problem with coding mega arduino
I am trying to do a code using mega 2560 arduino to generate Pulse Width Modulation(PWM) with 4 KHZ and also I want to be able to change the duty cycle of PWM through the code. could you please help with that. This is my code. I feel it is not the write code. please let me know if there is a simpler way to do the code.
boolean toggle2 = 0;
int LedPin = 11;
pinMode (LedPin, OUTPUT); // set pin 11 as output (the LED pin)
//int myprescaler = 6;
// initialize timer1
noInterrupts(); // disable all interrupts
TCCR2A = 0;
TCCR2B = 0;
TCNT2 = 0;
OCR2A = 249; // compare match register
TCCR2A |= (1 << WGM21); // CTC mode
//TCCR1B |= myprescaler;
TCCR2B |= (1 << CS11);
TIMSK2 |= (1 << OCIE2A); // enable timer compare interrupt
interrupts(); // enable all interrupts
ISR(TIMER2_COMPA_vect){//timer1 interrupt 8kHz toggles pin 9
//generates pulse wave of frequency 8kHz/2 = 4kHz (takes two cycles for full wave- toggle high then toggle low)
if (toggle2){
digitalWrite(11,HIGH);
toggle2 = 0;
else{
digitalWrite(11,LOW);
toggle2 = 1;
int LedPin = 11;
//analogWrite (LedPin,127); // sets brightness (voltage) to i
for (int i=10; i<=204; i=i+2) // increasing i value ()
// 204 in PWM represents 4V (max volts to get me Imax = 8mA)
// 51 in PWM represents 1V (min volts i want… Imin = 2mA)
// Serial.println (analogRead(LedPin));
delay (1);
for (int j=204; j>=25; j=j-2) // decreasing j value
analogWrite (LedPin,j);
//Serial.println (analogRead(LedPin));
delay (1);
Your other post here. Posting the same question in more than one place is cross posting. Don't cross post. Please read the "how to use the forum" stickies to see how to format and post code.
