HIGH);
  // onetime-measure:
//  bmp280.setEnabled(0);
//  bmp280.triggerMeasurement();
  dht.begin();
  tft.reset();                 //hardware reset
  uint16_t ID = tft.readID(); //
/*  Serial.print("ID = 0x");
  Serial.println(ID, HEX);
*/  if (ID == 0xD3D3) ID = 0x9481; // write-only shield
  //    ID = 0x9329;                             // force ID
  tft.begin(ID);
  tft.fillScreen(BLACK);
  tft.setRotation(1);
  tft.setCursor(0, 0);
  tft.setTextColor(WHITE);  tft.setTextSize(2);
  tft.println("Aria di Tempesta");
  tft.setTextColor(YELLOW); tft.setTextSize(2);
  tft.println("");
  tft.setTextColor(RED);    tft.setTextSize(2);
  tft.println("Temperatura e umidita'");
  tft.println();
  tft.setTextColor(GREEN);
  tft.setTextSize(3);
  tft.println(" 0C");
  tft.println(" 0%");
  //Create Red Button
  tft.fillRect(50, 180, 220, 40, RED);
  tft.drawRect(50, 180, 220, 40, WHITE);
  tft.setCursor(70, 188);
  tft.setTextSize(3);
  tft.print("Clicca qui");
    float t1 = float t = dht.readTemperature();
    float h1 = float h = dht.readHumidity();
    Serial.print("Temperatura: ");
    Serial.println(String(t) + "°C");
    Serial.println(String(t1) + "°C");
    Serial.print("Umidità: ");
    Serial.println(String(h) + "%");
    Serial.println(String(h1) + "%");
  if (t != t1 || h != h1) {
    Serial.println("Diversi");
    t = t1;
    h = h1;
  /*  bmp280.awaitMeasurement();
    float temperature;
    bmp280.getTemperature(temperature);
    float pascal;
    bmp280.getPressure(pascal);
    static float meters, metersold;
    bmp280.getAltitude(meters);
    metersold = (metersold * 10 + meters)/11;
    Serial.print(" Altezza iniziale: ");
    Serial.print(metersold);
    Serial.print(" m; Altezza: ");
    Serial.print(meters);
    Serial.print(" Pressure: ");
    Serial.print(pascal);
    Serial.print(" Pa; T: ");
    Serial.print(temperature);
    Serial.println("°C");
    tft.setRotation(1);
    tft.println("");
    tft.println();
    tft.setTextSize(3);
    tft.println(" " + String(t) + "C");
    tft.println(" " + String(h) + "%");
    //Create Red Button
    tft.setTextSize(3);
  TSPoint p = ts.getPoint();  //Get touch point
/*  if (p.z > ts.pressureThreshhold) {
    Serial.print("X = "); Serial.print(p.x);
    Serial.print("\tY = "); Serial.print(p.y);
    Serial.print("\n");
    Serial.println(map(p.x, TS_MAXX, TS_MINX, 0, 320));
    Serial.println(map(p.y, TS_MAXY, TS_MINY, 0, 240));
*/ p.x = map(p.x, TS_MAXX, TS_MINX, 0, 320);
   p.y = map(p.y, TS_MAXY, TS_MINY, 0, 240);
   if(p.x>30 && p.x<80 && p.y>35 && p.y<200 && buttonEnabled)// The user has pressed inside the red rectangle
    buttonEnabled = false; //Disable button
    //This is important, because the libraries are sharing pins
   pinMode(XM, OUTPUT);
   pinMode(YP, OUTPUT);
    //Erase the screen
    //Draw frame
    tft.fillRect(0,0,318,240,BLACK);
    tft.drawRect(0,0,318,240,WHITE);
    tft.setCursor(50,50);
    tft.setTextSize(3);
    tft.print("OK");
