Problem with compiling MySensors Gateway code
I have a problem with compiling GatewaySerial code for my Arduino Leonardo
* The MySensors Arduino library handles the wireless radio link and protocol
* between your home built sensors/actuators and HA controller of choice.
* The sensors forms a self healing radio network with optional repeaters. Each
* repeater and gateway builds a routing tables in EEPROM which keeps track of the
* network topology allowing messages to be routed to nodes.
* Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
* Copyright (C) 2013-2015 Sensnology AB
* Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
* Documentation: http://www.mysensors.org
* Support Forum: http://forum.mysensors.org
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License
* version 2 as published by the Free Software Foundation.
* DESCRIPTION
* The ArduinoGateway prints data received from sensors on the serial link.
* The gateway accepts input on seral which will be sent out on radio network.
* The GW code is designed for Arduino Nano 328p / 16MHz
* Wire connections (OPTIONAL):
* - Inclusion button should be connected between digital pin 3 and GND
* - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
* LEDs (OPTIONAL):
* - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
* - RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
* - TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
* - ERR (red) - fast blink on error during transmission error or recieve crc error
// Enable debug prints to serial monitor
#define MY_DEBUG
// Enable and select radio type attached
#define MY_RADIO_NRF24
//#define MY_RADIO_NRF5_ESB
//#define MY_RADIO_RFM69
//#define MY_RADIO_RFM95
// Set LOW transmit power level as default, if you have an amplified NRF-module and
// power your radio separately with a good regulator you can turn up PA level.
#define MY_RF24_PA_LEVEL RF24_PA_LOW
// Enable serial gateway
#define MY_GATEWAY_SERIAL
// Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
#if F_CPU == 8000000L
#define MY_BAUD_RATE 38400
#endif
// Enable inclusion mode
#define MY_INCLUSION_MODE_FEATURE
// Enable Inclusion mode button on gateway
//#define MY_INCLUSION_BUTTON_FEATURE
// Inverses behavior of inclusion button (if using external pullup)
//#define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP
// Set inclusion mode duration (in seconds)
#define MY_INCLUSION_MODE_DURATION 60
// Digital pin used for inclusion mode button
//#define MY_INCLUSION_MODE_BUTTON_PIN  3
// Set blinking period
#define MY_DEFAULT_LED_BLINK_PERIOD 300
// Inverses the behavior of leds
//#define MY_WITH_LEDS_BLINKING_INVERSE
// Flash leds on rx/tx/err
// Uncomment to override default HW configurations
//#define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
//#define MY_DEFAULT_RX_LED_PIN  6  // Receive led pin
//#define MY_DEFAULT_TX_LED_PIN  5  // the PCB, on board LED
#include <MySensors.h>
	// Setup locally attached sensors
void presentation()
	// Present locally attached sensors
	// Send locally attached sensor data here
It gives me an error message:
In file included from /home/szymex/Arduino/libraries/MySensors/hal/architecture/AVR/MyHwAVR.cpp:20:0,
                 from /home/szymex/Arduino/libraries/MySensors/MySensors.h:64,
                 from /home/szymex/Arduino/libraries/MySensors/examples/GatewaySerial/GatewaySerial.ino:86:
/home/szymex/Arduino/libraries/MySensors/core/MyTransport.cpp: In function 'bool transportAssignNodeID(uint8_t)':
/home/szymex/Arduino/libraries/MySensors/hal/architecture/AVR/MyHwAVR.h:54:82: error: 'eeprom_update_byte' was not declared in this scope
 #define hwWriteConfig(__pos, __val) eeprom_update_byte((uint8_t*)(__pos), (__val))
/home/szymex/Arduino/libraries/MySensors/core/MyTransport.cpp:503:3: note: in expansion of macro 'hwWriteConfig'
   hwWriteConfig(EEPROM_NODE_ID_ADDRESS, newNodeId);
/home/szymex/Arduino/libraries/MySensors/core/MyTransport.cpp: In function 'void transportSetRoute(uint8_t, uint8_t)':
/home/szymex/Arduino/libraries/MySensors/core/MyTransport.cpp:1065:2: note: in expansion of macro 'hwWriteConfig'
  hwWriteConfig(EEPROM_ROUTES_ADDRESS + node, route);
/home/szymex/Arduino/libraries/MySensors/core/MySensorsCore.cpp: In function 'void _begin()':
/home/szymex/Arduino/libraries/MySensors/core/MySensorsCore.cpp:140:2: note: in expansion of macro 'hwWriteConfig'
  hwWriteConfig(EEPROM_PARENT_NODE_ID_ADDRESS, MY_PARENT_NODE_ID);
/home/szymex/Arduino/libraries/MySensors/core/MySensorsCore.cpp: In function 'bool _processInternalMessages()':
/home/szymex/Arduino/libraries/MySensors/hal/architecture/AVR/MyHwAVR.h:56:114: error: 'eeprom_update_block' was not declared in this scope
 #define hwWriteConfigBlock(__buf, __pos, __length) eeprom_update_block((void*)(__buf), (void*)(__pos), (__length))
/home/szymex/Arduino/libraries/MySensors/core/MySensorsCore.cpp:415:4: note: in expansion of macro 'hwWriteConfigBlock'
    hwWriteConfigBlock((void*)&_coreConfig.controllerConfig, (void*)EEPROM_CONTROLLER_CONFIG_ADDRESS,
/home/szymex/Arduino/libraries/MySensors/core/MySensorsCore.cpp: In function 'void saveState(uint8_t, uint8_t)':
/home/szymex/Arduino/libraries/MySensors/core/MySensorsCore.cpp:499:2: note: in expansion of macro 'hwWriteConfig'
  hwWriteConfig(EEPROM_LOCAL_CONFIG_ADDRESS+pos, value);
exit status 1
Including avr/eeprom.h and/or EEPROM.h doesn’t help.
And please don’t say that I should ask for help on MySensord forum because I already made a thread there and noone responded
