Problem with COM5
Hello
My Arduino has COM5 and always says can't open device "\.\COM2->COM3": and I select the correct port and Aduino (UNO).
Thanks.
Hi! could you tell us the OS and browser you are using.
A screenshot with the output will also be really appreciated!
Hi !!!!
Thanks for reply :).
My OS is Windows 7, 64 bits and browser is Chrome Versión 49.0.2623.87 m.
I attach some images with the process in order by image name.
This is the output error:
Warning: platform.txt from core 'Arduino AVR Boards' contains deprecated recipe.preproc.macros="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags}
Using library Stepper at version 1.1.2 in folder: /usr/src/arduino/libraries/Stepper
avrdude: ser_open(): can't open device "\.\COM2->COM3": El sistema no puede encontrar el archivo especificado.
avrdude done. Thank you.
Could not program the board
Thanks.
WOA this looks really wrong! Thank you so much for reporting this.
A few questions to help us debug this issue:
  • are you using an original UNO board or a compatible?
  • what happens when you connect your board to your PC via serial, do you get a notification on the top right of the IDE?
You should be seeing just ONE Uno and it should be recognised as a UNO not as a generic board.
It would be really helpful if you could post in this thread the output of the plugin, reachable from the tray icon (see attachment).
Thanks!
