Problem with coding
Hello does anyone know how we can find code to make a motor run on a timer. Also if anyone knows how to find the setup for that like how the bread board is setup and how the stuff is plugged into the arduino would be great. Finally does anyone know how to run the code and save it so that we can access it again later.
Thanks, eaweiss9
So you don't have a problem with coding, you just want someone else to do all the work for you, even learning the basics like how to load a sketch and run a program? Good luck with that. Why don't you try doing a little bit of reading on this site first and see if you can't at least answer some of this yourself.
Try starting with this link. Hopefully from there you will see what you need to do to find the other answers.
