Hi, I wanted to try this interesting project I found on the Arduino project hub (I didn't write the code) but it keeps sending me the same message error (I will leave it under the code below)
This is the code:
// 20/05/2016 - Written by Matteo Pasqualin
#include <dht.h>
#include <LiquidCrystal.h>
#define DHTPIN 6 // digital pin we're connected to
#define DHTTYPE DHT11 // DHT 11 sensor
// lcd display object instance
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// dht sensor object instance
dht(DHTPIN, DHTTYPE);
// delay time settings
int stepDelay = 100;
int shortDelay = 200;
int mediumDelay = 500;
int oneSecDelay = 1000;
int longDelay = 3000;
int nCounter = 3;
// variables used in the sketch
float humidity = 0;
float tempFahr = 0;
float tempCels = 0;
float tempHeatC = 0;
float tempHeatF = 0;
float tempMIN = 0;
float tempMAX = 0;
bool isFirstExec = true;
//String txtTemp = ""; // Temperature text
//String txtUmidita = ""; // Humidity text
//String txtHeatTemp = ""; // Heat Temperature text
// ******************************************************* [LOGIC] **************************************************
// debug
void debugDataCelsius(float h, float t, float hit) {
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(t);
Serial.print(" *C ");
Serial.print("Heat Temp.: ");
Serial.print(hit, 1);
Serial.println("\t");
String getTextTemparature() {
String txt = "TEMP: ";
txt.concat(String(tempCels, 0));
txt.concat((char)223); // ASCII degree ° char http://www.rapidtables.com/code/text/ascii-table.htm
txt.concat("C");
return txt;
String getTextHumidity() {
return "UMIDITA': " + String(humidity, 0) + "%";
String getTextHeatTemp() {
String txt = "H.TEMP: ";
txt.concat(String(tempHeatC, 1));
txt.concat("C");
return txt;
String getTextMinMaxTemp() {
String txt = "MAX:";
txt.concat(String(tempMAX, 0));
txt.concat(" ");
txt.concat("MIN:");
txt.concat(String(tempMIN, 0));
return txt;
void readSensorData() {
//Serial.println("DHT11 sensor data request...");
humidity = dht.readHumidity(); // Read humidity data
tempCels = dht.readTemperature(); // Read temperature as Celsius
//tempFahr = dht.readTemperature(true); // Read temperature as Fahrenheit - not used
// Check if any reads failed and exit early (to try again).
if (isnan(humidity) || isnan(tempCels) || isnan(tempFahr)) {
//Serial.println("Failed to read from DHT sensor!");
return;
// Compute heat index in Fahrenheit (the default)
//tempHeatF = dht.computeHeatIndex(tempFahr, humidity);
// Compute heat index in Celsius (isFahreheit = false)
tempHeatC = dht.computeHeatIndex(tempCels, humidity, false);
if(isFirstExec){
tempMAX = tempMIN = tempCels;
isFirstExec = false;
// set max temp.
if (tempCels != tempMAX && tempCels > tempMAX) {
tempMAX = tempCels;
// set min temp.
if (tempCels != tempMIN && tempCels < tempMIN) {
tempMIN = tempCels;
void printLcdTemperatureRow() {
lcd.setCursor(0, 0); // moving to first row
lcd.print(getTextTemparature()); // it always prints temp. in first row
void printLcdDataRow() {
lcd.setCursor(0, 1); // moving to second row
// it checks what to print
if (nCounter == 0) {
lcd.print(getTextHumidity()); // if loop #1 it prints humidity in second row
} else if (nCounter == 1) {
lcd.print(getTextHeatTemp()); // if loop #2 it prints heat temp.
} else if (nCounter == 2) {
lcd.print(getTextMinMaxTemp()); // if loop #3 it prints min/max temp.
void scrollText(){
// scroll text to the right
for (int positionCounter = 0; positionCounter < 16; positionCounter++) {
lcd.scrollDisplayRight();
delay(stepDelay);
// ******************************************************* [SETUP] ****************************************************
// Serial.begin(9600); // debug
lcd.begin(16, 2); // set up the LCD's number of columns and rows:
dht.begin();
//Serial.println("DHT11 Started..."); // debug
// ******************************************************** [LOOP] *****************************************************
lcd.clear();
if (nCounter > 2) {
nCounter = 0; // reset counter
readSensorData(); // every 3 loops it reads data from sensor
//debugDataCelsius(humidity, tempCels, tempHeatC);
printLcdTemperatureRow();
printLcdDataRow();
delay(longDelay);
lcd.clear();
delay(mediumDelay);
printLcdDataRow();
delay(longDelay);
scrollText();
nCounter++;
delay(mediumDelay);
This is the message error that it keeps sending me:
Arduino:1.8.1 (Windows 10), Tarjeta:"Arduino/Genuino Uno"
C:\Users\Name\Documents\Arduino\sketch_apr02a\sketch_apr02a.ino:3:27: warning: extra tokens at end of #include directive
#include <LiquidCrystal.h>;
sketch_apr02a:6: error: expected unqualified-id before numeric constant
C:\Users\Name\Documents\Arduino\sketch_apr02a\sketch_apr02a.ino:13:6: note: in expansion of macro 'DHTPIN'
sketch_apr02a:6: error: expected ')' before numeric constant
C:\Users\Name\Documents\Arduino\sketch_apr02a\sketch_apr02a.ino: In function 'void readSensorData()':
sketch_apr02a:92: error: expected primary-expression before '.' token
sketch_apr02a:94: error: expected primary-expression before '.' token
sketch_apr02a:108: error: expected primary-expression before '.' token
C:\Users\Name\Documents\Arduino\sketch_apr02a\sketch_apr02a.ino: In function 'void setup()':
sketch_apr02a:170: error: expected unqualified-id before '.' token
dht.begin();
Se encontraron múltiples librerías para "dht.h"
Usado: C:\Users\Name\Documents\Arduino\libraries\DHTlib
No usado: C:\Users\Name\Desktop\Elegoo\Arduino\libraries\DHTlib
Se encontraron múltiples librerías para "LiquidCrystal.h"
Usado: C:\Users\Name\Documents\Arduino\libraries\LiquidCrystal
No usado: C:\Users\Name\Desktop\Elegoo\Arduino\libraries\LiquidCrystal
exit status 1
Here´s the link to the library I used for the DHT11 (if you need it): https://arduino-info.wikispaces.com/file/view/DHT-lib.zip/545470280/DHT-lib.zip
Any help appreciated. Thanks.
