Problem with configuring DAC on ESP32
Hi guys!
I'm just trying to use the DAC on an ESP32 (Pico) as a "PWM" source. The usage is defined here: Digital To Analog Converter - ESP32 - — ESP-IDF Programming Guide latest documentation (espressif.com) with the Arduino IDE 2.0
Right now I have the following code which compiles properly (I was not able to test it on a device yet):
#include <driver/dac.h>
  dac_output_enable(DAC_CHANNEL_1);
  dacWrite(25, 200); // or dac_output_voltage(DAC_CHANNEL_1, 200);
  delay(5000);
  dac_output_voltage(DAC_CHANNEL_1, 100); // or dacWrite(25, 100);
  delay(5000);
I tried this (which I found in the internet):
    dac_cw_config_t dac_cw_config = {
        .en_ch = DAC_CHANNEL_1,
        .scale = DAC_CW_SCALE_1,
        .phase = DAC_CW_PHASE_180,
        .freq = 25000,
        .offset = 127
    dac_cw_generator_config(&dac_cw_config);
    dac_cw_generator_enable();
but this throws an error that all the dac_cw_xxx function are not declared in that scope. Trying to include driver/include/driver/dac_common.h as defined on the documentation page linked above throws the error, that no such file could be found.
So my main question is: How can I configure the DAC, especially the frequency (and what is the default frequency)?
