Hi gys please help me ![]()
void softInterr()
// Reading from first ultrasonic sensor
digitalWrite(triggerpin1, LOW);
delayMicroseconds(2);
digitalWrite(triggerpin1, HIGH);
delayMicroseconds(10);
time = pulseIn(echopin1, HIGH);
S1= time0.034/2;
// Reading from second ultrasonic sensor
digitalWrite(triggerpin2, LOW);
digitalWrite(triggerpin2, HIGH);
time = pulseIn(echopin2, HIGH);
S2= time0.034/2;
// Reading from third ultrasonic sensor
digitalWrite(triggerpin3, LOW);
digitalWrite(triggerpin3, HIGH);
time = pulseIn(echopin3, HIGH);
S3= time0.034/2;
// Reading from fourth ultrasonic sensor
digitalWrite(triggerpin4, LOW);
digitalWrite(triggerpin4, HIGH);
time = pulseIn(echopin4, HIGH);
S4= time0.034/2;
// Print distance values on serial monitor for debugging
Serial.print("S1: ");
Serial.print(S1);
Serial.print(" S2: ");
Serial.print(S2);
Serial.print(" S3: ");
Serial.print(S3);
Serial.print(" S4: ");
Serial.println(S4);
void signal1Function()
Serial.println("1");
low();
// Make RED LED LOW and make Green HIGH for 5 seconds
digitalWrite(signal1[0], LOW);
digitalWrite(signal1[2], HIGH);
delay(redDelay);
// if there are vehicels at other signals
if(S2<t || S3<t || S4<t)
// Make Green LED LOW and make yellow LED HIGH for 2 seconds
digitalWrite(signal1[2], LOW);
digitalWrite(signal1[1], HIGH);
delay(yellowDelay);
void signal2Function()
Serial.println("2");
low();
digitalWrite(signal2[0], LOW);
digitalWrite(signal2[2], HIGH);
delay(redDelay);
if(S1<t || S3<t || S4<t)
digitalWrite(signal2[2], LOW);
digitalWrite(signal2[1], HIGH);
delay(yellowDelay);
void signal3Function()
Serial.println("3");
low();
digitalWrite(signal3[0], LOW);
digitalWrite(signal3[2], HIGH);
delay(redDelay);
if(S1<t || S2<t || S4<t)
digitalWrite(signal3[2], LOW);
digitalWrite(signal3[1], HIGH);
delay(yellowDelay);
void signal4Function(){
Serial.println("4");
low();
digitalWrite(signal4[0], LOW);
digitalWrite(signal4[2], HIGH);
delay(redDelay);
if(S1<t || S2<t || S3<t)
digitalWrite(signal4[2], LOW);
digitalWrite(signal4[1], HIGH);
delay(yellowDelay);
// Function to make all LED's LOW except RED one's.
void low(){
for(int i=1; i<3; i++)
digitalWrite(signal1*, LOW);*
_ digitalWrite(signal2*, LOW);_
_ digitalWrite(signal3, LOW);
digitalWrite(signal4, LOW);
for(int i=0; i<1; i++)
digitalWrite(signal1, HIGH);
digitalWrite(signal2, HIGH);
digitalWrite(signal3, HIGH);
digitalWrite(signal4, HIGH);
Error:
C:\Users\HP\Desktop\LEVEL-10\Senoir_Project_2\Code\STCSProject\STCSProject.ino: In function 'void softInterr()':
STCSProject:58:1: error: a function-definition is not allowed here before '{' token
STCSProject:80:14: error: a function-definition is not allowed here before '{' token
STCSProject:104:1: error: a function-definition is not allowed here before '{' token
STCSProject:128:1: error: a function-definition is not allowed here before '{' token
STCSProject:175:1: error: a function-definition is not allowed here before '{' token
STCSProject:192:1: error: a function-definition is not allowed here before '{' token
STCSProject:207:1: error: a function-definition is not allowed here before '{' token
STCSProject:220:23: error: a function-definition is not allowed here before '{' token
STCSProject:235:11: error: a function-definition is not allowed here before '{' token
void low(){
Using library TimerOne in folder: C:\Users\HP\Documents\Arduino\libraries\TimerOne (legacy)
exit status 1
a function-definition is not allowed here before '{' token_
