Hello,
Can anyone spot the error in this code? The buzzer on D7 don't work, and I need to hold the button down for 5 seconds for it to change levels... I shold change levels with only a push... If you hold the button for 5 seconds it should turn D7 true untill you push the button again..
int buttonSensor = analogRead(A1);
int countbuttonsec = 0;
int level = 0;
bool levelon = false;
const int ledPin = 3;
const int relaisPin = 7;
#define NOTE_G3 196
pinMode(ledPin, OUTPUT);
pinMode(relaisPin, OUTPUT);
// Convert the analog reading (which goes from 0 - 1023 er 40) to a voltage (0 - 5V):
if (buttonSensor > 961) {
countbuttonsec++;
if (countbuttonsec == 1){
if (level == 0){
digitalWrite(ledPin, HIGH);
buzz();
digitalWrite(ledPin, LOW);
level1();
level++;
else if (level == 1){
buzz();
delay(10000);
buzz();
level2();
level++;
else if (level == 2){
buzz();
buzz();
buzz();
level3();
level++;
else if (level == 3){
buzz();
buzz();
buzz();
buzz();
level4();
level++;
else if (level == 4){
buzz();
delay(300);
delay(300);
buzz();
delay(300);
delay(300);
buzz();
delay(300);
level = 0;
else if(countbuttonsec > 5000){
buzz();
buzz();
buzz();
if (level != 5){
digitalWrite(relaisPin, 250);
level = 5;
else{
digitalWrite(relaisPin, 0);
delay(200);
level = 0;
else{
countbuttonsec = 0;
if (level > 0){
if (level == 1){
level1();
level2();
level3();
level4();
// print out the value you read:
void level1(){
//levelon = true;
delay(1500);
delay(5000);
//levelon = false
void level2(){
//levelon = true;
delay(1500);
delay(10000);
//levelon = false
void level3(){
//levelon = true;
delay(1500);
delay(150000);
//levelon = false
void level4(){
//levelon = true;
delay(1500);
delay(200000);
//levelon = false
void buzz(){
tone(8, NOTE_G3, 0.2);
