I'm working on a project. I used an old code witch was working and added 4 relays and 4 switches. Unfortunately the code is working anymore. Does someone has a clue why?
#define CLOSED LOW
#define OPENED HIGH
#define ENABLED true
#define DISABLED false
#define PUMPon LOW
#define PUMPoff HIGH
boolean switch1Flag = !ENABLED;
boolean switch2Flag = !ENABLED;
boolean switch3Flag = !ENABLED;
boolean switch4Flag = !ENABLED; //valve
boolean switch5Flag = !ENABLED; //valve
boolean switch6Flag = !ENABLED; //valve
byte lastSwitch1State = OPENED;
byte lastSwitch2State = OPENED;
byte lastSwitch3State = OPENED;
byte lastSwitch4State = OPENED; //valve
byte lastSwitch5State = OPENED; //valve
byte lastSwitch6State = OPENED; //valve
byte pump1State = PUMPoff;
byte pump2State = PUMPoff;
byte pump3State = PUMPoff;
byte pump4State = PUMPoff; //valve
byte pump5State = PUMPoff; //valve
byte pump6State = PUMPoff; //valve
const byte pump1Relay = 3;
const byte pump2Relay = 4;
const byte pump3Relay = 5;
const byte pump4Relay = 6; //valve
const byte pump5Relay = 1; //valve
const byte pump6Relay = 2; //valve
const byte SWITCH1 = 7;
const byte SWITCH2 = 10;
const byte SWITCH3 = 9;
const byte SWITCH4 = 8; //valve
const byte SWITCH5 = 11; //valve
const byte SWITCH6 = 12; //valve
const byte heartbeatLED = 13;
//timing stuff
unsigned long pump1Millis;
unsigned long pump2Millis;
unsigned long pump3Millis;
unsigned long pump4Millis; //valve
unsigned long pump5Millis; //valve
unsigned long pump6Millis; //valve
unsigned long heartbeatMillis;
unsigned long switchMillis;
unsigned long pump1_interval;
unsigned long pump2_interval;
unsigned long pump3_interval;
unsigned long pump4_interval; //valve
unsigned long pump5_interval; //valve
unsigned long pump6_interval; //valve
// PUMP 1 right
const unsigned long pump1_ON_time = 1000;
const unsigned long pump1_OFF_time = 4000;
// PUMP 2 left
const unsigned long pump2_ON_time = 9000;
const unsigned long pump2_OFF_time = 3000;
// PUMP 3 left
const unsigned long pump3_ON_time = 1000;
const unsigned long pump3_OFF_time = 1400;
// PUMP 4 (Valve)
const unsigned long pump4_ON_time = 1500; //valve // geschlosse lampe aus (switch need to be on o)
const unsigned long pump4_OFF_time = 1000; //valve // offen lampe an
// PUMP 5 (Valve)
const unsigned long pump5_ON_time = 1000; //valve
const unsigned long pump5_OFF_time = 1400; //valve
// PUMP 6 (Valve)
const unsigned long pump6_ON_time = 1000; //valve
const unsigned long pump6_OFF_time = 1400; //valve
pinMode(heartbeatLED, OUTPUT);
pinMode(pump1Relay, OUTPUT);
pinMode(pump2Relay, OUTPUT);
pinMode(pump3Relay, OUTPUT);
pinMode(pump4Relay, OUTPUT);
pinMode(pump5Relay, OUTPUT);
pinMode(pump6Relay, OUTPUT);
pinMode(SWITCH1, INPUT_PULLUP);
pinMode(SWITCH2, INPUT_PULLUP);
pinMode(SWITCH3, INPUT_PULLUP);
pinMode(SWITCH4, INPUT_PULLUP);
pinMode(SWITCH5, INPUT_PULLUP);
pinMode(SWITCH6, INPUT_PULLUP);
digitalWrite(pump1Relay, PUMPoff);
pump1_interval = pump1_OFF_time;
digitalWrite(pump2Relay, PUMPoff);
pump2_interval = pump2_OFF_time;
digitalWrite(pump3Relay, PUMPoff);
pump3_interval = pump3_OFF_time;
digitalWrite(pump4Relay, PUMPoff);
pump4_interval = pump4_OFF_time;
digitalWrite(pump5Relay, PUMPoff);
pump5_interval = pump5_OFF_time;
digitalWrite(pump6Relay, PUMPoff);
pump6_interval = pump6_OFF_time;
} //END of setup()
//************************************* h e a r t b e a t T I M E R
//to see if the sketch is blocking,
//toggle the heartbeat LED every 500ms
if (millis() - heartbeatMillis >= 500)
//restart the TIMER
heartbeatMillis = millis();
//toggle the LED
digitalWrite(heartbeatLED, !digitalRead(heartbeatLED));
//************************************* c h e c k S w i t c h T I M E R
//is it time to read the switches ?
if (millis() - switchMillis >= 50)
//restart the TIMER
switchMillis = millis();
checkSwitches();
//************************************* P U M P 1
//if the switch is 'not enabled' proceed with autmatic operation
if (switch1Flag == !ENABLED)
//*********************************** p u m p 1 T I M E R
//is it time to toggle the pump relay ?
