Problem with Change loop to interrupt
My task is to turn all the loop code to interrupt. However, after adding the interrupt the program become not working.
Original Code
#include <Servo.h>
#define LEFT_DEFAULT {9, 5, 7, false, gate_left}
#define RIGHT_DEFAULT {10, 6, 8, false, gate_right}
//The reference position for the servo
struct Gate_Ref{
  int OPEN;
  int CLOSE;
const Gate_Ref gate_left = {130, 50}, gate_right = {90, 170};
enum State {VACANT, OCCUPIED};
struct Device {
  int pin_servo; //the motor controlling the gate.
  int pin_switch;
  int pin_indicator; //one LED, turned on when the gate is opened, turned off otherwise
  bool occupied;
  Gate_Ref ref;
  Servo servo;
Device right = RIGHT_DEFAULT;
Device left = LEFT_DEFAULT;
//Exmamine if the button is pressed, which indicates the parking slot is occcupied
//@return TRUE if the button is pressedif the button is pressed, FALSE otherwise
bool check_occupied(const int& pin_switch){
  int first = digitalRead(pin_switch); // reads LOW if the button is pressed
  delay(15);
  int second = digitalRead(pin_switch); // read second time in case of glitches
  if (first != second)
    return check_occupied(pin_switch);
    return !first; //TRUE if the button is pressed
  pinMode(right.pin_switch, INPUT_PULLUP);
  pinMode(right.pin_servo, OUTPUT);
  pinMode(right.pin_indicator, OUTPUT);
  digitalWrite(right.pin_indicator, LOW);
  right.servo.attach(right.pin_servo);
  right.servo.write(right.ref.CLOSE);
  delay(15);
  pinMode(left.pin_switch, INPUT_PULLUP);
  pinMode(left.pin_servo, OUTPUT);
  pinMode(left.pin_indicator, OUTPUT);
  digitalWrite(left.pin_indicator, LOW);
  left.servo.attach(left.pin_servo);
  left.servo.write(left.ref.CLOSE);
  delay(15);
  //Serial.begin(115200);
//Open the gate if the button state is swithced from OCCUPIED to VACANT, and close the gate automatically after 2 seconds.
void loop(){
  if (!right.occupied){
    right.occupied = check_occupied(right.pin_switch);
    if (right.occupied){
      digitalWrite(right.pin_indicator, HIGH);
      right.servo.write(right.ref.OPEN);
      delay(2000);
      delay(15);
  if (!left.occupied){
    left.occupied = check_occupied(left.pin_switch);
    if (left.occupied){
      digitalWrite(left.pin_indicator, HIGH);
      left.servo.write(left.ref.OPEN);
      delay(2000);
      delay(15);
Changed to interrupt
#include <Servo.h>
struct Gate_Ref{
  int OPEN;
  int CLOSE;
struct Device {
  int pin_switch;
  bool occupied;
  Gate_Ref ref;
  Servo servo;
  delay(15);
  delay(15);
  delay(15);
  attachInterrupt(digitalPinToInterrupt(right.pin_switch), right_trigger, CHANGE)
  attachInterrupt(digitalPinToInterrupt(left.pin_switch), left_trigger, CHANGE)
void loop(){
void right_trigger(){
      delay(2000);
      delay(15);
void left_trigger(){
    if (left.occupied){
      delay(2000);
      delay(15);
marcozzxx810:
Can you guys correct my code ....
What is wrong with it? If you don't tell us what it does, and how that differs from what you expect, there isn't a hope in hell that the changes we suggest (I'm refraining, and, believe me, that is extremely hard) will get you the improvement you want.
@PaulS
I have reposting my problem. Sorry for that
Why does this function take a reference to an int? Surely you don't expect to change the value in pin_switch.
Why does the function call itself again?
Those pin numbers are 5 and 6. Which Arduino has interrupts on those pins?
      delay(2000);
In an ISR? Dream on.
marcozzxx810:
Don't try to change all the loop code to the code for an Interrupt Service Routine.
Change the loop() code into two separate functions and use the ISR to raise a flag to let loop() know that the ISR has triggered. Then loop() can call the appropriate function. Something like this
void rightISR() {
   rightTriggerFlag == true;
  if (rightTriggerFlag
     rightTriggerFunction();
And at the end of the rightTriggerFunction() set rightTriggerFlag back to false
Note that if your functions take more than a few millisecs to complete then loop() will be unable to keep up.
Have a look at how things are done in Several Things at a Time. Note how each function runs very briefly and returns to loop() so the next one can be called. Long running processes are achieved a tiny piece at a time. And there may be dozens of calls to some functions before it is actually time for anything to happen.
...R
void rightISR() {
Oops...
Oops...
