I wouldn't use those functions in the Arduino itself. Instead, I would create a table with a limited number of values pre-calculated from those functions and use interpolation to fill in the gaps.
For example, you could enter those equations into Excel and generate a table of, say, 33 entries for voltages starting at 0 and incrementing by 0.15625V up to 5V:
const float cgrOilPressure[] PROGMEM =
0.0, //000
0.139921181, //020
-0.046322741, //040
-0.097551793, //060
-0.035057538, //080
0.119702226, //0A0
0.345708762, //0C0
0.622987686, //0E0
0.933214267, //100
1.260318718, //120
1.591091497, //140
1.915788599, //160
2.228736851, //180
2.528939211, //1A0
2.820680063, //1C0
3.11413051, //1E0
3.425953671, //200
3.779909978, //220
4.207462472, //240
4.748382095, //260
5.451352991, //280
6.374577796, //2A0
7.586382938, //2C0
9.165823932, //2E0
11.20329067, //300
13.80111274, //320
17.07416467, //340
21.15047128, //360
26.17181297, //380
32.29433096, //3A0
39.68913265, //3C0
48.5428969, //3E0
59.05847929 //400
(Note the values were copied directly from Excel; no need for that many decimals tbh...)
The value 0.15625V was used for a specific reason. For a 5V reference and a 10-bit ADC (0x000 to 0x3FF counts inclusive), 0x15625V represents 32 ADC counts (that is: 0.15265/5.0 * 1024 == 32). This means that the entries in the table represent a value 32 ADC counts higher than the previous entry.
Consider the 10-bit value coming back from the ADC. The count would go:
0b000 0000 0000 0x000
0b000 0010 0000 0x020
0b000 0100 0000 0x040
0b000 0110 0000 0x060
0b011 1110 0000 0x3E0
0b100 0000 0000 0x400 <-- not actually used; just frames the end of the table
We can actually index into that table using the upper 5 bits of the ADC result. This also means we have 5 bits in the ADC result (able to range from 0x00 to 0x1f) "between" entries into the table and we can use a linear method to interpolate between two adjacent points in the table.
For example, suppose the ADC result came back at as 0x2A2:
0x2A2 == 0b1010100010
0b1010100010
+++++ upper five bits gives index into table; here 15h or 21d
0b1010100010
- lower 5 bits give "fractional remainder"; here 2h (2d)
The fractional remainder can range from 0b00000 (00h) to 0b11111 (1Fh). On that next ADC tick, we get to the next entry in the table and the remainder count goes back to 00h.
In the example of 0x2A2, we are looking at the 21st entry into the table and the remainder is 2; the fraction is 2/32 or 0.0625 of the way to the next entry in the table.
If we look at the table we see the value there is 6.374577796 and the next value is 7.586382938.
The difference between the next and the current is 7.586382938 - 6.374577796 or 1.211805142.
If we multiply that value by our fractional remainder of 0.0625 we get 0.07574... We can add that value to the 21st entry in the table to get an interpolated value of 6.4503...
Here's an example in use:
#include <avr/pgmspace.h>
0.0, //000 0
0.139921181, //020 1
-0.046322741, //040 2
-0.097551793, //060 3
-0.035057538, //080 4
0.119702226, //0A0 5
0.345708762, //0C0 6
0.622987686, //0E0 7
0.933214267, //100 8
1.260318718, //120 9
1.591091497, //140 10
1.915788599, //160 11
2.228736851, //180 12
2.528939211, //1A0 13
2.820680063, //1C0 14
3.11413051, //1E0 15
3.425953671, //200 16
3.779909978, //220 17
4.207462472, //240 18
4.748382095, //260 19
5.451352991, //280 20
6.374577796, //2A0 21
7.586382938, //2C0 22
9.165823932, //2E0 23
11.20329067, //300 24
13.80111274, //320 25
17.07416467, //340 26
21.15047128, //360 27
26.17181297, //380 28
32.29433096, //3A0 29
39.68913265, //3C0 30
48.5428969, //3E0 31
59.05847929 //400 32
const uint8_t pinOilPressure;
pinMode( pinOilPressure, INPUT );
}//setup
uint16_t valOP = analogRead( pinOilPressure );
Serial.print( "ADC : " ); Serial.print( valOP, HEX );
Serial.write( '\t');
Serial.print( "Oil Press.: " ); Serial.println( fInterp( valOP, cgrOilPressure ) , 4 );
delay(250);
}//loop
float fInterp( uint16_t counts, const float *fTable )
uint8_t
idx = (uint8_t)(counts >> 5);
uint8_t
interp = (uint8_t)counts & 0x1f;
float v1 = pgm_read_float( fTable + idx );
float v2 = pgm_read_float( fTable + idx + 1 );
return (v1 + (((v2 - v1) * (float)interp) / (float)32));
}//fInterp
This generates the following with A0 connected to 3.3V on the Mega:
ADC : 2A1 Oil Press.: 6.4124
ADC : 2A2 Oil Press.: 6.4503
ADC : 2A3 Oil Press.: 6.4882
Using canned-data and interpolation is how auto manufacturers do it (well, when I was reverse engineering PCMs back in the 1990s that's how they did it, when computing speed and memory were very low). In those days they'd use fixed-point math; there was no need for 4 or more decimal places; I used floats here because it's easy and the processor is reasonably quick. YMMV.