if (millis() - pump1Millis >= pump1_interval)
//restart the TIMER
pump1Millis = millis();
//is pump1 now OFF ?
if (pump1State == PUMPoff)
digitalWrite(pump1Relay, PUMPon);
pump1State = PUMPon;
pump1_interval = pump1_ON_time;
} //END of if(switch1Flag == !ENABLED)
//************************************* P U M P 2
if (switch2Flag == !ENABLED)
//*********************************** p u m p 2 T I M E R
if (millis() - pump2Millis >= pump2_interval)
//restart the TIMER
pump2Millis = millis();
//is pump2 now OFF ?
if (pump2State == PUMPoff)
digitalWrite(pump2Relay, PUMPon);
pump2State = PUMPon;
pump2_interval = pump2_ON_time;
} //END of if(switch2Flag == !ENABLED)
} //END of loop()
//************************************* P U M P 3
if (switch3Flag == !ENABLED)
//*********************************** p u m p 3 T I M E R
if (millis() - pump3Millis >= pump3_interval)
//restart the TIMER
pump3Millis = millis();
//is pump3 now OFF ?
if (pump3State == PUMPoff)
digitalWrite(pump3Relay, PUMPon);
pump3State = PUMPon;
pump3_interval = pump3_ON_time;
} //END of if(switch3Flag == !ENABLED)
} //END of loop()
//************************************* P U M P VALVE 4
if (switch4Flag == !ENABLED)
//*********************************** p u m p 4 T I M E R
if (millis() - pump4Millis >= pump4_interval)
//restart the TIMER
pump4Millis = millis();
//is pump4 now OFF ?
if (pump4State == PUMPoff)
digitalWrite(pump4Relay, PUMPon);
pump4State = PUMPon;
pump4_interval = pump4_ON_time;
} //END of if(switch4Flag == !ENABLED)
} //END of loop()
//************************************* P U M P VALVE 5
if (switch5Flag == !ENABLED)
//*********************************** p u m p 5 T I M E R
if (millis() - pump5Millis >= pump5_interval)
//restart the TIMER
pump5Millis = millis();
//is pump5 now OFF ?
if (pump5State == PUMPoff)
digitalWrite(pump5Relay, PUMPon);
pump5State = PUMPon;
pump5_interval = pump5_ON_time;
} //END of if(switch5Flag == !ENABLED)
} //END of loop()
//************************************* P U M P VALVE 6
if (switch6Flag == !ENABLED)
//*********************************** p u m p 6 T I M E R
if (millis() - pump6Millis >= pump6_interval)
//restart the TIMER
pump6Millis = millis();
//is pump6 now OFF ?
if (pump6State == PUMPoff)
digitalWrite(pump6Relay, PUMPon);
pump6State = PUMPon;
pump6_interval = pump6_ON_time;
} //END of if(switch6Flag == !ENABLED)
} //END of loop()
void checkSwitches()
//********************************************* S W I T C H 1
//SWITCH1 code
byte currentState = digitalRead(SWITCH1);
//was there a change in state ?
if (lastSwitch1State != currentState)
//update to the new state
lastSwitch1State = currentState;
//********************** C L O S E D
//is the switch closed ?
if (currentState == CLOSED)
//allow manual switch bypass
switch1Flag = ENABLED;
//********************** O P E N E D
//the switch is opened
//cancel manual switch bypass
switch1Flag = DISABLED;
} //END of SWITCH1 code
//********************************************* S W I T C H 2
//SWITCH2 code
currentState = digitalRead(SWITCH2);
if (lastSwitch2State != currentState)
lastSwitch2State = currentState;
switch2Flag = ENABLED;
switch2Flag = DISABLED;
} //END of SWITCH2 code
//********************************************* S W I T C H 3
//SWITCH3 code
currentState = digitalRead(SWITCH3);
if (lastSwitch3State != currentState)
lastSwitch3State = currentState;
switch3Flag = ENABLED;
switch3Flag = DISABLED;
} //END of SWITCH3 code
//********************************************* S W I T C H 4
//SWITCH4 code
currentState = digitalRead(SWITCH4);
if (lastSwitch4State != currentState)
lastSwitch4State = currentState;
switch4Flag = ENABLED;
switch4Flag = DISABLED;
} //END of SWITCH4 code
//********************************************* S W I T C H 5
//SWITCH5 code
currentState = digitalRead(SWITCH5);
if (lastSwitch5State != currentState)
lastSwitch5State = currentState;
switch5Flag = ENABLED;
switch5Flag = DISABLED;
} //END of SWITCH5 code
//********************************************* S W I T C H 6
//SWITCH6 code
currentState = digitalRead(SWITCH6);
if (lastSwitch6State != currentState)
lastSwitch6State = currentState;
switch6Flag = ENABLED;
switch6Flag = DISABLED;
} //END of SWITCH6 code
//********************************************* o t h e r S w i t c h e s
//next switch code
} //END of checkSwitches()
