Hello
Please help where as a problem my code problem if I check the thermocouple temperature my stepper motor is not working properly
[pre][color=#202124]code in the annex[/color]
[/pre]
KotolMiro.ino (3.43 KB)
Hello
[/pre]
previousMillis should be an 'unsigned long', not a long.
There are several places where you probably think you are setting the global variables 'previousMillis' and 'currentMillis' but you are actually creating a local variable of the same name and never setting the global variable.
Please format your code using the auto-format feature of the IDE.
Well this is interesting! Something happened to it in the annex, all the comments fell out and white space took there place. Post a simple schematic as well, not a frizzy thing. Show all power, ground and interconnections.
#include <Stepper.h>
#include <max6675.h>
#define iskra 13
#define plyn 12
#define thermostat 11
#define start_cyklu 10
#define ENBp A5
#define releiskra 6
#define releplyn 3
#define M1 9
#define kontrolka 4
int thermoDO = A2;
int thermoCS = A3;
int thermoCLK = A4;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
const int stepsPerRevolution = 200;
Stepper myStepper(stepsPerRevolution, 2, 7, 5, 8);
int stepCount = 0;
long previousMillis = 0;
int thermo = 1;
int teplota = thermocouple.readCelsius();
pinMode(iskra , INPUT_PULLUP);
pinMode(plyn , INPUT_PULLUP);
pinMode(thermostat , INPUT_PULLUP);
pinMode(start_cyklu , INPUT_PULLUP);
pinMode(ENBp , OUTPUT);
pinMode(releiskra , OUTPUT);
pinMode(releplyn , OUTPUT);
pinMode(M1 , OUTPUT);
pinMode(kontrolka , OUTPUT);
int sensorReading = analogRead(A0);
int sensorReading2 = analogRead(A0);
int sensorReadingV = analogRead(A1);
int motorSpeed = map(sensorReading, 0, 1023, 100, 200);
int motorSpeed2 = map(sensorReading2, 0, 1023, 50, 100);
int motorSpeedV = (sensorReadingV ) / 4;
Serial.print("C = ");
Serial.println(thermocouple.readCelsius());
if (digitalRead(iskra) == LOW) {
digitalWrite(releiskra, HIGH);
else if (digitalRead(iskra) == HIGH) {
digitalWrite(releiskra, LOW);
if (digitalRead(plyn) == LOW) {
digitalWrite(releplyn, HIGH);
else if (digitalRead(plyn) == HIGH) {
digitalWrite(releplyn, LOW);
if (digitalRead(start_cyklu) == LOW ) {
analogWrite(M1, motorSpeedV);
if (digitalRead(start_cyklu) == HIGH and (thermocouple.readCelsius() < 200.00)) {
digitalWrite(kontrolka, LOW);
else if (digitalRead(start_cyklu) == LOW and (thermocouple.readCelsius() < 200.00) and currentMillis - previousMillis > 60000){
digitalWrite(kontrolka, HIGH);
if (digitalRead(start_cyklu) == LOW and digitalRead(thermostat) == HIGH and teplota > 200 ) {// velka dávka termostat
digitalWrite(ENBp, HIGH);
myStepper.setSpeed(motorSpeed);
// step 1/100 of a revolution:
myStepper.step(stepsPerRevolution / 100);
else if (digitalRead(start_cyklu) == LOW and digitalRead(thermostat) == LOW and teplota > 200 ) { // mala dávka termostat
myStepper.setSpeed(motorSpeed2);
if (digitalRead(start_cyklu) == HIGH) {
analogWrite(M1, 0);
digitalWrite(ENBp, LOW);
[color=#202124]even when using millins (1000), the engine stops every second and then continues
code
[/color]
#define iskra 13
#define plyn 12
#define ENBp A5
#define releiskra 6
#define releplyn 3
#define M1 9
#define kontrolka 4
int thermoDO = A2;
int thermoCS = A3;
int thermoCLK = A4;
int stepCount = 0;
int thermo = 1;
if (currentMillis - previousMillis >= 1000) {
analogWrite(M1, 0);
You have
in your code so that will account for half of the problem
Check out my detailed tutorial on Multi-tasking in Arduino which includes a detailed stepper example
and the tools you need to track down your loop delay.
Also loop at How to write Timers and Delays in Arduino
You still have issues I pointed out earlier:
You still have a delay in this code. You are re-declaring 'teplota' here and it is NOT setting the global 'teplota' value.
Why are you directly reading the thermocouple here if you only want to read it every second? currentMillis - previousMillis will never be greater than 60000 since you are resetting previousMillis once per second every time you read the thermocouple.
else if (digitalRead(start_cyklu) == LOW and (thermocouple.readCelsius() < 200.00) and currentMillis - previousMillis > 60000) {
You are declaring local variables for 'previousMillis' and 'currentMillis' in the following code. This does nothing.
analogWrite(M1, 0);
You need to understanding scoping of variables in C/C++. Here is a tutorial:
