problem with code for button and relay
Hello guys,
I have a code so when i press a button(1) my relay will switch for an given amount of seconds and a 2nd button(2) that will switch the relay for as long as the button is pressed. now the problem is button 1 works perfectly but button 2 wont work only if i press button 1 and then press button 2, only then button to will keep the relay switched for as long as it is pressed. its weird that button 2 wont switch the relay because if i press it it will light up the led of the relay but you dont hear the clicking.
could you guys lend me a hand.
this is my code btw
ps Knop = Button (knop is a dutch word)
#define Relay 10
#define Knop1 4
#define Knop2 3
 pinMode(Knop1, INPUT_PULLUP);
 pinMode(Knop2, INPUT_PULLUP);
 pinMode(Relay, OUTPUT);
  digitalWrite(Relay,HIGH);
  if (digitalRead(Knop1)== LOW){
 digitalWrite(Relay,LOW);
 delay(4000);
 if (digitalRead(Knop2)== LOW){
( digitalRead(Knop2)== HIGH);{
don't you miss a if or something and have a weird semicolon ?
how do you handle bouncing?
Your second if does not create a loop so you'll go back to the top of the loop where you do   digitalWrite(Relay, HIGH);
--> Suggest you clarify exactly what you want
