Problem with calling matrix elements
I'm very new to arduino, I thought I'd be able to pick it up quickly as I have a background in C programming. But I guess not. Anyway, I'm having problem with this bit of code:
#include <MatrixMath.h>
float qcurrent[4][1] = { {0.6},{0.8},{0},{0} };
float qcmd[4][1] = { {0} , {0} , {0} , {1} };
float q1c = qcmd[1][1];
float q2c = qcmd[2][1];
float q3c = qcmd[3][1];
float q4c = qcmd[4][1];
float qe[4][1];
float qcm[4][4] = {
  {q4c , q3c , -q2c , -q1c},
  {-q3c , q4c , q1c , -q2c},
  {q2c,-q1c,q4c,-q3c},
  {q1c,q2c,q3c,q4c}
 Matrix.Multiply((float*)qcm,(float*)qcurrent,4,4,1,(float*)qe);
// Matrix.Print((float*)qcm,4,4,".");
Serial.print(q1c);
Serial.print("\n");
Serial.print(q2c);
Serial.print("\n");
Serial.print(q3c);
Serial.print("\n");
Serial.print(q4c);
Serial.print("\n");
Serial.print("\n");
Serial.print("\n");
 delay(3000);
The problem seems to occur at these lines:
The program doesn't seem to be properly assigning the values of q1~4c for some reason.
qcurrent , qcmd and qe are 4 X 1 matrices and qe is a 4 X 4 matrix.
Thanks!
The biggest index qcmd can have is 3.
Hmm.
As AWOL pointed out, an array definition:
  • int myArray[5];*
specifies the number of elements you want for the array; 5 in this case. That is, you have defined 5 int-sized data buckets. However, the highest array index is always the number of buckets minus one, sometimes referred to as the N - 1 Rule for array definitions. So the five valid array indexes are 0 - 4, not 0 - 5.
Please tell us the error.
Unless this is a C++ thing, you cannot initialize your floats to a non compile-time constant. qcmd[1][1] is not a compile time constant. It's value is set at runtime.
Oh whoops! Totally slipped my mind, I was programming with matlab before trying Arduino. I forgot that for Arduino and C the indexing starts from 0.
Thanks for the help!
By the way, you call functions, not array elements or variables. You access them.
