Problem with code: if (state! = buttonState)
Hello everyone!
I am working with an Arduino Uno as an effort to learn. I'm very new to Arduino, coding, electronics in general. I've already gone through all the preloaded sketches on the Arduino program and am looking for additional practice.
I'm trying to use a string of code I copied from a blog, which is supposed to control an LED with a pushbutton. I received a code error and would really appreciate help on this.
Thanks so much! :slight_smile:
The code is
// constants will not change
const  int  buttonPin = 2; // the number of the push button pin
const  int  ledPin = 13;   // the number of the LED pin
// variables wants change
int  buttonState = 0;     // variable for reading the push button status
int  ledState = 0;        // variable for reading the LED status
int  counter = 0;         // variable for remember the number of button pressed
// the setup routine runs once you turn the device on or you press reset
void  setup ()
    // initialize the LED pin as an output
    pinMode (ledPin,  OUTPUT );
    // initialize the pushbutton pins as input and enable internal pull-up resistor
    pinMode (buttonPin,  INPUT_PULLUP );
    // initialize serial communication at 9600 bits per second
    Serial.begin (9600);
// the loop routine runs over and over again forever
void  loop ()
    // read the state of the pushbutton value
    int  state = digitalRead (buttonPin);
    // recognize state changes: button pressed and button released
        // remember new button state
        buttonState = state;
        // print out the state of the button
        Serial.print ( "2 State changed" );
        Serial.println (button state);
        // button is pressed and LED is off
        if  (buttonState ==  LOW  && ledState ==  LOW )
            // remember new LED state
            ledState =  HIGH ;
            // turn LED on
            digitalWrite (ledPin,  HIGH );
            // print out the state of the LED
            Serial.print ( "2 set high" );
            Serial.println (ledState);
            // increment number of button pressed
            counter ++;
            // print out the number of button pressed
            Serial.print ( "2 counter:" );
            Serial.println (counter);
        // button is pressed and LED is on
        else  if  (buttonState ==  LOW  && ledState ==  HIGH )
            ledState =  LOW ;
            // turn LED off
            digitalWrite (ledPin,  LOW );
            Serial.print ( "2 Set low" );
            counter ++;
        // button is released
        else  if  (buttonState ==  HIGH )
            // print out new line
            Serial.println ();
            // wait before next click is recognized
            delay (100);
The error message is
Arduino: 1.8.5 (Mac OS X), Board: "Arduino/Genuino Uno"
Build options changed, rebuilding all
/Users/acyber/Documents/Arduino/Chriga_s_button_test/Chriga_s_button_test.ino: In function 'void loop()':
Chriga_s_button_test:32: error: expected ')' before '!' token
Chriga_s_button_test:39: error: 'button' was not declared in this scope
exit status 1
option enabled in File -> Preferences.
P.S. The blog can be found at the following site (it's in German but gets translated almost instantaneously) chriga's blog: Audino - Arduino MP3-Player (5) - Knöpfe (digital)
(deleted)
'button state' and 'buttonState' aren't the same thing.
Pete
This will complie , check
void  setup ()
void  loop ()
    if  (state != buttonState)
        Serial.println (buttonState);
            ledState =  HIGH ;
            // turn LED on
            counter ++;
            ledState =  LOW ;
            // turn LED off
            counter ++;
            Serial.println ();
            delay (100);
Though I'm Curious what's the problem with this ?
spycatcher2k:
try
The problem is the space between '!' and '='
Thanks so much everyone, it worked! I was nervous posting my first post, and your quick and helpful replies have made a really positive impression on me. Thanks again!
