Problem with code
Hi, I'm trying to do something when I give it 5 volts to let the LED light up and the column to sound, but I have a code problem
int piezoPin = 8;
int  VoltageLevel = analogRead(A0);
if (VoltageLevel >= triggerLevel){
digitalWrite(13, HIGH);
tone(piezoPin, 1000);
else {
digitalWrite (13, LOW);
tone(piezoPin, 0);
and gives me this error
 error: 'triggerLevel' was not declared in this scope
exit status 1
please help
That doesn't look like a complete sketch.
Where do you declare triggerLevel?
You need to define triggerLevel somewhere, for example before the setup
int triggerLevel = 127; // <-- put your own value here
lesept:
thank you
Art69itech:
thank you
So, the lesson is:
A variable must be declared and defined before it is used in a sketch/program.
